DHC-6 Twin Otter Update Sets 1:72 AeroCraft Models
While the available kit is a good one, it leaves room for improvement which Ali has now addressed.
New cockpit Set
This is a complete new cockpit section with the windows cast in clear resin with correctly proportioned windows.  As well as the lower part there is also a new cockpit bulkhead.
Tail Planes Set
Most of the versions of the kit suffer from sink/shrink marks in the tail planes and this is a quick drop in replacement for these parts.
Engine Upgrade Set
This is a new set of engine fronts for a more realistic look, with new spinners and new prop blades. These can now be properly set as feathered when the aircraft is shut down.
The casting of the parts is upto Ali's usual high standards. Highly recommended to bring your Twotter up a notch.
Review samples courtesy of
