Pin Posted July 19, 2020 Share Posted July 19, 2020 2 minutes ago, Mike said: I'm confused. How many builds are going on in this thread? Two, Ken and me Link to comment Share on other sites More sharing options...
Flankerman Posted July 19, 2020 Author Share Posted July 19, 2020 I'm in the middle of a house clearance - so I'll be 'offline' for a week or two as far as building goes. All down to you for the time being Alexey...... Ken Link to comment Share on other sites More sharing options...
Aardvark Posted July 19, 2020 Share Posted July 19, 2020 4 hours ago, Pin said: Boogies are the concern. I'm not sure that that they would withstand the significant weight of the model, I'm thinking of replacing some plastic parts with scratch built ones made of metal tubes Maybe make a copy of the front wheels in lead (Plumbum) and install them instead of plastic? B.R. Serge Link to comment Share on other sites More sharing options...
Pin Posted August 2, 2020 Share Posted August 2, 2020 The kit does not provide any struts to join massive "legs" to the wing, it needs some reinforcement. Event without the tail booms the wing weight distribution makes it sit on its heels. I wanted to put lead pellets to the leading edge of the wing, for this I have made a bag that is easy to insert into a wing and fill with pellets through a funnel Eventually it sits straight. But it required A LOT of weight, the wing is really very very heavy 5 Link to comment Share on other sites More sharing options...
Pin Posted November 13, 2020 Share Posted November 13, 2020 No, the build is not stale or abandoned, but I spent to much time fitting and rescribing all seven engine nacelles Unfortunately latest forum engine upgrade has invalidated all the pics. Maybe I should re-upload them some day 3 Link to comment Share on other sites More sharing options...
John Meyer Posted January 11, 2021 Share Posted January 11, 2021 I'm working on this kit as well and have done some balance tests. There's ample room in existing spaces for weight without cutting holes in the wings, using magnets, etc. You can put weight in the "fuselage," the landing gear pontoons and supports, and the engine nacelles. I threw away all the landing gear struts due to concerns about their weakness. They're also fiddly as can be, and completely invisible once the pontoons are together. I made axles out of steel rod and styrente supports glued to the pontoon walls. Much easier and stronger. While it's a very cool kit in some ways, it's generally pretty awful in terms of fit. NOTHING can be assembled without tweaking and trimming. The windows are all to big for their openings in the fuselage and wings. The exhausts are all too big to fit in the slots on the nacelles. The openings for the struts on the horizontal tail and vertical fin are also too small. Nor will any of the control tabs fit without a lot of work. Etc. etc. It just isn't any fun to build. Link to comment Share on other sites More sharing options...
