Stash Refugee Texan or Harvard
Today I was delving into the stash to look for something and I came across a couple of Academy 1/72nd Texans.
Upon opening the box I found the kit was reasonably advanced, I decided to take pity on it and rescue it from the stash.
You can see, I'd got the big bits buttoned up, this definitely exceeds the 25% that would exclude it from being a GB entrant!
Rescued_1
It's a bit very hard to see, but I'd put some circular grips on the top of the control column, that and the extended exhaust tells me I was originally making this as a Harvard IIb but as I haven't made the fuselage alterations to the rear of the canopy my options are still open.
Rescued_3
I'd previously added some seatbelts, can't tell whether I scratched them or whether they're aftermarket, thinking about it they look too neat so they're probably aftermarket.
Rescued_4
Finally, I'd done some work on the propeller, the kit is based upon a T-6G so comes with a propeller boss typical of that version, the propeller beneath that is very plain, lacking any detail such as the pitch change counterbalance weights so hopefully, you can see I've added some detail.  Again, this points to my original intention to make a Harvard but as I have spares my options are still open on that front, I could keep it and use it for a Harvard later if I decide to go down the route of a spinner equipped aircraft.
Rescued_2
Martin @RidgeRunner, the prop was altered in the method I'd described to you when you were asking about AT-6D, I'm actually quite pleased with this result.
This will be a sloooow build, I've still got my studies to complete and that's after I've rebuilt my modelling desk which I had to clear the way for some electrical work to be done in the basement where the modelling lair is.
I haven't decided whether I'm going down the Harvard IIb route (I have the CMR conversion), or whether to make a Texan, I've got plenty of options, the DC Caspar set for the Soccer War, a Blue Rider set for a Nicaraguan machine (thanks Martin), some other Latin American options on an Aztec sheet, the ArmyCast sheet for worldwide Texan/Harvard, Modeldecal and S&M decals for RAF options and finally, which probably come as no surprise to some, the Model Art and Berna decal options for French Texan's in North Africa...   ...choices, choices, choices...
