Model Mate Posted July 5, 2020 Share Posted July 5, 2020 DIY compressor Living on a boat is a wonderful lifestyle but it does come with certain challenges. My lovely Silair compressor unfortunately refuses to operate on my dirty and weedy 240V power supply, so I needed to come up with an alternative. I had a cheap 12V car tyre compressor (and plentiful 12V power) but realised that it wouldn’t give a smooth supply of air, so I needed a reservoir. Last summer I lashed up a terrifying monstrosity using a 5 litre water bottle, aforementioned compressor and the regulating valve and moisture trap from the Silair. This worked surprisingly well, and allowed me to spray a couple of models, but having languished on the boat unattended for too long, started to leak, so I decided it was time for an upgrade. I found a timber sprayer in Aldi for a tenner and couldn’t resist. Boat life has made me rather “greener” than ever, and the prospect of being able to airbrush without relying on electricity at all was irresistible – despite the fact that my electricity all comes from solar anyway. That said, I decided to connect the 12V compressor regardless, just to have the choice you understand. The timber sprayer comes equipped with two threaded in/outlets. I cut the threaded head off one and inserted a tubeless tyre valve stem with a couple of rubber washers and a good dose of araldite epoxy glue. The mini-compressor’s hose just clips onto this as it would a tyre. The second in/outlet was threaded using a ¼” BSP thread tap. I got a ¼” BSP 45 degree angle, bulkhead fitting and a bunch of male/male and female/female connectors from eBay. I wasn’t sure what exactly would physically fit and couldn’t decide on the orientation, so I thought I’d best cover a few bases. Having the 45 degree angle gave me a bit of flexibility as to whether I want to lie the whole contraption on its side, or have it standing upright. Again using araldite as a thread lock/sealant, I screwed it all together and in. BE WARNED – in classically perverse imperial style, a BSP thread that measures ½” is NOT a ½” – it’s actually ¼”! Also, there are DIFFERENT ‘standard’ BSP threads; parallel and tapered – I think we need parallel for this stuff. Honestly, it’s no wonder the British Empire collapsed… The funnel/cup arrangement was cut down as it was a bit cumbersome and the plunger mechanism was reinstated for manual power. The valve and moisture trap was fitted and the whole contraption was screwed down onto a piece of MDF as a baseplate. It seems to work really well - 30psi in the bottle lasts for a few minutes when you’re only drawing 5-10psi from the airbrush. Once it drops too low, switch on the compressor for a couple of minutes or pump the handle half a dozen times and you’re back up to pressure! I used a few bits and bobs I already had to hand for this, but if you needed to buy everything in, here’s a rough guide: Timber sprayer £10 12V compressor £15 Pressure regulator & moisture trap £10 Pipe fittings £10 Tubeless tyre valve stem £5 ¼” BSP parallel thread tap £5 So for about £55 (or £35 for a fully manual version) you can have a go-anywhere airbrush setup! No more miserable caravanning holidays! 3 Link to comment Share on other sites More sharing options...
Model Mate Posted July 5, 2020 Author Share Posted July 5, 2020 I should have mentioned; if you'd like to see how it performs, have alook at the tail end of my current WIP... 1 Link to comment Share on other sites More sharing options...
stevehnz Posted July 6, 2020 Share Posted July 6, 2020 I like the look of that, you've got me thinking now. Steve. Link to comment Share on other sites More sharing options...
Steve Noble Posted July 6, 2020 Share Posted July 6, 2020 Is it safe to have a plastic bottle as the air tank? Link to comment Share on other sites More sharing options...
