CrazyCrank 2,903 Posted November 1, 2020 Author Share Posted November 1, 2020 Evening guys Tires are on the wheels, not a big improvement, but this car is taking life step by step Only the wing nuts are missing (or the wheel covers supplied in the kit... Haven't decided yet ) Too much dust on this part, I've to blow it and clean the tire 4 Link to post Share on other sites
silver911 955 Posted November 1, 2020 Share Posted November 1, 2020 Very nice but...me being me...I have to ask...where are the valve stems Thierry Ron Link to post Share on other sites
CrazyCrank 2,903 Posted November 2, 2020 Author Share Posted November 2, 2020 8 hours ago, silver911 said: Very nice but...me being me...I have to ask...where are the valve stems Thierry Ron Hereunder the photograph I was looking for, in order to scratch the valves: Thanks Ron for the advertisement 1 Link to post Share on other sites
CrazyCrank 2,903 Posted November 2, 2020 Author Share Posted November 2, 2020 Evening chaps I've been asked to make stem valves for the wheels... so I scratched them - Hole 0.5 mm drilled through the wheel - A tiny portion of 0.5 mm electrical wire with black insulation threaded through the hole - a droplet of CA gel - A little touch of semi gloss black at the end of the cable, to mask the metal wire - 4 times - it's done ! A merciless close picture: Wheels are now in place on the axles, they are just waiting for wheel covers or wing nuts . I've also glued in place the air filter and air box To be continued....stay tuned 11 Link to post Share on other sites
silver911 955 Posted November 2, 2020 Share Posted November 2, 2020 Nice tyre valves mate Ron 1 Link to post Share on other sites
johnlambert 1,704 Posted November 3, 2020 Share Posted November 3, 2020 Great job, it's amazing how much a little detail like tyre valves makes such a big difference. If it was my build, I'd go for wheel trims as I prefer them on the SL. 1 Link to post Share on other sites
CrazyCrank 2,903 Posted November 3, 2020 Author Share Posted November 3, 2020 2 hours ago, johnlambert said: Great job, it's amazing how much a little detail like tyre valves makes such a big difference. If it was my build, I'd go for wheel trims as I prefer them on the SL. I'm torn by the 2 options.. Wheel trim caps are beautiful, but a nightmare to paint correctly. PE Wing nuts are beautiful and frankly "glamour", rather easy to assemble, less difficult to paint (Molotow chrome) and would give a touch of originality. I'm going to prepare both sets and have to sleep on it before deciding 3 Link to post Share on other sites
CrazyCrank 2,903 Posted November 4, 2020 Author Share Posted November 4, 2020 Good evening gentlemen Still thinking and hesitating about the wheels, so I've begun a now job, while I'm waiting for the jelly which replace my brain stops to wobble So.....body work ! At least, as many say ! The body has been inspected a while, looking for moulding lines and other stuff, and in reality, there was one major issue: the shape of the right front fender was wrong: viewed from the front, it had a triangular shape instead of a rounded one, as for the left. So began the sanding job, 1000, 2000; 3000 grit, then a light coat of grey primer, to verify the job, and so on, until I get a correct shape for the fender and I've removed the moulding lines I saw previously. Then, I tried a test fit over the chassis, and there....Another issue: the vacuum chamber I've scratched, situated behind the oil tank, didn't allow the body to fit correctly...so I've removed this additional part. And, at least, the body has been primed with a second coat of primer, as well as the doors and the hood: You could notice that the fittings are terrific ! It's Tamiya And I've primed the underbody with Light grey Alclad primer, a second coat is needed: You could notice that the details are very fine and accurate. This underbody, obviously is going to hide the bird cage and other components as the engine, but IT IS a masterpiece itself Stay tuned if you like 9 Link to post Share on other sites
silver911 955 Posted November 5, 2020 Share Posted November 5, 2020 Very nice work Thierry...strangely enough...I faced a similar dilemma with the 312T undertray...whether to use the PE...or retain the moulded detail...which was also superb Regards Ron Link to post Share on other sites
Spiny 1,953 Posted November 5, 2020 Share Posted November 5, 2020 It's very hard to judge the quality of a part when it's that slightly weird matt clear plastic the undertray is made of, but judging by your photos have made a good job of the underbody as well as the body itself. I have to admit that I couldn't tell (still can't if I'm honest) the issue with the shape of the wings but I can't deny that the end product from you is excellent and up to your usual standards. Keep up the good work. 1 Link to post Share on other sites
CrazyCrank 2,903 Posted November 8, 2020 Author Share Posted November 8, 2020 Good evening gentlemen A bit of progress today...I've been working on the tub. The underside has been painted semi gloss black, the wheel housings have received their first coat of Gravity Color GC-208 Daimler silver, and the inside of the tub has been painted red as the inside of the firewall The Red I used is ZERO PAINTS ROSSO-FX Ferrari Leather Color, which match perfectly with the Tamiya suggested color (a 50/50 mix of Tamiya X7 - Bright Red and Tamiya XF-7, matt red) but give in addition and overall a realistic leather effect The dashboard top and the two seats has been painted the same color. The dashboard supplied by Tamiya is a nice chromed part, which had to be painted with 2 colors : - the bottom, in red - and the space between all the meters, the same color than the body, that is Daimler silver - Of course, the bezel must keep their chrome How to proceed ? The solution has been given by another French modeler on his Youtube channel (Fabio from Videomodelling channel) - First: paint the dashboard Daimler Silver, over the chrome - Then, gently strip the chrome on the bezels and other stuff that must be chromed, with a toothpick point - And finally, paint the red part with a fine brush (I tried to paint it before the Silver, after right masking, with the airbrush, but the ZERO PAINT do not stick very well on the chrome, and while removing the masking tape, the red paint stripped out !) Hereunder the result Now, it remains to put the decals and the logo "300 SL" on the dash and many other operations...so stay tuned for the next steps 11 Link to post Share on other sites
johnlambert 1,704 Posted November 8, 2020 Share Posted November 8, 2020 Good work on the dashboard. 1 Link to post Share on other sites
Mr Mansfield 206 Posted November 9, 2020 Share Posted November 9, 2020 Superb workmanship on the dash. Does the kit come with decals for the dials? noticed on your previous post how well the doors line up. That must make you smile Link to post Share on other sites
CrazyCrank 2,903 Posted November 9, 2020 Author Share Posted November 9, 2020 1 hour ago, Mr Mansfield said: Superb workmanship on the dash. Does the kit come with decals for the dials? noticed on your previous post how well the doors line up. That must make you smile Of course, there is ! but I was a bit lazy yesterday, so didn't put them on. There's also a metal transfer with the logo "300SL". This will be done shortly What I've done yesterday evening is : - placing 2 PE parts which represent the locking plates for the doors - fabricating the floor carpeting of the seats - painting the seats red and weathering them a bit To be continued.... 7 Link to post Share on other sites
Pouln 752 Posted November 9, 2020 Share Posted November 9, 2020 Looking very smart, Thierry. I love the dashboard. 1 Link to post Share on other sites
CrazyCrank 2,903 Posted November 11, 2020 Author Share Posted November 11, 2020 Good evening Gentlemen I know that, writing what is following, I'm going, perhaps, to disappoint some of you... but I have to be honest and not to hide the harsh truth ! After a good start on the dashboard, I've faced several issues with domino effect, that I've managed as I could, for finally getting a just passable result to my eyes (and more, only if I remove my glasses) - All was going well for putting decals. - But when I tried to put on the dash the metal transfer (logo" 300 SL"), the Daimler Silver paint stripped out while removing the transparent protector film ! - So, it's been necessary to paint another time the right portion of the dash, while respecting the left portion, in order not to spoil the decals. - Pity, the right most decal (the clock) has been damaged - Fortunately, I had in my stash some spare decals from my Talbot Lago, and I've been able to use one of them, after a little surgery, to replace the damaged one - It remained to clean the metal transfer from the paint that was glued on it, and try to glue it on the dash, if possible without soiling the Silver paint...... - Here, another time, some problems: first the litlle coat of adhesive at the back of the transfer has been removed while cleaning, second, this weak transfer broke in 2 parts during thsoe operations. - I've managed to save it and to glue it in place with very tiny drops of canopy glue, which I hoped to get transparent while drying, but the result is frankly very disappointing, at close range. - At last, in order to enhance the visual aspect of the dials, I've used, as usual, tiny drops of Gauzy Agent put on the decals....But unfortunately, for the first time since I use this varnish, an undesirable reaction appeared with the Tamiya decals (and not with the Heller Talbot Lago one), and the dark parts of the decals have turned a bit grey !!! - I've managed to darken them a bit using diluted Tamiya Black Panel Line Accent Color All things considered, this would not have happened if I have taken the precaution of spraying 1 or two layers of Clear coat over the dash after having put the decals....Once dried, I would have placed the metal transfer without any difficulty and without stripping the paint whole removing the film. It's often from your mistakes that you learn most ! Hereunder, some photos (I've avoided to take close pictures of the right part of the dash, because I feel ashamed to have spoiled it) To go on enhancing the dash, I've put a micro touch of Molotov Chrome with the sharpened point of a toothpick on the 4 screws situated on the top of the dash and have given more relief to the ashtray with Tamiya Light Grey Panel Line Accent Color Now, it's time to modify the steering while, using the Hobby Design PE parts Stay tuned if you like and thanks for watching 10 Link to post Share on other sites
silver911 955 Posted November 11, 2020 Share Posted November 11, 2020 Many are the trials of modelling mate...we do what we can 1 Link to post Share on other sites
CrazyCrank 2,903 Posted November 11, 2020 Author Share Posted November 11, 2020 1 minute ago, silver911 said: Many are the trials of modelling mate...we do what we can True my friend, and I'm confused by such forgetfulness 1 Link to post Share on other sites
silver911 955 Posted November 11, 2020 Share Posted November 11, 2020 Ah...confusion and forgetfulness...the modellers 'mantra' 2 Link to post Share on other sites
CrazyCrank 2,903 Posted November 11, 2020 Author Share Posted November 11, 2020 Wheels too have been redone, because finally I wasn't happy with them. The Mig pigments , based I suppose, upon graphite powder, are very greasy and let prints on the tyre. So, I've stripped out the paints in a bath of Glanzer and the a bath of IPA, and then redo the job using the following sequence: - 1/ Alclad Gray Primer and Microfiller...24 hours drying - 2/ Alclad Gloss Black base....48 hours drying - 3/ Alclad Polished Aluminium, 3 light coats....72 hours drying - 4/ Put the tires on..no issue - 5/ Paint the valve satin black with the point of a sharpened toothpick, under magnifying glasses - 6/ a bit of Tamiya Black panel Line Accent Color here and there and... Here is the result, which I'm proud of: 7 Link to post Share on other sites
nick 1,058 Posted November 11, 2020 Share Posted November 11, 2020 Much better, they look great now. regards Nick 1 Link to post Share on other sites
Bengalensis 6,519 Posted November 12, 2020 Share Posted November 12, 2020 Without small mistakes here and there we never grow and learn. Still looking lovely! 1 1 Link to post Share on other sites
Pouln 752 Posted November 12, 2020 Share Posted November 12, 2020 Sorry to hear about the mishaps with your dash. Good save though and thanks for the warning you added. Wheels look great after the latest treatment. 1 Link to post Share on other sites
ejboyd5 320 Posted November 12, 2020 Share Posted November 12, 2020 (edited) Suggest you remove the "flocked" carpet. The 300 SL had black ribbed rubber mats covering the floor areas in front of the seats. The vertical sides of the footwells were covered in either leather or vinyl to match the interior. The transmission tunnel cover was carpeted with a tight square weave carpet as was the horizontal area behind the seats. Since the carpet was such a hard, tight weave, there is no softness or pile visible in 1:1 scale let alone in a 1/24 model, Wheels look much better following the repaint, but please be advised that fully chromed wheels were extremely rare back in the day, appearing only on some specially prepared display vehicles. Similarly, what is commonly seen today as a wheel with the majority painted body color and a highly polisher alloy outer rim is not an original finish. Factory wheels were painted body color all over. Hub caps were generally chrome with the three segments abutting the star and the wide ring outside that being painted in the body color. Some early cars (not yours) had two tone hubcaps with the segments abutting the star being painted to match the interior and the wide ring around that painted in body color. Sorry about the wasted effort you put into scratch building the vacuum tank, but as you now know it was not needed with the Ate T-50 brake booster system with which which your car is equipped. Finally. with regard to the dashboard lights, may I suggest some small drops of paint: 1) Red, for the light between and above the tachometer/speedometer which is the generator charging indicator; 2) Blue, for the small light between and below which is the high beam indicator; and 3) White, for the other two lights below the tachometer and speedometer. The lighted pull knob controls (electric fuel pump and ventilation blower) can be brightened with a dab of amber paint to signify their lenses as well. Edited November 12, 2020 by ejboyd5 1 Link to post Share on other sites
CrazyCrank 2,903 Posted November 12, 2020 Author Share Posted November 12, 2020 1 hour ago, ejboyd5 said: Suggest you remove the "flocked" carpet. The 300 SL had black ribbed rubber mats covering the floor areas in front of the seats. The vertical sides of the footwells were covered in either leather or vinyl to match the interior. The transmission tunnel cover was carpeted with a tight square weave carpet as was the horizontal area behind the seats. Since the carpet was such a hard, tight weave, there is no softness or pile visible in 1:1 scale let alone in a 1/24 model, Wheels look much better following the repaint, but please be advised that fully chromed wheels were extremely rare back in the day, appearing only on some specially prepared display vehicles. Similarly, what is commonly seen today as a wheel with the majority painted body color and a highly polisher alloy outer rim is not an original finish. Factory wheels were painted body color all over. Hub caps were generally chrome with the three segments abutting the star and the wide ring outside that being painted in the body color. Some early cars (not yours) had two tone hubcaps with the segments abutting the star being painted to match the interior and the wide ring around that painted in body color. Sorry about the wasted effort you put into scratch building the vacuum tank, but as you now know it was not needed with the Ate T-50 brake booster system with which which your car is equipped. Finally. with regard to the dashboard lights, may I suggest some small drops of paint: 1) Red, for the light between and above the tachometer/speedometer which is the generator charging indicator; 2) Blue, for the small light between and below which is the high beam indicator; and 3) White, for the other two lights below the tachometer and speedometer. The lighted pull knob controls (electric fuel pump and ventilation blower) can be brightened with a dab of amber paint to signify their lenses as well. Thanks so much @ejboyd5 for these precisions and advices It seemed to me, looking at the wheels on some pictures found on the Internet, that what I have represented polished aluminium, could be the same color than the body. Now I know....so the job will be redone, for the fifth time ! OK for the dashboard lights; I think I've understood what you mean... could you provide on this forum some close up pictures of the dash if you own ? Unfortunately, it's too late for the bad carpeting on the floor. Impossible to remove it without definitely ruining the tub. I'll try to fix this mistake, with black stuff to simulate the ribbed rubbernecked mats Concerning the tunnel , perhaps could I modify the appearance, glueing some painted fabric on it... I've to sleep on it 1 Link to post Share on other sites
