Sign in to follow this
Julien
Aircraft Paint Stand & Accessories EBMA Hobby & Craft
EBMA Hobby & Craft
We all have all at some time struggled when painting and or decaling in that situation where you need a third hand. EBMA have now come up with a modular aircraft stand to help out with this. It will take a wide variety of 1/72 aircraft and some smaller 1.48 such as single engine fighters.  The base dimensions when built up are 252mm x 236mm. There are then four slots in each side of the top of the T for the wing supports, and 10 in the body for tail supports. There are four different height tail supports (30mm, 40mm, 50mm and 60mm high), and 3 pairs of different height wing supports (.35mm, 5mm and 55mm high). These parts are on one flat sheet and just press out.
Filled with my 1/72 Canberra to give scale
Construction is simple, and will require some PVA to glue the sections together, and having some clamps handy will be a boon for getting strong joints.  The joints will also be stronger if you use proper woodworking PVA glue, which can be sourced online easily and cheaply if you’re in need.  Instructions are found online to save paper and cost, and yes you do really need to look at them. If you have built any kind of flat pack you already know this! This set like many others from EBMA comes with little magnets which you can use for to keep more than one of their modular units together.
Large Supports
If you find you want or need more height to the stands then there is an extra pack of larger support stands which can be purchased. These are four tail supports (80mm, 90mm, 100mm & 110mm high), and 4 pairs of wing supports (75mm, 85mm, 95mm and 105mm high). These parts are on one flat sheet and just press out.
Filled with my 1/48 Me 262 to give scale
Twin Boom Supports
If you are making or going to make a twin tail boom aircraft then there are also stands which can be purchased for these. These are four tail supports (35mm, 45mm, 55mm & 65mm). These parts are on one flat sheet and just press out.
Conclusion
This is a well designed stand system which should suit a lot of modeller. The ability to buy extra parts keeps the initial price of the basis unit down.  As well as this stand EBMA make others specifically for armour and railroad modellers.
Very highly recommended.
Review sample courtesy of
