Sign in to follow this
A_S
Decals in panel lines - found a good trick
Hi
Ive not seen this mentioned so I thought I would bring it to peoples attention.
ive often seen people recommend pushing decals into panel lines with a knife/blade and cutting the decal.
however I’ve been using the Tamiya fine cotton buds in combination with the usual decal softening solutions and it works a charm. The decals set down really nicely and you can apply a lot of pressure to really push them in. If you rub them up and down the panel line with enough micro sol it will give you a clean panel line and expose any panel line wash underneath.
Sounds like a great idea if you already spent time detailing the panel lines.
You can also run a pin or needle along the groove at a shallow angle, tip trailing.  I was given that tip by a friend and it has worked for me over the years :)
