Grumman Hellcat Mk.I, 1/72, Eduard - community knowledge appreciated
Hello,
I’ll skip the kit introduction as Eduard’s Hellcat in 72nd scale is well known to the community. I’m not a Hellcat aficionado and actually decided to give it a try thanks to the good press and the generous dimensions of the model in this scale. My knowledge on the subject is quite limited and the documentation even less – the good old “In Action” booklet and the instruction sheet of the 1/24 Airfix kit! Subsequently I’ll heavily rely on community knowledge to guide me into the subject – a Grumman Hellcat Mk.I, obviously FAA, more precisely the JV131 with invasion stripes.
The starting point is the Eduard ProfiPack dual combo (so 2 kits, a Mk.II or F6F-5/ -5N might come afterwards on the production line, who knows) and a several accessories (Big Ed set, various resins, etc.). Not sure if all those will find place in a single model. For me, the big “first” will be the rivet decal set – never tried it before; I’ll see.
Please excuse the inherent English language mistakes that will be present in my post from time to time; obviously I’m not a native speaker but more of a “bad English” category.
101 102
That being said, let’s roll.
Started by removing exhausts pipes from the fuselage, not due to their representation – quite honest for the scale – but with the aim of simplifying the painting of the exhaust stains latter on; I’ll add some brass tube sections at the very end of the construction.
I’ve also opened the tail wheel well; the blank proposal of the kit gives some sort of a toy appearance. I’ll recreate some dummy representation of the two fuselage frames in that area. Of course, the 2 ejector pin marks on fuselage inside are now visible and must be somehow handled.
103 104 105
As my model will be a Mk.I – with the corresponding additional windows at the back of the cockpit – and because Eduard completely neglected any frame representation there, I’ve transferred the seat back panel to a piece of 1mm polystyrene and recreated the upper part of the back frame. Not 100% accurate, just to avoid a nasty void perspective. Still thinking if lower part of the abovementioned frame is needed.
106 107 108
More to come; hopefully.
Best regards,
Iulian
Decided to add an extension to the rear cockpit frame, loosely resembling the one from the Airfix instructions.
109
A little bit of work on tail wheel well; the way Eduard modeled the oleo strut force me to insert it close to the middle frame, on the original it was actually articulated on the front bulkhead. I do not intend to completely redo the tail wheel assembly – I’m not in that league of scratch building – so I’ll keep kit’s approach; the Alu tube is the provision for tail wheel insertion.
110 111 112
A question regarding painting – what would be the right color for wheel wells (including the tail one) and cockpit interior? Any Vallejo Model Air reference for that/ those colors?
Feedback, comments and recommendations are more than welcomed.
Best regards,
Iulian
  • mack changed the title to Grumman Hellcat Mk.I, 1/72, Eduard - community knowledge appreciated
Hello fellow community members,
I would highly appreciate your opinion/ recommendation regarding cockpit interior and wheel wells colors from Vallejo acrylics range.
My limited inquiry (mostly internet) ended up with the following results:
for cockpit interior:
(Interior Green) – Vallejo Model Air 71137 or 71010
or
(Cockpit Light Green) – Vallejo Model Air 70974
For wheel wells (including tail wheel) is either same color as cockpit interior or underside color.
For underside (supposedly Sky S – BS210) I have no less than 3 Vallejo Model Air references: 71302, 71296, 71009.
So, where to?
