BobC Posted June 19, 2020 Share Posted June 19, 2020 (edited) A returnee to the hobby and straight in at the deep end with a project combining a Tiger and Bussing NAG crane in an engine out scene, what could possibly go wrong 😆 I've already built the crane as far as I could go before setting it in the final scene. If I have worked out image loading a few pics should follow and I'll say a bit about each. The designer of this kit has become my arch nemesis, why mold one componoint when six will do the job just as well must have been their daily mantra. Building up the chassis, Edited June 19, 2020 by BobC 4 Link to comment Share on other sites More sharing options...
Stef N. Posted June 20, 2020 Share Posted June 20, 2020 "The designer of this kit has become my arch nemesis, why mold one componoint when six will do the job just as well must have been their daily mantra." Just started a kit with very similar problem. I got annoyed after the first axle so put it away "for a later date".😀 Good luck with this project. It sounds very interesting.👍 1 Link to comment Share on other sites More sharing options...
BobC Posted June 21, 2020 Author Share Posted June 21, 2020 A bit of work on the can interior next. For the paintwork I'm using brushes throughout, don't yet have an airbrush so it's old school for me. These Lottie's were typically shipped over to N Africa painted grey and we refinished in theatre with green brown and often an olive camo. My lorry crew are a tad lazy and only painted the visible parts, hence the interior remaining grey along with the chassis underside. No camo yet, a second line vehicle and a crew that couldn't see the point of it 👌 Used a touch of Chrome and steel to add highlights and areas of wear. Most of my paints are vallejo acrylics with some from Tamiya, enamels from Revel and Humbrol with a few airfix freebies that came with a kit. Nothing fancy on the brush front, a few I bought and some I found in the man drawer. 4 Link to comment Share on other sites More sharing options...
BobC Posted June 21, 2020 Author Share Posted June 21, 2020 A little bit more work on the chassis, adding some corrosion onto the leaf springs and chassis members. Painting up the tool box, lots of options on this, various panels can be set open or closed so lots of choice for the modeller. Fillng away on the door glass allowed me to set the window partly wound down. 3 Link to comment Share on other sites More sharing options...
BobC Posted July 9, 2020 Author Share Posted July 9, 2020 Build interrupted by dentist, marathon man moment is now complete so a lot of progress made.... Rear deck and crane base fitted. 2 Link to comment Share on other sites More sharing options...
BobC Posted July 9, 2020 Author Share Posted July 9, 2020 Tool box nearly complete. Leaving this open at the top and the left hand side. Crane built and decals on, lots of them. Lots of detail on the crane and had a go at weathering this, mainly used a fine brush to apply highlights and shades 1 Link to comment Share on other sites More sharing options...
BobC Posted July 9, 2020 Author Share Posted July 9, 2020 Jerry cans built up, nice etched parts for these. Slung underneath and a few spares which I'll use in the diarama Lots of towing equipment fitted to the rear deck, all of which could be used for a variety of scenes 5 Link to comment Share on other sites More sharing options...
BobC Posted July 10, 2020 Author Share Posted July 10, 2020 About to start the Tiger tank. This particular Dragon Initial Tunisia is not the 131 kit they also produced. There are some glaring errors between my kit and the more accurate 131 kit. I'll point these out as I proceed, I wont be correcting them, but I also wont be modelling 131, I'll be modelling 122, although some of the errors remain at least I wont get the Bovington crew on my case I have ordered up the Engine bay kit from the USA and will also buy in some maintenance crew and a field workshop. I also fancy trying some Friul metal tracks. I notice they provide two sets for the initial tiger. One described as a mirror set consisting of 2 sets of 110 links and the other set described as 220 links (early). Does anyone know if there is a difference between these sets? Link to comment Share on other sites More sharing options...
M3talpig Posted July 10, 2020 Share Posted July 10, 2020 (edited) If your doing a 501 Tiger you got your work cut out for you ...im doing 142 at the moment, big project so it's being done in spurts whilst i do other things...i'm assuming your going for something like this...... On the tracks if your doing an african Tiger you need the initial fruil tracks as they dont have the chevrons on the links..... set ATL116 . Edited July 10, 2020 by M3talpig 1 Link to comment Share on other sites More sharing options...
BobC Posted July 13, 2020 Author Share Posted July 13, 2020 On 10/07/2020 at 11:14, M3talpig said: If your doing a 501 Tiger you got your work cut out for you ...im doing 142 at the moment, big project so it's being done in spurts whilst i do other things...i'm assuming your going for something like this...... On the tracks if your doing an african Tiger you need the initial fruil tracks as they dont have the chevrons on the links..... set ATL116 . Thanks for the info regarding the tracks. Made a start on the Tiger, my kit has errors on the paint codes, you could end up painting all the wheels the wrong colour along with the hull, then having to disassemble it all and repaint. That would be a beginner's error, wouldn't catch me doing that, no siree. It's Ral 8000, not Ral7028, a couple of reviews pointed this out, should have read them first! 1 Link to comment Share on other sites More sharing options...
BobC Posted July 20, 2020 Author Share Posted July 20, 2020 On with the Tiger tank, initial production, Tunisia. This shot shows a measure of the technical achievement of the design and it’s strategic weakness. It was so complex, sucked up industrial capacity and capability along with scarce resource. Can you imagine if they had designed a simple tank with sloped armour and had five thousand available by 1940. Luckily for us they wasted inordinate effort on complex tanks, tactically good, but always defeatable. The interleaved road wheels allowed for larger wheels and the number, over forty, have an unbeatable track pressure. Steel wheels, initially Clad in rubber, hybrid electric drive. Found that this kit does actually contain some of the correct parts for 131 should you wish to model it, such as the latter hinged rear mudguards. 2 Link to comment Share on other sites More sharing options...
M3talpig Posted July 20, 2020 Share Posted July 20, 2020 (edited) Progress is good bud ...what kit is the Tiger..i mean manufacturer of it? And i think it was only the Ferdinand Porsche design chassis that had the hybrid drive ...and substandard engineering just isn't in a German engineers vocabulary Edited July 20, 2020 by M3talpig Link to comment Share on other sites More sharing options...
BobC Posted July 28, 2020 Author Share Posted July 28, 2020 It's the Dragon early Tunisia kit. Not the specific 131 kit, but it does include a lot of sprues from that kit and you could build most of 131 if you wanted. Lots of spares for the future that's for sure. A lot of updates to post on the build, I'll sort that out over the weekend. 1 Link to comment Share on other sites More sharing options...
