1/72 Airfix Supermarine Spitfire F Mk.22 + Eduard PE set
10 hours ago, Roland Pulfrew said:
Beautiful job of a beautiful aircraft!  I really should get round to finishing mine 🤦🏻‍♂️
Hi Roland. Hope you are well and thank you very much. I look forward to seeing yours finished then! :thumbsup:
Kind regards,
Stix
10 hours ago, TEMPESTMK5 said:
Good afternoon Stix
 You have done a very good job here 👍
Patrice
Hi Patrice. Hope you are well and thank you for your kind comments. :thumbsup:
Kind regards,
Stix
Fantastic job! I am impressed by the realism!  I especially love what you did with the wing roots.   I've got this same kit in my stash, hope it turns out half as good as this.
15 hours ago, Vlad said:
Wow! Really amazing build inside and out, I thoroughly enjoyed looking at that!
Hi Vlad. Hope you are well and thank you very much for your kind comments.
Kind regards,
Stix
Kind regards,
Stix
Good morning Stix
Thank you for asking everything is fine ..
Best Regards
Patrice
18 hours ago, Tbolt said:
Excellent build with great painting and weathering.
Hi Tbolt. Great to hear from you again. I hope you are keeping well. Thank you very much for your kind comments.
Kind regards,
Stix
Simply outstanding Mr Stix!!!!!!  The results are not only impressive, but inspiring as well.  :clap2:
Mike
21 hours ago, Dennis_C said:
An impressive Spitfire! Clean and nice build of a very elegant Spitfire version!!!
Hi Dennis. I hope you are keeping well. Thank you very much for your kind comments.
Kind regards,
Stix
22 hours ago, giemme said:
Suggestions... I suggest you keep on like that, because this model is spectacular! :worthy: :worthy:
Ciao
Hi Giorgio. Thank you very much - as always you are too kind.
Kind regards,
Stix
23 hours ago, russ c said:
Beautifully done Stix, thought it was `48th at first
Hi Russ. Hope you are well and thank you very much for your kind comments.
Kind regards,
Stix
A masterclass in brush painting - you really must give us a lesson in how to achieve such a fantastic finish and exquisite restrained weathering. Simply lovely!
Mark
I love a Griffon engined Spit and this Mark is my favourite...that laminar-flow wing and the sheer brute power up front...great
The Spiteful/Seafang had the "laminar flow" wing.  The 20 series had the aerodynamic shape of the standard wing with the extended wingtips, just clipped a little.  They did have a redesigned structure for higher dive speeds and stiffer to resist twist, plus simply hinged ailerons instead of  the Frise kind.  Plus the new undercarriage and all the rest...
On 14/06/2020 at 18:28, Epeeman said:
Outstanding, Spitfire Stix - your brush painting is truly outstanding.
Question - I brush paint myself and am therefore interested in knowing what/how you highlighted the panel lines
Regards
Dave
Hi Dave. Thank you very much for your comments and your question.
With regards the panel lines - the process I went through for painting the aircraft and doing the panel lines can be found in this post in my Work In Progress thread:
https://www.britmodeller.com/forums/index.php?/topic/235071411-supermarine-spitfire-f-mk22-airfix-172-finished-and-in-the-gallery/&do=findComment&comment=3716903
You will need to scroll down a bit.
Please let me know if anything requires clarification.
Kind regards,
Stix
Really rather lovely. It's great little kit (Airfix what have you done with it, it's disappeared!) and you've really made it shine with all the extra bits & bobs. Super-nifty brush work to polish it off.
Justin
On 14/06/2020 at 19:09, Martin1962 said:
That is a beautiful and superbly detailed rendition. Fantastic. The photographs are stunning. Excellent work
Hi Martin. That is very kind of you to say, thank you. :thumbsup:
Kind regards,
Stix
On 14/06/2020 at 20:15, John Laidlaw said:
Simply lovely, and in 1/72nd as well! My hat's off to you, sir.
Hi John. Hope you are well and thank you very much for your kind comments.
Kind regards,
Stix
On 14/06/2020 at 21:10, Wulfman said:
Superb build, finish and presentation, great modelling !
Wulfman
Hi Wulfman. Hope you are well and thank you for your very kind comments. :thumbsup:
Kind regards,
Stix
Hi opus999. I hope you are well. Thank you very much for your most kind comments. :thumbsup:
Kind regards,
Stix
