PlaStix Posted June 26, 2020 Author Share Posted June 26, 2020 4 minutes ago, Corsairfoxfouruncle said: Nice looking mud Stix, up to your good work as usual. Thank you Dennis. You probably missed the snow photos as I managed to loose the last two photos in the posting of it! Dunno what happened! I have put them back in now. Take care and stay well. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
Hewy Posted June 26, 2020 Share Posted June 26, 2020 Is it me or does everything look just perfect, Exellent bit of painting and weathering stix 1 1 Link to comment Share on other sites More sharing options...
modelling minion Posted June 26, 2020 Share Posted June 26, 2020 I think you summed that up expertly Glynn "perfect" is the only word to describe your work so far Stix. Great painting and weathering as usual and the mud and snow look really good. 1 1 Link to comment Share on other sites More sharing options...
PlaStix Posted July 5, 2020 Author Share Posted July 5, 2020 On 26/06/2020 at 21:38, Hewy said: Is it me or does everything look just perfect, Exellent bit of painting and weathering stix Hi Glynn. Hope you are well and thank you. Too kind! On 26/06/2020 at 21:55, modelling minion said: I think you summed that up expertly Glynn "perfect" is the only word to describe your work so far Stix. Great painting and weathering as usual and the mud and snow look really good. Hi Craig. Hope you are well. You and Glynn are way too kind. Once again I am sorry for the length of time between update posts. Not like me in the old days with two or three updates a weekend! So, as I mentioned a while back, work on the wheels was next - I added some touches, in various places, of thinned Humbrol Gunmetal to create chipping effects, over which I added some very thinned Anthracite before using some Railmatch Light rust for rusty highlights: Closer view: Next I stippled on some very thinned Matt White in several thin layers to build up a worn whitewash appearance: Same as on the hull sides - I applied very thinned Humbrol Dark Earth, followed by Vallejo Mud and then Vallejo Snow: Following touching up of the wheels edges - the wheels were then attached to the hull sides using CA glue: With the wheels setting I started work on the tracks - applying some filler to the ejector pin marks on those sections that will be more visible: I followed my usual routine for tracks - thinned Anthracite applied all over with a medium flat brush. Once dry everything was dry-brushed with Gunmetal. Once dry everything was given an overall wash of very, very thinned Humbrol 93 and finally some touches of very thinned Railmatch Light Rust was applied here and there: Track parts cut off the sprues and assembled: Mud and snow lightly applied to the undersides of the sponsons using a cocktail stick: Same on the upper surface of the tracks - where it would have been difficult to get at with the upper hull unit in place: Test fit of the upper hull: Upper hull attached in place using the screws provided: More assembly followed and then painting was next - again - Humbrol 102 applied with a medium flat brush: Next I applied a very thinned wash of Revell's Gunship Grey all over. Once dry I used a fine pointed brush to apply a thinned wash of Revell's Anthracite in and around the detail. Finally, over all this, I dry-brushed a lighter version of Humbrol 102 - lightened with matt white with a touch of matt yellow. Washes applied: And dry-brushed: Next time it will be decals and starting the winter weathering. Comments and suggestions welcome. Kind regards, Stix 11 Link to comment Share on other sites More sharing options...
modelling minion Posted July 5, 2020 Share Posted July 5, 2020 I think WOW!!! sums that up. What a transformation and excellent progress. Once again everything is perfect right down to the application of the mud and snow by cocktail stick, I don't know how you get it to be so realistic. I am especially grateful to your concise step by step explanation of your work and telling us exactly what paint and brush you used to work your magic, I still can't make half as good a job of things as you do but its nice to know how you do it. Isn't Revell's anthracite wonderful stuff, I use it for exactly the same things you do, also makes for a good faded black. 2 1 Link to comment Share on other sites More sharing options...
fatfingers Posted July 5, 2020 Share Posted July 5, 2020 Aye up Stix, Absolutely superb build. As @modelling minion says above the step by step guide you provide is really helpful. Regards, Steve 1 1 Link to comment Share on other sites More sharing options...
SoftScience Posted July 6, 2020 Share Posted July 6, 2020 It's always a treat to follow one of your projects. 1 Link to comment Share on other sites More sharing options...
Hewy Posted July 6, 2020 Share Posted July 6, 2020 Beautifully painted stix 1 Link to comment Share on other sites More sharing options...
Silver Fox Posted July 6, 2020 Share Posted July 6, 2020 This is a great step by step guide, thank you for posting. 1 Link to comment Share on other sites More sharing options...
SimonT Posted July 7, 2020 Share Posted July 7, 2020 Outstanding work as always Stix, really like how you build up the mud then add the snow, looks very good. 1 Link to comment Share on other sites More sharing options...
exdraken Posted July 10, 2020 Share Posted July 10, 2020 Wow! Looks really great! Need a start mine finally.... 1 Link to comment Share on other sites More sharing options...
PlaStix Posted July 13, 2020 Author Share Posted July 13, 2020 On 05/07/2020 at 20:19, modelling minion said: I think WOW!!! sums that up. What a transformation and excellent progress. Once again everything is perfect right down to the application of the mud and snow by cocktail stick, I don't know how you get it to be so realistic. I am especially grateful to your concise step by step explanation of your work and telling us exactly what paint and brush you used to work your magic, I still can't make half as good a job of things as you do but its nice to know how you do it. Isn't Revell's anthracite wonderful stuff, I use it for exactly the same things you do, also makes for a good faded black. On 05/07/2020 at 21:45, fatfingers said: Aye up Stix, Absolutely superb build. As @modelling minion says above the step by step guide you provide is really helpful. Regards, Steve On 06/07/2020 at 13:49, SoftScience said: It's always a treat to follow one of your projects. On 06/07/2020 at 18:52, Hewy said: Beautifully painted stix On 06/07/2020 at 20:07, Silver Fox said: This is a great step by step guide, thank you for posting. On 07/07/2020 at 07:12, SimonT said: Outstanding work as always Stix, really like how you build up the mud then add the snow, looks very good. On 10/07/2020 at 19:56, exdraken said: Wow! Looks really great! Need a start mine finally.... Hi all. I am sorry for the length of time it's taken me to reply! Thank you very much for all your kind comments. Again - as before - I have been doing bits and pieces on this when I have had chance. Decals applied - Wow! they're thick!! I cut my decals as close to the printed design as possible - to try to minimise the problems of silvering with the carrier film. Problem is - the cut edges are quite visible in some lighting! There will be lashings of weathering!! Baggie with all the other bits and pieces that still need to be added: Humbrol Gunmetal, Revell Anthracite and Railmatch Light Rust applied very thinned in and around the detail - I wanted some weathering in place to show through my weathered whitewash: Weathered whitewash in place - Humbrol Matt White - very thinned and built up slowly using a small stippling brush - leaving some areas thinner than others: More weathering effects next! Hopefully soon. Comments and suggestions welcome. Kind regards, Stix 12 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted July 13, 2020 Share Posted July 13, 2020 Beautiful work on the green camouflage and white distemper over that. 1 Link to comment Share on other sites More sharing options...
modelling minion Posted July 13, 2020 Share Posted July 13, 2020 That, my friend, is fantastic. I really like the fact that you took the time to do the green paint justice before applying the white over the top of it. The way the white is stippled on is very effective and really does hide the thickness of the Tamiya decals, it never ceases to amaze me that a company that makes some of the best models going makes what are probably the thickest decals around too. This is going to look brilliant when all the parts come together. Sad news about the Victory Show being cancelled, but at least they are planning on holding it next year. 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted July 15, 2020 Share Posted July 15, 2020 On 13/07/2020 at 15:37, PlaStix said: Decals applied - Wow! they're thick!! https://www.britmodeller.com/forums/index.php?/topic/235008098-dealing-with-thick-decals-ie-tamiya/&do=findComment&comment=2464801 On 29/08/2016 at 23:26, Gary C said: The best way to get all Japanese decals ( Fujimi, Hasegawa, Tamiya etc)to work as they're supposed to is use hot water and the correct setting solutions. You'll need a bottle each of Gunze Mr Setter and Mr Softer. Micro sol and others won't work as they're formulated differently. Do not use Gunze on Microscale or Cartograf decals as it will chew right through them. Dip the decal in hot water, it doesn't need to be boiling but it does need to be fairly hot. The temperature of a drinkable tea will do. The glue is heat activated and is what makes up most of the thickness. If you dip it in cold water you'll spend the rest of the day waiting and cursing. Lay down some Mr Setter, this is in the blue bottle. It acts as an additional glue. Slide the decal onto it and into postion and leave it alone. The decal should wrinkle a little. Give it 10 mins or so and go over the decal with a brush with a little Mr Softer (green bottle) on it. Use sparingly as it is extremely hot. Too much and it will damage the paint, especially the weaker acrylics. The decal will now wrinkle a lot. Do not touch it as it is almost liquified at this point. Once it is dry it will have smoothed out and will lay down beautifully over just about any raised or recessed detail you care to think of. Used properly it is probably the best conforming decal process in the industry. Used incorrectly and you'll be just another guy complaining about crap Japanese decals. Looking at the reference pics, the numbers in red seem to be applied over the white, or a patch left behind. the tracks look great, are you going to abrade parts of the white for wear? cheers T 1 Link to comment Share on other sites More sharing options...
badger Posted July 17, 2020 Share Posted July 17, 2020 Fantastic white wash finish!! Really impressed with your build so far. All the best Ben 1 Link to comment Share on other sites More sharing options...
PlaStix Posted July 25, 2020 Author Share Posted July 25, 2020 On 13/07/2020 at 17:49, Corsairfoxfouruncle said: Beautiful work on the green camouflage and white distemper over that. Hi Dennis. Thank you for your comments. On 13/07/2020 at 21:42, modelling minion said: That, my friend, is fantastic. I really like the fact that you took the time to do the green paint justice before applying the white over the top of it. The way the white is stippled on is very effective and really does hide the thickness of the Tamiya decals, it never ceases to amaze me that a company that makes some of the best models going makes what are probably the thickest decals around too. This is going to look brilliant when all the parts come together. Sad news about the Victory Show being cancelled, but at least they are planning on holding it next year. Hi Craig. Hope you and yours are keeping well. Thank you for your comments and yes, shame Tamiya doesn't make more effort with their decals. Thank you for the information about the Victory Show. I hadn't heard. Yes it's good they are going to try and hold it next year. Probably will be better than under the current circumstances. On 15/07/2020 at 12:19, Troy Smith said: https://www.britmodeller.com/forums/index.php?/topic/235008098-dealing-with-thick-decals-ie-tamiya/&do=findComment&comment=2464801 Looking at the reference pics, the numbers in red seem to be applied over the white, or a patch left behind. the tracks look great, are you going to abrade parts of the white for wear? cheers T Hi Troy. Hope you are well. Thank you, as always, for the effort you put into trying to assist. Very interesting stuff from Gary C. Will have to try that in future. Hopefully you can see the progress I have made below. On 17/07/2020 at 17:40, badger said: Fantastic white wash finish!! Really impressed with your build so far. All the best Ben Hi Ben. Thank you very much for your comments. I have been working on this over the past couple of weeks but not had chance to post any updates. First I got more weathering applied - various streaks of various thinned paints: Some of the smaller parts that need to be added have been painted and weathered in the same way: Then I added some thinned Humbrol Dark Earth and Desert Yellow using a stippling brush. Over this I applied some Vallejo European Thick Mud product using a cocktail stick: Then it all seemed to come together quite quickly. I got all the remaining parts attached and some final bits of weathering done: Next up I need to work on the base and possibly a figure or two. I have to admit I'm scaling back on the scenic aspect of this project otherwise I'm not going to get this and my other GB builds finished in time. I have already decided to use a smaller picture frame than I had planned. Comments and suggestions welcome. Kind regards, Stix 9 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted July 25, 2020 Share Posted July 25, 2020 🤯... The only two sets of words that ever come to mind when I see your work Stix. “Properly Blown Mind” & “ Why in the heck do I have/need three airbrushes ?” 1 2 Link to comment Share on other sites More sharing options...
modelling minion Posted July 25, 2020 Share Posted July 25, 2020 I absolutely love it. That has to be one of the best winter finishes that I have ever seen, the spattered up mud and snow really do look very realistic indeed. Even on a smaller base (I know how over committed you are as I'm in the same boat) this is going to be really impressive mate. 1 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted July 26, 2020 Share Posted July 26, 2020 Hi Stix, That's an incredibly realistic finish you've achieved with this one 😲 Looks like you'd get frostbite handling it! Excellent work. Cheers Greg 1 Link to comment Share on other sites More sharing options...
PlaStix Posted July 27, 2020 Author Share Posted July 27, 2020 On 25/07/2020 at 15:53, Corsairfoxfouruncle said: 🤯... The only two sets of words that ever come to mind when I see your work Stix. “Properly Blown Mind” & “ Why in the heck do I have/need three airbrushes ?” Hi Dennis. Hope you are well. Your post did make me smile!! So thank you! And thank you for your way too kind comments too. If I had somewhere to use one I'd probably have an airbrush or two..................maybe.........I do quite enjoy brush painting. It's mostly pretty theraputic!! On 25/07/2020 at 19:46, modelling minion said: I absolutely love it. That has to be one of the best winter finishes that I have ever seen, the spattered up mud and snow really do look very realistic indeed. Even on a smaller base (I know how over committed you are as I'm in the same boat) this is going to be really impressive mate. Hi Craig. Hope you and yours are well. Thank you for your comments. I do know you are always busy with a lot of builds on the go. You mentioned a none GB build in your reply in another thread? On 26/07/2020 at 09:42, GREG DESTEC said: Hi Stix, That's an incredibly realistic finish you've achieved with this one 😲 Looks like you'd get frostbite handling it! Excellent work. Cheers Greg Hi Greg. Hope you are well and thank you very much for your comments too. I have done a bit more on this project over the weekend but didn't get as much time on it as I thought I might. First I cut out and sanded some MDF to fit on top of the smaller picture frame I am going to use now: I also started work on a figure from Tamiya's Russian tank crew set - assembled and given a base coat of thinned Revell's Anthracite: Then I got him painted - using thinned Humbrol, Revell, Vallejo and Citadel paints: A few photos of him in place: I used some cheap mounting board card to build up some areas of the base: And finally I got some filler applied: More on the base next. Comments and suggestiomns welcome. Kind regards, Stix 7 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted July 27, 2020 Share Posted July 27, 2020 Shaping up nicely Stix, Are you adding tank riders or figures on the ground? Also what filler did you use for the base? Cheers Greg 1 Link to comment Share on other sites More sharing options...
Hewy Posted July 27, 2020 Share Posted July 27, 2020 An incredibly good job stix what a weathering job👍👍 1 Link to comment Share on other sites More sharing options...
modelling minion Posted July 27, 2020 Share Posted July 27, 2020 Very nice Stix. The base is taking shape very nicely and the tank commander adds further interest to the build, although in the pics of him before he was fitted in place he does look like he's suffering from a terrible bout of diarrhoea and has raised his hand to ask permission to go and relieve himself, probably too much borscht. 7 hours ago, PlaStix said: You mentioned a none GB build Indeed. I have just finished it, a 1/48 Monogram NA-37B Dragonfly used for testing at Edwards AFB. When I post some pics I will let you know. 1 1 Link to comment Share on other sites More sharing options...
modelling minion Posted July 28, 2020 Share Posted July 28, 2020 As promised Stix here is a link to my A-37, Sorry for the thread hijack, please resume your tanky goodness. 1 Link to comment Share on other sites More sharing options...
