Graeme H Posted May 28, 2020 Posted May 28, 2020 OK, a slow start to this one, which ensures I will end up in a stressed and panicked state near the end. I started with some basic work about a week after the start of this GB, and been doing little bits here and there, but now into it sort of full time so the box shot plan is a basic OOB build as Post takes too long to get anything else anyway the tub removed and painted these single type GB's don't allow much time for mucking about, so need to get stuck in 8
Col. Posted May 28, 2020 Posted May 28, 2020 Welcome to the GB Graeme. You look to be off for a fine start already
Graeme H Posted June 1, 2020 Author Posted June 1, 2020 OK, got done with Part 8 and page 1 of the instructions, here is the cockpit installed in one half and some nose weight superglued in I have started on the wings and all that entails, with a lot of different painting done Why is it that Airfix have chosen to just give paint numbers and no translation anywhere as to what they are, downside for me is no one stocks Humbrol in my town anymore so have to rely on translating from their paint chart. I painted around the Undercarriage bay, to make less masking later on, should just be able to put on the maingear doors as a masking medium, won't need to go right up to them anyway, or that's the plan The exhausts are visible in the bay, and they are painted Alclad Semi Matte Aluminium, one side is a bit duller than the other, but this is an in service aircraft anyway. OK, time to turn the page on the instructions. 3
Graeme H Posted June 3, 2020 Author Posted June 3, 2020 Well, one needs to be very careful looking at the pictorial instructions, I glued the main cross brace the wrong side of the mouldings on the lower half giving me a really big gap between the back of the engines and the tailpipes so using Tamiya extra thin to soften it up, got it off and on the other side After a lot of cussing and scraping got a reasonable join, I think if I ever did this kit again, I would mount the tailpipes to the rear cross member and then put the whole lot in in one go, or even build it all as a sub assembly and mount up complete. So after messing about, back on track I hope 8
Col. Posted June 3, 2020 Posted June 3, 2020 Good save getting this one back on track Graeme and hopefully no further fit issues will arise from here forward.
CliffB Posted June 5, 2020 Posted June 5, 2020 Getting this one together seems to be an intellectual, as well as a practical, challenge Graeme! It's looking good though and hopefully things will now become more straightforward. Cheers
Graeme H Posted June 8, 2020 Author Posted June 8, 2020 OK, got the upper and lower centre fuselage halves together Built up the back end and stuck it on also starting to look like an aircraft now 7
Graeme H Posted June 11, 2020 Author Posted June 11, 2020 Getting more done, firstly I managed to get off most of those extra plates that Mark @Harry Lime tells us are not on the early Buccs so last night I started thinning out the tailpipes, only one done so far, I just use a blade going slowly around in circles, also started to drill out the holes in the airbrake Got the nose on, still needs blending in at this stage, sort of wanted to twist very slightly, so used superglue to hold it on you can see the airbrake is now fully vented, so ready to build up now. 10
Jabba Posted June 11, 2020 Posted June 11, 2020 Looking very much Buccaneer shaped now. The extra work on the air brakes and engines make the parts look so much better and realistic.
Col. Posted June 15, 2020 Posted June 15, 2020 Coming together well and the extra attention to those small details will make a big difference
P-3s rule Posted June 16, 2020 Posted June 16, 2020 Keep up the great work Graeme. And I hear that you have a roden early he 111 ready to build in parallel as a form of stress relief!? Lol 1
Cookenbacher Posted June 17, 2020 Posted June 17, 2020 Very nice Graeme, this looks like a complex kit, but you're making it look worth the effort.
Graeme H Posted June 21, 2020 Author Posted June 21, 2020 Slow progress Very poor photo of the wheel wells, I'm happy with how they turned out, which is all that matters really The wing and tailplanes sprayed black in preparation for the Stainless or whatever Now one big question is the wingtips are moulded in clear, assuming that's for the nav lights, but Airfix don't mention anywhere which bit are the nav lights anyone with any clue, can't find anything on walkarounds at all. 7
Harry Lime Posted June 21, 2020 Posted June 21, 2020 5 hours ago, Graeme H said: Now one big question is the wingtips are moulded in clear, assuming that's for the nav lights, but Airfix don't mention anywhere which bit are the nav lights anyone with any clue, can't find anything on walkarounds at all. The nav lights are the tiny sections at the forward edge. Some builders have assumed that being such a large piece, the nav lights are the middle section but this is incorrect. The two rectangle shapes towards the rear should be a very pale grey colour with the small raised bit inside them in black. Mark. 1 1
Graeme H Posted June 21, 2020 Author Posted June 21, 2020 10 hours ago, Harry Lime said: The nav lights are the tiny sections at the forward edge. Some builders have assumed that being such a large piece, the nav lights are the middle section but this is incorrect. The two rectangle shapes towards the rear should be a very pale grey colour with the small raised bit inside them in black. Mark. Thanks so much for that, really helpful 1
Graeme H Posted July 20, 2020 Author Posted July 20, 2020 Wow nearly a month has slipped by since my last post on this, have been doing bits here and there, but progress is very slow, getting there I hope So this afternoon I put some Extra Dark Sea Grey on the underside, will let that dry before I do the top, these single colour schemes are OK, but I really needed something to hold it, but no time to make it with time running out on this GB, seems to happen to me a lot c'est la vie I had planned on using the tanks, but read on someone else's post they are for the very early Buccs, so not appropriate for the later Ark Royal one I want, all to do with the fairing from the tank to the wing and after having it pointed out, I can see it so clearly, oh bugger, 😩 This is just a first coat, will need another coat in places. 4
Graeme H Posted July 26, 2020 Author Posted July 26, 2020 Well things are not going well painting wise, I applied a coat of Xtracolor over the Humbrol, to gloss it up and one of them was a very bad finish, so having to sand all of it down to start again, otherwise it will be a paint strip, not keen on that as it will take too long, and we only have week left Photos where I have done most of the sanding down, I lost the front pitot, so need to scratchbuild a new one of those planning on painting it with the Humbrol and putting a gloss coat over that, lets see how we go better get back to it 1 3
nimrod54 Posted July 26, 2020 Posted July 26, 2020 Sorry to read about your paint woes Graeme, but keep plugging away bud, I'm sure you will get it sorted.
Jabba Posted July 27, 2020 Posted July 27, 2020 Sorry to read about the paint problem, hopefully all will go better next time around.
Graeme H Posted July 27, 2020 Author Posted July 27, 2020 well going on with the paint job, I found I had an old tin of Compucolor, marked as Extra Dark Sea Grey, so stirred that for about 20 minutes with my stirring machine, ended up smooth so sprayed it on last night just on the underside, to my horror it has a green cast, left it until this morning and digged out my British Aviation Colours chart, turns out there on that chart there is an Extra Dark Sea Green which it matches perfectly. Now it must be just me, but I have never heard of Extra Dark Sea Green, and what was it used on? see on the chart on the top line of colours So dug a bit deeper and found I had new bottle of Model Master FS36118, which all quote as Extra Dark Sea Grey, so good enough for me, sprayed beautifully, lovely smooth job, quite happy with it, it could be a touch light, I will put on some clear tomorrow. So where I'm at tonight It does look much lighter here than it really is as it's late in the afternoon and I flooded it with light from some LED Lamps 5
Col. Posted July 31, 2020 Posted July 31, 2020 Glad to see the paintwork issues are resolved now Graeme. Decals next?
