OK. Enough time has passed for me to have another go at this build.
y4mVksGQRFldsyDPQrCz1s1dcidK7ghqqYsGiJSz
Slowly going round and re-touching some of the chrome.
y4mYth0DzkiY7U6QKKPZvVPSeVXVyZwuVK3z3bt_
There were a few gaps in the chrome rubbing strip, I followed the advice to use a sharp blade to try and get a clean edge.
y4mHbe7ST0ShIP0p3AnJH4w8bVCpNS9tRgzbeWOT
Parts for the pop-up head lamps.
y4maNKsHaUYjbgrVRjpeKu9tBHYcth-NELf39jP1
Something not in the instructions but quite noticeable are the centre caps for the wheels that have a bright "H" inside a black surround.  The centre caps are painted satin black and then the recessed H was touched in using Molotow chrome applied with a sharpened cocktail stick.
A bit more work on this Prelude.
y4mQ0kaHK3SNSAMykyGiPOfcXiDXkpH9M1UmS3ei
I don't want to get too close with the cameara but I think I've managed to tidy up the window surrounds.  It looks better to the Mk1 eyeball than the unforgiving gaze of the digital camera.
y4mcMo8uALLI6vGljtzHrEn11zsKekt_z8fQlI6I
I've given the inside of the roof a quick covering of Tamiya Sky grey, not intending to go all the way to the edge but enough to suggest a headlining when you look through the windows.
y4mzqp_KlMTl9cYP5os0QxrMAm_I0bB3IbI9lbZp
A little work on the engine, painting the power steering pump.
y4mY-aKNxXMeuHasetG_5rMdq9-cM_otRS52QEXZ
Yes, it's a bit wonky but better than nothing.
y4msdPVGj8_3HXShX_nUa6Rj4J9CdgisEaREjNt3
Drive belt is a cut down strip of Tamiya masking tape, painted matt black (I should really get some NATO or Rubber Black as they are slightly more satisfying colours).
y4mAS3nUXiYAE_ti_8b2uO3Ao1z9ZcBCGmZKDK8h
I'd washed the clear parts in soapy water before painting the parts that needed it.  The glazing unit was left with spots from the soap, so I cleaned it using my preferred method for 1:1 car windows; a solution of vinegar and water.
y4mtxbtOlpzL1OWzMkisRu7L8oETGYcLNlp0dtfs
The instructions advise to paint the edge of the sun roof matt black, but I think the beading around the edge should be black, so it was masked and sprayed as that seemed easier than trying to brush paint.
Lots of work on the Prelude today.
y4m9iKwXNRDLPeRjj2kaMYWXf_FjQN4DOz9-vH4i
Putting the engine bay together.  It's a bit of a tight squeeze.
y4ml7Zbm59FoAa6pl38OwSEegno3wC77sy2ZtC6c
Interior doesn't look too bad.
y4mUk9vvlv0f2KVJ7bwuDG5jirdl6t1u-jtWV9KE
I'm glad I picked out the interior door handles in chrome; it's not in the instructions but was on all the photos of real cars.
y4mtgaz7ibTFmytqFTw1uhZsVq7Mn9hPAeRvwbvC
The reshaped seat bolsters look pretty tidy too.
y4m-kA1zGvVUrC_Shv2ZNgBbMgY9VvddhxA97kEN
Moving on to the tyres, there was a pretty horrendous mould ridge on each one.
y4mefHehuE4k1YdTwkVKyB4PI1PfA_NJLMu-tkrW
Much better after some attention with the sanding stick.
y4mR19FDvuGOXJb4sar-MzkKTHNYDagS0NG--tYR
Suspension and brakes are in place too.  Assembling the suspension, particularly at the front, was more tricky than on the Fujimi Prelude but the components are much more realistic.
y4mFsWmCMnABEwMpf7IxizumgAYa8X4xu-okks99
Putting the pop-up headlamps together.
y4mrZfaXHaWluaQJqiTDxakIOI9EcaSeM78SvlcN
You have to cut the headlamp covers away from the bonnet and then sandwich the cover and lamp body around some spigots moulded into the body and glue them together.  There isn't much to hold everything together or much of a mating surface for the glue.  I've used Gorilla superglue and I hope it holds.  I could live without pop-up lamps that actually work and did think about just gluing them in the down position.
I also trial fitted the front bumper, I'm still not sure how it seems to fit so well in Tamiya's photos of the assembled model, I'm not sure everything is going to line up correctly.  No photo, maybe tomorrow?
That engine bay is rather busy! Good work on it. I've also got a soft spot for the prelude as I had a mark IV in Brittany blue green. Lovely car and good fun to drive.
Nick
It seems a shame to have to go to the trouble of making those headlamp units only to display it in the down position. Fingers crossed that you have that mechanism working, but I have to say that you have a pretty good fit there - retracting headlamps seem to be a pain in my (admittedly limited) experience.
I remember them being trouble on the Tamiya Ferrari Testarossa, with the lamps connected by a flimsy plastic shaft so that they should pop up together.  The ones on the Tamiya Lamborghini could be posed open or closed but had no hinge as such.  I think they eventually fell out and got lost.
Right, time to push this forward as it's starting to feel like an albatross around my neck.
y4m6tBYgWit_LssHBCRlfCaqTDEnBoNJpoPz7rqL
Adding a bit more detail to the interior, representing the seat belts that attach to the B-pillar.  It should be two pieces of fabric but this should give roughly the right impression once assembled.
y4mlZ5YZwS5BNljHi-x7RysxpzE6G4Ubw9jvlpq-
Front bumper glued in place.  I've also had to re-glue one of the head lamps (again).  Tamiya must have got the work experience boy to design the front end of this kit.
y4mNyIE0wnXwbpSssLt0rVk1e3ydenE-LVDaFB6Q
Chrome trim added to the side marker lights.
It's coming together.
y4mb1aGpnKPQgDCc2ETqCLpwgjuMMlPKRq0iuf2g
Bumpers on, upper and lower body united with the interior in between.  Of course it put up a fight, the glass didn't want to attach to the body, the interior seemed reluctant to stick to the floor and it took a couple of goes to get the underside correctly seated in the body.
y4mTnysC0DxW9X7RsR-cOU-gmhlqc40iNhcZoqMm
I'm not sure how you'd get the bumper to line up without major surgery and I wouldn't dare try and get the headlamps to pop up but the engine bay doesn't look too bad.  I'm pleased with it as a first attempt at detailing an engine bay at least.  Oh and you can't tell that the indicator lens is moulded into the bumper; I'm pleased with how that turned out.
y4mZSVHiXG-O1SYzOAAUo8pBMB92AVk5xXDwk1Kq
Seatbelt doesn't look too bad either.
y4mhIgEAwxSAPU2vvVYoN1iG9KGwqYSvxTxMjohK
Wheels ready to go on.
Next steps; fit wheels, exhaust, tail lamps, mirrors, wipers and decals.  Nothing to it, really!
It's starting to look almost finished.
y4msFapS8DKC_0yLaMTP7oS-YpzxrqbiTVo3d_oC
Wheels and exhaust are on.
y4mIR8_P0Gt2JntJyHsgdgdY9FA8kgqBlWuB4CoQ
Windscreen wipers needed more paint where they were removed from the sprue.
y4mVL9Nfbo4Dex7i6BU4sdwGDByrKl-F2-etCqWi
Right way up with sidelights added.
y4mZhb2yUaOfrKa_BvBJbK0q1Pz8xig4HUcZoU91
Mirrors and wipers added.
y4mqNkzttshZBpAmzgOCheGXYh89YTOEM0wMVKPA
Rear lights are the one main piece that's missing, I've touched up the paint on the lights and there are a couple of decals to apply.
y4mA0jdONcla2_ffVkfRlLvqDmn-IQDDdTkXgVeC
I bought this detail kit for the Honda Civic Fiero mainly because it comes with plenty of Honda emblems.  I'll use one of the #14 ones for the boot lid as the moulded on one on the kit isn't very well defined.
Other than that, there are some decals for the boot lid and chrome trim for the side rubbing strips.  The instructions suggest this should be painted but I couldn't see it moulded, there's just a recess that's perfect to take some straight nickel silver wire.  It might be ready for inspection by the weekend.
Tail lamps and decals today.
y4mkpZJbbIFnsVp_SxUHC-2vYVSJle0mxWEWpspD
Trying to get the decals to sit straight and level is a challenge.  Every time I go to blot away the water I end up moving the decal.
y4mB_tBJt-v3eCHBeat3fCXPdoG8Hc6Q_UYcIqYu
Number plates sprayed gloss white, and left to dry over night to receive the licence plate decals in the morning.
y4mAA4huZmMeovYzdm893YN-g3LXbQtDf6Zl0ryX
Guess which idiot missed the bit in the instructions about painting the back of the tail lamps gloss black?
y4mgmcxE6MPo8UnI0gZpPHcstIgZkUcCgzglPZxg
Doesn't look too bad.
y4m9G6mSpSo8zejFXMVdZ7agrEo8FFAC7znIhfFD
Having the lights in place helps to bring everything together.
y4maefWaqyP5GqcOzZdTjdUx95qE56dic5-8UqLG
And more decals.
I'm looking forward to getting this finished.
Gets me every time! So frustrating!
This used to get me quite a bit too, particularly where there was a droplet of water and the decal was trying to sit on top. Eventually I worked out that touching the side of the droplet with a cloth (such as a duster) would wick the water away without the decal moving much, and if it does move it should still be easy enough to push back into position once the droplet has gone. If there is no droplet and the decal is sitting quite flat, I usually just let the water dry before touching it as the decal should settle down as the water evaporates.
Good job on the car by the way.
I think today was my last day working on the Honda.
y4m8vCke_0yqLHU3tGUZU8-ar0QjinqsksTuwf4T
First job was adding a photo-etched "H" badge to the boot in place of Tamiya's moulded item.  The moulded badge is still there because I didn't think of sanding it off before painting.  To be fair, that was fifteen years ago when I wasn't even aware that someone might do fine, etched metal Honda badges.  The H got a coat of chrome paint before it was glued to the body.
y4mqKfZBv1yMxeQMZxexN_PgKd24CPIljiE8RDZO
Number plates with the decals on.  It's a pity the carrier film over hangs the edge of the plate.
y4m7bDVjIKSdfIa_yhC8LtWhJj602ewk_Z9vlmI7
Plates cut away and the film trimmed with a sharp blade.
y4mwDGSvnP1cx3PMAxzxsm-FcDm-C0W_fkNsMnrQ
A bit of black paint to the rescue.
y4mYiWWjrYCaEJ7YHhG3T5i0lPgzcREmv9aHuk52
Rear plate in place.
y4mBxYeptLLK6X2RgNTnfS7dWZ_QFeztQm2ufttC
Before putting the front plate on I remembered that something was missing from the sides...
y4mfXIxzHyudFK05gXl9d5rrk-ocFGszyb9lmhgC
I cut pieces of straight nickel silver wire that fitted neatly into the recesses in the side rubbing strip.  Much easier than trying to get a tidy line of paint.
y4m5WwxEgZaFKMr8Q26YBXiHswVKP524CxR3VniY
Door piece done.
y4mhXufDC5RhlIMzEoo4N_q8TSiCPQOgN7U28Qu_
If only all chrome trim were this easy.
y4mQJcfpZjLJ3p6jTjy-k5paJuL9iOHlmFu28iuk
Other side done.
y4mKMtbLRLiVUh253JPOtZBCzf4Lv79NRNzVi1mR
Front number plate on.
y4mxrBD6cFiv-IbgQDeVdeVoVGP6aijteGopRU_F
I'll do some proper, pretty photos tomorrow; but here's a quick "walkaround".
y4myNVFIbHm5afPtOYUoU3XXiyR0Lcaf38oqiFOv
y4mG8wtVw7pskD2K1mMLQjAa6d6CWeauePg2TelU
y4m6ngaupqoJIHkK4zg1XiY8EHqW15yymfgyXJeh
y4moZPOS_bkQ4cmTKBdPeqyiRcR-cxdQ3-EXJVvX
This build has been a battle at times but the finished result isn't too bad.
Very nice model, John. well done!
Nice result every inch a Prelude
     Roger
Very nice model.
This was a lovely car, I drove an Acura Prelude from Memphis to Boston back in the day, “Driveaway” relocation for a finance company.  It was fully loaded, but manual so had hung around for a while in Tn.  “Driveaway” said they were always pleased to use Brits for relocation as they were trained to a consistent standard (as opposed to different per state), and never phased by things like manuals or left-hand drive.  My first introduction to Japanese cars, took me a few years till I actually owned one myself...
Hi John,
Where did you get the photo-etched emblem?
Alan.
54 minutes ago, Alan R said:
Hi John,
Alan.
Hi Alan,
It came from Hiroby as part of the Honda Civic Ferio detail set.
John.
Hi John,
Thanks for the info.
Lots of emblems on there!
I might just get this for my dual NSX build (When I eventually get around to it ... :))
Alan.
