This has been sitting in an unfinished state for many years since I messed up the paint on the body.
y4mVOmW2BY1AY83rSynDK_eEDLhIjzg49xV8kbu0
I chose yellow for the body and picked up a can of Humbrol enamel spray from the model shop when I bought the kit.  Unfortunately it went on so thick that it looked like I'd used household gloss paint.  At least I can check out paint stripping on the sprue before attacking the main body.
y4mchkulVQ9aevVvXo6g0YAcz2AN1iiBgH0R5Y5Z
In the past I've tried sanding back and respraying but it probably needs stripping back to the plastic.
y4mCB9dpOg6CEghsqgbDtZgyPaEJdewPI4fbDpZB
There is also a crack in the windscreen pillar, I hope I can glue and fill it so that you can't see the join (the photo hides it pretty well).y4mwg_EnQhcK2Epi9OeBug4toUZU9g0HsW7Favhu
I like the clear plastic undertray that allows some of the suspension and engine detail to be seen.  Pity about the glue and finger print.  Maybe a bit of sanding will save things, I might just try and use some satin black to paint over the marks while leaving at least half the tray clear.
y4mZFJcAhcY6VvXrqK3a1YHwJRKfoqmJGsWLh64u
Onto the more positive stuff; I'm really pleased with the front and rear screens, the frames were probably painted in Tamiya X11 or Humbrol Silver.
y4mE9tb5d0Qwk37icYysA3hmPBLgV_uDHamIWCcN
The rest of the build is pretty much complete.
y4mZd0QfwOCKjTB4tulTpweZZM0C1vh_Oam4_FdH
y4mM0-bIVoiANkgg1B7SDzfynvlgl9a55_hP86lD
y4mVjtAehgV2VjjbxFdVCEJiycd5SGXKJXAAypkv
y4mDgDeJACspgYL5nNulRiAfyJF14dMTwDyBEigC
It looks like most of the other parts are painted, if I can just get the body done to an acceptable standard then it should be an easy job to finish as the kit seems to go together really nicely (typical Tamiya quality).
y4mRdhoRxSmWDcANOsC4Preg6Naarzc3XsMS8LXn
I'd strip the body down completely, it'll be worth the work.
Here's some encouragement (Friday car meet, Le Mans 2009)
645
640
Thanks for those pictures, I don't always strive for 100% accuracy with the colour choices for my cars, but I do prefer them to be plausible.  You have also gifted me some nice reference pictures for doing the body details.
Incidentally, any idea what the beige coupé is in the first picture (the car just to the top right of the Alpine)?  I'd guess it's a Ford Taunus of some description, it's certainly not something I recognise.
Those are my most favourite "wish I had the money for one" cars, ever since seeing a works one hurtling through a Scottish forest, round an uphill hairpin near on backwards way back then.
I've got both kits, the road one and the Monte version with the proper 6 spoke wheels. I stopped work on the road one ages ago as the wheels are wrong; wrong pattern, even for a standard car, and moulded with 4 studs - Alpines only have three.
I did wonder about the wheels, given the French penchant for attaching wheels with only three studs.
I'm happy to say you can continue the work on the road car as far as the wheels are concerned. The wheels in the Tamiya road version are perfectly correct for the 1600SC the kit depicts, both in shape and being 4-studs. Beginning with the A110 1600SC/SI introduced in 1974 the rear suspension changed to a double wishbone, close to the newer A310 1600 rear suspension, and 4-stud wheels where therefore also introduced. The 1300 model retained the older style rear suspension and 3-stud wheels.
Works rally/race 1600/1800 cars of the same years differ from this and must be studied as individuals.
The problem for Tamiya begins with the rally version they released; A 1600S, where they have supplied the correct 6-spoke 3-stud wheels for that car, but still kept the newer rear suspension that is all wrong for a 1600S.
Cue the well-known music, I'm stripping; paint of the Alpine, that is!
There's something lurking in this ice cream tub full of Dettol.
y4mLK7v8WVMX8s-l8rzNdvcDak5-_CDJOC-INt2B
Most of the top coat came off after a lot of minutes and some scrubbing with an old toothbrush.
y4mywDOQnP4bRuOc2RnLYPhSq8nLUrTiCYvpltRa
After many more minutes, that old enamel was really caked on:
y4m2CTymLpAm-IPbbUtPGY_SLjEwHa7QpEUaCqS3
Most of the white primer has gone now, only yellow enamel to go.
y4mJbRpxXehz1ZA0e2HGoTeEQTPJXtIFOaorPWoi
It's still soaking as I type this.  I started at about 10 or 11 this morning, so it's had about four hours!
The Dettol eventually seemed to run out of "oomph" but it's done a pretty good job.  I'll need to get some more and give it one last long soak to get the stubborn remaining paint off.
y4mzguwdSDInPEy-q-WFhBSfK6mAXPI4Vi9kWYlY
An old (or cheap) toothbrush can often help with dislodging those stubborn bits of paint in panel lines, corners etc. I've found. It hopefully goes without saying that this will be in conjunction with the soaking in paint stripping fluid or some description, and ultimately you will still need a good soak to soften it anyway.
Yes, that's what I did.  Soak for a long time, then scrub and back in for another soak.  I'm glad I always keep an old toothbrush or two.  Another soak and more scrubbing and I think it will be pretty much as good as new.  It's quite satisfying to see a "ruined" model start to look like something that might turn out fairly presentable.
Hi all :)
Brake fluid is also highly effective to strip the paint, but rather dangerous
Now, I use a product  named "Glanzer",  very rich in ammonia, but infinitely less toxic.
You can find it in UK
Some success to celebrate.  Hours of soaking and scrubbing have finally removed all the old paint.
y4mbf0GKLUivNDKqyipRIAf7JDP_URb3Tggl8woJ
Some parts of the body have lost the gloss but I don't think it should be a problem once primed and painted properly.
y4mPPepziEus6O4nCnJkN7UCTRQQiUfSZi4VIPcg
y4m5jqleo8Vv0_iQ5DURnzwUvQKTkkT2fTEV6uGF
There are a couple of little bits of flash on the rear screen pillars that I'll sand down.
y4mV70Du2sGrDg7Ao-fSiKVYMlwp5OQYKJOSki0D
I've removed the chrome from the plated parts.
y4mXpleJVCVBxM9fnc-1ankmuktPf2BLnucSmFcv
The clear under-tray came off quite cleanly, let's see if I can tidy it up and put it back.  If all else fails it'll get a coat of satin black.
y4mYr1iQeeUvrDhNqZ0LyW8YNd6xvPWy-Mys6-ZI
Current thoughts:
Do I attach parts of the body like the air intakes before painting?  Probably.
What to do with the engine cover? Glue it on or try to make it removable?
Removable, of course, and articulated too 🙏
Edited by Mike
Removing quote from previous post - please reply from the bottom of the page, rather than quoting people if you're the next contributor.
Engine is quite nicely detailed, so visibility is well worth while.
OK. I've never done anything like that before.
Thanks.  I may need some advice on how to make it open.
Good point! Haven't got to that stage in mine yet, but the instructions seem to indicate that you just sit it in place, not cemented. Hinging it would be a real plus, but a bit of scratching required - both of head and building!
Just call it a key for the primer ;)
Current thoughts:
Do I attach parts of the body like the air intakes before painting?  Probably. I think you'll get different opinions on this, so go with what feels right to you. For what it's worth, if it's a part which is separate on the real car I tend to attach after painting, and if it doesn't look like a different part on the real thing I'll attach prior to painting.
This one has cleaned up really nicely, it'll be good to see how you go with it.
Good save with the paint job 😁
This is one kit I will get and build at some point as it's such a beautiful looking car, keep up the good progress
Ian 😁
Decided to do a little to the Alpine, there are a couple of mould seams on the body, they're only faint but I might as well try and smooth them off.
y4m18LlV0zGGlOtZcAJqmPxVBSXf3hLZsTjrO2Lv
y4m5OyIBBPsz2z2hYjJvfOBmcdzDqRbvCggGGto_
I also had a think about the rear air intakes, I think getting them to fit after painting would be risky so I've decided to fit them before painting.
y4mNz9arYxh2Ys9WXqaW54QtwTLTE6V9ZXgl3hv5
First dry fit.
y4m_Zl2t-gZi_K73j4YLwaN9gtWhumVTSNOAUMJH
Careful filing with a sanding stick is necessary to get a good fit.
y4mYb1c1YtIcenGOgBQcPerezrlagWhy5QK8WE3W
3 hours ago, Bengalensis said:
Progressing nicely now 👍
Seconded!
Stay safe     Roger
One step forward, two steps back.
I did a test fitting of the body to the chassis - I'm glad I did but the result wasn't pretty.
y4mzdJMJDLSS2eotz_cq_igtXNPGRWv_VkLMNPWT
The engine cover doesn't fit
y4mIV7BsDkkMxA5Yn0wucWD-DNpJHwnYa0Z_ODdA
The floor doesn't sit flush with the door sills, causing the backbone chassis (which wasn't very well glued to the floor) to come away.
y4mnpLtcI36YfZeGO2oBSnnyuV4ecc4VYpPXme6_
One nice thing is that the body fits round the interior with no nasty gaps but something isn't quite right with the dashboard.
y4mw1YoHh9VPq57YZRWseiXGTgVrqQrf7Y_KTHp9
It looks a bit wonky.
y4m7KOA1mr_W9u-twrA3SlchS5BjJ00LLFqlFRtL
Not much but compare this side of the dashboard...
y4mW-gtmXtrw3yHWDNEM7DwD5aYF6tZhgivf2ooI
...and this time, only a little out but enough to throw out the body alignment.
y4mF_DxfZKuAyHjsdTtfEhS3BypsIu2Gytgk5TLO
Thankfully it didn't take too much to take the interior apart.
y4mMGGM32_Hj668i8zlJfGs98e2mSc32tgHDvA3D
A little damage to the dashboard but it shouldn't notice when back together.
y4mXqNT-6ZqOWxaaqd-r6qxNDNinGqXVCtbNGwL4
I'm still quite pleased with how the dashboard turned out.  It's almost a pity it won't really be visible in the finished car.
With the interior removed I tried the body again and perfect fit.
y4mI3JnljV3oVq568XCmeKRKexeFdfjxCarelcHh
Engine cover fits better too, I'm glad I didn't resort to any more drastic measures.
y4mAohUoqFt3yeEtFOoVfw-oRQSZZxuIEAsQKDWs
Better fit underneath too.
y4mY4ex3L17m26gtBKM2o3kltPEV7GQIHMNWcTmK
Next step is to clean up the mating surfaces and refit the dashboard.
You have the basis for a very smart looking little car there. Take your time preparing the body, it should pay off!
I'd never notices until I saw this pic, but the A110 makes a pretty little car without the bubble-rear window, definitely shades of the original Lotus Elan although with a longer rear deck in this photo.
Good work on sorting out the fit issues, it's always a nervewracking moment when you fit the body so that was a very foresighted move testing and fixing now rather than when everything is in place :thumbsup:
