Fujimi 1/72 Spitfire XIVe Grp Capt ''Johnny'' Johnson Soltau Germany April/May 1945
TEMPESTMK5
Good evening
For this Gb I have started today a Fujimi Spitfire XIV I will try to represent the aircraft flown  by the Group Captain ''Johnny'' Johnson
https://en.wikipedia.org/wiki/Johnnie_Johnson_(RAF_officer)
based at Soltau Germany in April/May 1945
Some book
The box art kit
The sprues
I will use the decals of the Freightdogmodels Spit kit
I will use an Eduard set to detail the cockpit , it is designed for the Italeri Spit IX kit but under  the closed canopy I think that will be Ok ..
I will use an instrument panel from an Eduard kit  that I have finished for the Spitfire GB
I started to place the sidewalls PE Parts
Patrice
Good choice Patrice, I remember Johnnie Johnson writing about this time in Wing Leader, still a good read (in fact I think I'll dig it out to read post studies).
I've got the Fujimi and Sword kits in the stash too :hmmm:
Welcome and good luck.
Good afternoon Wez
 I discovered this great pilot many years ago thanks to a documentary on the history of aviation where he spoke of his experience as a fighter pilot at the controls of a Spitfire.
https://www.youtube.com/watch?v=RFHmr3w1R1E
Best Regards
Patrice
Hello
  I found in my spare box  a few pieces of a Italeri Spit (a seat and its support, a ''floor'' ) yesterday after some dry fitting tests in the fuselage and a "bit" of sanding here and there  I painted everything , I glued the Eduard belts on the seat and this morning I placed  these parts as well as the instrument panel in the left half fuselage .. well I am quite sure that this does not conform to the real cockpit of a Mk XIV but I think that once the canopy will be glued in place it will do the trick ..
Patrice
Good evening
 This afternoon I closed the 2 fuselage halves ,  I placed the engine cowling and ''spine''
I also glued the upper and lower wings and placed the wingtips  ..
Patrice
Looking good so far Patrice. I personally like the look of the Griffon engined Spits compared to the Merlin types, but they are all beautiful to the eye... except maybe the extended wing ones 😕
:goodjob:
Davey
Good evening
This week end I painted the upper surfaces in Dark Green HU 116 , the wing leading edges in yellow and the position lights on the wing tips
Patrice
On 17/06/2020 at 02:56, stevehnz said:
Easy to see the end of this build approaching Patrice. It has appeared to go together nicely & I can see the end result will look terrific. :)
Steve.
Good morning Steve
 Thank you for your comment I will do my best ..
But we really need a good Spit Mk XIV in 1/72 Scale ...
Best Regards
Patrice
Good evening
During the week end I made a light weathering , I placed the exhausts , the landing gear , the propeller , the rear view mirror , the whip antenna
Patrice
Nice work Patrice
I never get around to doing it myself but models always look much better when set in a diarama as you’ve done here.
James
