7 hours ago, Flyingdutchman said:
Great work on this ancient kit. The Gina is a nice plane but not easy to build. You were able to touch the colours perfect! Looks very promising.
Thank you Evert, I am glad you find the colors appropriate.
6 hours ago, Giorgio N said:
Considering that the usual gloss coat before decals and matt/satin final coat will very likely tone down the effect, I would probably leave it as is. In Italian service at least, the paint on these aircraft weathered quite a lot, the dark green in particular
Thank you Giorgio. You are right about the effect of the gloss coat. Probably, I will touch up only few over-sprays and fill-in few spots that are really too discolored. I saw also pictures where the paints were quite discolored.
Dan
Meanwhile, I worked on the landing gear parts. These are the parts out of the kit:
p?i=1f6772374b8c4a88985656af6992837a
The struts are clearly undersized and I wonder what are of all those rings meant to reproduce. Considering that these parts are not adequate, after cleaning I replaced the struts with plastic rods and metallic tubing. The new parts are then pinned together. The front gear received few additional parts and the oleo was replaced with a metallic tube. Then, I furnished the assemblies with aluminium tape and lead wires.
p?i=5a5c6fd8f6a3dbae4c746e5b86e1372d
Finally, after priming and painting, they look closer to the real pieces:
p?i=9e9e46925f00fee5d097e0bf0cc3bd9e
That's all for now,
best regards,
Dan
Hi,
just a small update, I added some green color to the areas that looked too discolored keeping a mottle pattern. I think it looks better now.
p?i=dbf69f9f74bbfb0d869922eda1fa4f7a
I also added the anti-glare panel on the nose and a black dielectric on the tip of the rudder.
p?i=1f79883f0327016f3205a0d2cbd474db
p?i=cb63b7916a5bf5f66a35080406ef1ac5
Now I have to mask the upper part prior to spraying the aluminium paint on the lower part. It starts to look like a proper G-91.
Dan
6 hours ago, Dstream said:
Hi,
just a small update, I added some green Now I have to mask the upper part prior to spraying the aluminium paint on the lower part. It starts to look like a proper G-91.
Dan
The camo looks great, Dan!!
Just one thing...The belly of the German G.91 were not RAL 9006 Weißaluminium, but RAL 7001 Silbergrau...which is a grey color shade.
@coneheadff, thank you for following my {endless) build and providing comments, it is really appreciated. I really hope that you will not be disappointed, but my intention is to build an Italian version, for which, I have already installed the four guns. The German version is very spectacular, but I will do it when a new tool will be available. My choice is due to the fact that my memories (related to aviation) as a kid are associated to this plane. In addition, I started working as a young engineer more than 37 years ago in the factory in Turin where these planes where build. At that time it was called Aeritalia, not Fiat anymore, G. Gabrielli was already retired, but documents of the plane were still around.
Kindest regards,
Daniele
Kindest regards,
Daniele
Aaaaaah...that explains the details and the amount of time you're putting into that project 😁
Absolutely fantastic work, Daniele!
I grew up in West-Berlin, so I only know the Gina from a books and museums 😪
There's a privately owned G.91 not far from our place. The owner bought it a long time ago when the German Air Force still sold retired equipment as a whole assy. Nowadays they chop everything in pieces...even uniforms 🤬
Back to the Gina...our air force also had the Gina with four cannons. It was called G.91R.4.
These aircraft were supposed to be delivered to Turkey and Greece, but ended up with the GAF. They all flew with WaSLw 50 in Fürstenfeldbruck.
40 of them were sold to Portugal and were probably the only Gina's used in action in Angola.
Alex
Wow ! I'm loving the attention to detail that you are putting into this model. It brings back happy memories of watching Luftwaffe G-91's when on our 17 Squadron  annual detachments to Decimomannu in the early 70's, and also watching a flight of Luftwaffe G-91's engaged in a simulated airfield attack at our base in Brüggen during a NATO exercise . . . Very impressive !
I've always loved the " Gina " and and your model certainly does justice to this iconic little fighter.. Keep up the good work 😃:cheers:
Time to mask the upper side in preparation of spraying the Aluminium paint on the lower side.
p?i=672cfe8018b68590623596f1cdabcf66
For the Aluminium paint, I used a mix of Tamiya Flat Aluminium XF-16 with 20% Flat White. I know that the Tamiya Aluminium might be a bit grainy, but I think that this mix reproduces well the real paint.
p?i=e764d53f348c8a7befdb3a7270a098a3
The result seems not too bad.
p?i=9e2451f30c6aa90a0b7dff9dab50bb60
p?i=448031c76cd0995e462278b90b05a7d7
That's all for now, next, I will be busy with the many spots that need a touch up.
Best regards,
Dan
  • 3 weeks later...
Hi,
just few pictures to update my build, work is progressing slowly, but it is progressing. Tackling all the remaining bit and pieces that were left behind. Starting with the drop tanks, here shown OOB:
p?i=bab1081d9224945de8237f5034df7409
That heavy superstructures need to go. I noticed that the Italian tanks are slightly different from the German ones. This is how they look now:
p?i=75a6ff6d7c202610f2a56885000ff1d5
I am hesitating to better detail the attachment points, I will see what to do later. I have rebuilt the large dorsal navigation light that was molded into the plastic halves and that I promptly removed because it was ugly and it was in the way when I had to sand and scribe the fuselage. This is the new piece turned from a clear plastic runner:
p?i=3c3cd949ff283c70546c041cde7c8e7f
Here how it looks with the tanks dry fitted:
p?i=21eedec4cdc13a9084fad1b291138d60
I am continuing with the various landing gear doors, that's all foe now,
best regards,
Dan
Hi,
I decorated the fin with a white band and started to paint the remaining pieces.
p?i=802928f4ef25abca844a6511e633ea76
I added the small tail wheel which was removed at the time when I rebuilt the tail cone. I fitted also the jet pipe to get the overall impression of the rebuilt exhaust area.
p?i=713a7106cae9f26489453d1f62c11b36
The grey cylinder is the original jet pipe of the kit which is much smaller than the one built by me. Finally, I sprayed a coat of Tamiya clear in preparation for the decals.
p?i=4fa0a13254459a0cffb405a3b447a109
Decals will follow. I hope you like it,
best regards,
Dan
Thanks for the likes gents. I went on with the decals. The large sheet provided plenty of decals of good quality. However, I found that many of the service stencils are a tad out of scale, i.e. a bit too large and I ended up by omitting many of them because I found that they disrupted the overall view of the model.
p?i=b868e82d31c414ff2daa96d50ea222d6
The national insignias have the central green circle a tad too small, but I have to live with that.
p?i=d0011b832081a9dcb528125649773ceb
In this picture, I try to show the stressed skin effect that I tried to create on the gun lids, which, although difficult to see in the picture, look quite effective in reality.
p?i=f62bfd1e16c13b5354f2b389600c36d0
The underside was completed with few oil trails made with brushed oil colors.
p?i=9347d353d76fe5c97fc957fc7e9f6285
Next, I will wet sand everything and apply a final satin coat. I am thinking to add a drop of grey to mute a bit the vivid colors of the decals.
To the next time, thanks for following,
D.
Hi, before spraying the last finishing coat, I am proceeding with the last remaining bits. I glued in place the landing gears that were greatly modified as shown in a previous post:
p?i=7d272ea51b16fb9fd33b7c6b547c744b
The work done on the landing gear elements paid off and these are quite more presentable now. Wheels of the kit were painted and finally added after having flattened a bit the are in contact with ground.
p?i=6948911971e6e3e21aa245639fc9e1d6
The mechanism for the extension of the airbrakes was built out of plastic stocks trying to imitate roughly the real one.
p?i=a3a501f56e39e6332e9f66cfc1dcdc45
Airbrakes and leverages added, but still not painted yet. It is really a pity that the shape of the airbrakes is not accurate, but at any rate, the overall impression seems not too bad.
p?i=180207dea34ac20f8775cc9b67566df2
Continuing with the last bits that usually require a great amount of time.
Dan
Hi, thanks to @coneheadff and @Biggles87 for your kind messages and thanks to the 'like's. I went on with the last bits and pieces and I am mostly done with the main airframe. I attached all the landing gear doors by now:
p?i=c1fb2d06cbe7c9bf40834b16a48f2cb2
The underwing tanks:
p?i=e8957358234bf4937816376365001dc6
The pitot tube made of brass microtubes:
p?i=79d46f01a8ee9e070c9ba04d9347bd4b
Now I am ready for a transparent coat which will be matt, but with a bit of a shine. I need to mix some clear/matt types. Another view with the landing doors:
p?i=63c1d93ccfcd407c44706d22d9da0501
Meanwhile, I am also finishing the ejection seat which will be the last addition.
Best regards,
Dan
I assembled the final missing bits and sprayed the final coats of matt/satin finish and removed the masking tape from the transparent parts of the cockpit.
The jet pipe and the tail lights:
p?i=a9ed96a2d11817cd0b3a8e01eed7a0a3
The ejection seat:
p?i=fc497cb1052885754a11cf64b9c4f22c
The canopy hood:
p?i=2ec09984b5217641aa854ac1b4771822
ad the final overall view:
p?i=235a713117481ba93ebc2131e7d3b9d7
I am posting the final photos in the RFI section.
Thanks to those that have followed this long build, for sure I will stay away from old kits for a while.
Best regards,
Dan
15 minutes ago, PeteH1969 said:
When ever I see this period aircraft I always think of this?
It also happens to me!
Glad that you liked my build.
Dan
7 hours ago, Biggles87 said:
Wonderful!
I always think of the F-86D
Indeed, the G.91 indisputably resembles the shape of a Sabre F-86D. Before the G.91, Fiat built under license the F-86K for the Italian Air Force, therefore they were very familiar with the architecture of that jet.
Thank you, John for your kind comment and continuous support along my build.
Dan
1 hour ago, coneheadff said:
Fantastic result, Dan!!!
Congratulations...you made a little gem out of that basic kit
Thank you for your kind words and thanks for your continuous support. Indeed, I spent quite a lot of work on this old kit. Now, there is a high probability that a new tool will appear.
Dan
