  • 3 weeks later...
Hi all,
I went on with the work on the fuselage and I re-installed the rudder which I removed earlier to modify it. Only the trim tab is now missing.
p?i=0508aa03febf3ee1db8b7936ade4a0de
Here a close-up of the tail area with the rudder and the new scratch build ventral fin which includes the tail wheel fairing.
p?i=7672ff74616d1c467b92c3169970ac21
On the forward area, I put on the 'cheecks' with the gun muzzle grooves and the muzzles that were replaced by 0.8 mm aluminium tubing.
p?i=41ba8e73ce154690857151814933b2fc
The frontal characteristic air intake had to be faired inside and reshaped to get a properly thin lip thickness.
p?i=8c60ba06f9e92751e4456abed7b77874
Slowly going on, that is all for now,
Best regards,
Dan.
  • 1 year later...
Hi,
after a very long hiatus, when I was distracted by other models, I am back to this Gina. I finished the front part of the plane, filling gaps, scribing panel lines and adding some rivet lines.
p?i=24aedf0dc7bdf1f7ee2bb5795c28a7c2
Two air scoops were glued to the bottom side of the fuselage:
p?i=331ebd756174ef2a19d3ce23b7c71422
In the the cockpit area, I glued the resin coaming on top of the IP:
p?i=f9ac235948cca712bd3bc7883c26e5b9
p?i=6310916f23f35d8a60813f2225a4aa01
On the two weapon lids on the sides of the fuselage, I tried to add stripes of thick primer to render the stressed skin undulations visible on these panels, Let's see how this will work once painted.
That's all for now,
Dan
6 minutes ago, coneheadff said:
Hope Kinetic will finally release theirs. The old Heller/Italieri kit needs a ton of work.
Indeed, there isn't a single part of this kit that I didn't modified and adjusted.
Those gun doors are not a great fit.  Must have seemed a good idea when the kit was first launched but haven’t stood the test of time.  Seem to remember the undercarriage wasn’t up to much either.  Keep up the good work!
Indeed, the LG are inaccurate (i.e. wrong) and do not reproduce faithfully the stance of the plane. I will have to rework that, but I still do not know how.
Dan
Few small progress on my G.91. Also the aft fuselage is almost completed with rescribed and riveted lines.
p?i=4aeea6303a56546da787936f28f193ac
p?i=a94067c648cfa78183cb68520e6d313a
Some more details also on the front part.
p?i=67d48ca7b3f6e6578ccc0080929bfb4b
After that, also the wings were smoothed, rescribed and riveted. In addition, the boundary layer fence was replaced by a scratch build ones which are thinner and with a better shape:
p?i=7a5894d353ba512328ba6ca37253ad8b
The wing pilons were added after having been suitably modified:
p?i=0a19d559dbf009fc3e3d4c239246df92
The parts are here dry tested before gluing.
p?i=06b052a8cbb846113e762500b2a68dcf
That's all for now,
cheers,
Dan
Hi,
this week end I could clock some hours at the bench, hence I have few more pictures of my build to post. I started to assemble and glue the missing parts of the airframe, but the fit is everywhere atrocious. This is the nose cone which is in need a good dose of filler:
p?i=4137a3ad8d8a81fc85e3ec0986589377
The wings have straight butt joints with the fuselage with no fillet, but the joint is quite uncertain and therefore it was filled with filaments of stretched sprue:
p?i=e71e3c66675644fe84d851d96c1c3f2e
The filaments were then melted with liquid glue:
p?i=fe39f0ab335ee4b310f85b9805fadfe2
Once cured and light sanded, the result looks quite OK:
p?i=b23bd9801a480fba16b7b306444db227
This treatment was applied to all wing root junctions and to the tailplane surfaces as well. Having completed the assembly of the airframe, the nice lines of the aircraft finally emerged:
p?i=a3f16dc35ee8290aa3dee41f944e0d04
That's all for now,
to the next time,
Dan
@bar side, thanks for following. The fit of the gun pack doors was very bad also in my experience. If you go up to the top of this page, you find a picture before closing the gun bays. There you will see that I created a rabbet around the bay perimeter upon which the door could sit and stay level with the surrounding surface. After placing the doors, I filled the remaining irregular gap with thick CA and rescribed it anew.
Dan
20 hours ago, mike c said:
Great work, looking forward to seeing the finished model.
Thank you Mike for your note, I am looking forward too, but I am afraid at my pace it will not be very soon. 🙂
Dan
Hi,
a small update of my long build at the end of the week end. I remodeled the shape of the tail cone and refined it with the addition of the lid of the compartment for the drogue parachute.
p?i=57b212a71bea8839d69cee9ae1ee4628
The jet pipe is not glued and it will be added later on after painting.
p?i=18d9764f7a6662030b3013bcc5f497a0
On the other end of the plane, I added a small transparent part to represent the glass of the gunsight.
p?i=4d70fecaf9d831fdc2b8a8e86b0ded97
To protect it from knocking it off during handling, I glued in place the front part of the canopy.
p?i=2d15286aad4c96afb2e37715115facc9
This is how the cockpit looks now:
p?i=928362462b33ef1630c37fc0d5a0b869
That's all for now, thanks for following,
Dan
Hi,
some important progresses: finally we have some colors. However, before spraying, few last details had to be finalized. One was the areas of the wheels bay and airbrakes. These have an incorrect shape (this kit is hopeless), but, this time, I gave up with corrections. Life is too short to spend it in fixing all the mistakes of an old kit. Hence, I just framed the apertures with Evergreen stripes just to get a decent definition of them, and I moved on.
p?i=285dc23709fe6a8292d484c5004a3e25
I sprayed a very light coat of Mr. Surfacer 1500, provisionally mounted the canopy hood and gave a good wet sanding to the surfaces to be painted.
p?i=8417f5ab4616dbf06ce4de34d6014ada
p?i=ee64fa911a0d2ccd788460260faf97b2
All the newly scribed panels and rivet lines looked reasonably good, therefore I commenced the airbrush work. To reproduce the grey bands of the NATO camouflage I chose the Tamiya XF-54 'Dark Sea Grey', to which I added some white.
p?i=77b30b3146fe88cb9f121a53d1def2b2
I mottled the basic color with mixes with various percentage of white to try to reproduce the fading seen commonly on many period pictures.
p?i=1b38f519fee93a20f2ca51950d7a3ebe
This how the scratch built turbulence vanes look after a coat of paint. I find them much nicer than the original molded-in ones.
p?i=3a342d4597fda7b2539a2d080a556a55
Dark green will follow. That is all for now,
cheers,
Dan
Hi,
thanks to the holydays, I went on with the camouflage spraying. I added some post-shading to the grey paint to brake its uniformity.
p?i=5cb6b63dd0adc5ca0466c8ad731e6ccd
p?i=4c0a3a2a34ffe523288101d96bf99b46
Then, after masking with blu-tack rolls, I added the green bands, followed by some post shading. For the green, I used the Tamiya XF-81.
p?i=9e472cf4e7688711e33fe603194e7886
p?i=af4c32b7432a3322635d9c1d347d003e
p?i=1909449035c02e242eb2ed745720eb9c
Next, I need to make some corrections and perhaps tone a bit down the post-shading that looks to me a bit too stark. I also started working on the landing gears pieces that will be needed soon.
Best regards,
Dan
2 hours ago, Darth Vader said:
Paintjob looks great
Thanks for your comment! However, I find the post-shading too extreme. I will let it alone for a couple of days and then I will decide whether to tone it down or not.
Dan
Great work on this ancient kit. The Gina is a nice plane but not easy to build. You were able to touch the colours perfect! Looks very promising.
Evert
Dan
Considering that the usual gloss coat before decals and matt/satin final coat will very likely tone down the effect, I would probably leave it as is. In Italian service at least, the paint on these aircraft weathered quite a lot, the dark green in particular
Of course these are personal choices though, weathering is a matter of taste
In any case, really great work on this old kit!
