Pascal Posted May 23, 2020 Share Posted May 23, 2020 Hi guys, I broke one of the wheels of my 1/18 UT Models Porsche 911 GT1. I have a wheel insert from S.M.S., that I want to use to make a rubber mould. Do you think it's possible to make a mould with this insert ? And can you explain how to do it ? : Any help and tips are welcome. Sincerely Pascal Link to comment Share on other sites More sharing options...
JCH Posted May 23, 2020 Share Posted May 23, 2020 Sorry, no help here but I WILL be watching with interest. 😯 Link to comment Share on other sites More sharing options...
Black Knight Posted May 23, 2020 Share Posted May 23, 2020 Basics; 1. pack the inside carefully with plasticene. Up to the level of the back sides of the spokes, or level with the front sides of the spokes 2. place on a bed of plasticene. 3. make a wall around that bed. I use Lego 4. pour silicone RTV rubber over it all. 5 when that is set turn over and remove plasticene 6. apply mould release wax 7. pour on RTV rubber 8. when set remove the walls 9 separate the two halves of the moulds 10 use a scalpel to cut pouring gate in the rubber down to the wheel rim. 11. cast copy using polyurethane resin. 2 1 Link to comment Share on other sites More sharing options...
bootneck Posted May 23, 2020 Share Posted May 23, 2020 There's a nice, simplistic, practical video on the Sylmasta site. Select the video and view full screen. I would recommend that you make the original as good as possible, before making a mould, as any imperfections will end up in the casting. I am referring to the ejection marks on those rims. unless they are meant to be there. Mike 1 Link to comment Share on other sites More sharing options...
klubman01 Posted May 24, 2020 Share Posted May 24, 2020 The Sylmasta video is very clear. Their resin casting kit is also very good, and I've used it to make castings from a white metal master. A word of warning, though. Don't be in too much of a rush to get the castings from the mould. Although the resin may appear to have cured, it can still be soft and pliable, so handle with care. 1 Link to comment Share on other sites More sharing options...
Steve Noble Posted May 24, 2020 Share Posted May 24, 2020 I've used the Sylmasta kit a few times and it is very good. I made some wheels for a Tamiya Escort Cosworth and also a steering wheel and left hand drive dashboard for a Hasegawa Mitsubishi Lancer rally car. They turned out very nicely. Only problem I had was the occasional air bubbles in the wheel castings, but other than that it was fine. Link to comment Share on other sites More sharing options...
