sjsald Posted May 22, 2020 Share Posted May 22, 2020 Hey Everyone, I have a copy of the old Airfix Tri-Motor kit that I am tempted to start on. Does anyone know of a photo-etched (or other) detail set that would compliment the base kit well? Thank you Link to comment Share on other sites More sharing options...
billn53 Posted May 25, 2020 Share Posted May 25, 2020 I built this kit not too long ago (my detailed WIP is somewhere on the BM forum). There’s no aftermarket set per se, but you’d do well to replace the kit engines with Small Stuff’s Wasp Junior resin jewels. - Bill P.S. I found my WIP. H it is: 1 Link to comment Share on other sites More sharing options...
sjsald Posted May 26, 2020 Author Share Posted May 26, 2020 @billn53 thank you! I'll order the engines - they are a lot better than the ones included in the kit. Also, your build is spectacular! 1 Link to comment Share on other sites More sharing options...
billn53 Posted May 26, 2020 Share Posted May 26, 2020 47 minutes ago, sjsald said: @billn53 thank you! I'll order the engines - they are a lot better than the ones included in the kit. Also, your build is spectacular! Just be advised, with the current COVID situation shipments are being seriously delayed. I ordered a couple of the Small Stuff engines from Hong Kong two months ago, they only last week arrived in country. 1 Link to comment Share on other sites More sharing options...
Pedro1 Posted May 28, 2020 Share Posted May 28, 2020 On 5/22/2020 at 11:17 PM, sjsald said: Hey Everyone, I have a copy of the old Airfix Tri-Motor kit that I am tempted to start on. Does anyone know of a photo-etched (or other) detail set that would compliment the base kit well? Thank you Thunderbird Models make a vinyl masking set that helped me a lot (http://thunderbirdmodels.com/en/172-masks/48-tbm-011-thunderbird-models-172-ford-5-at-trimotor-masks.html). For the engines I used the ones from an Italeri Ju 52, with collector rings from solder wire. Please note that Airfix moulded the prop blades with the pitch reversed, so that needs to be corrected 🙂. Peter 1 Link to comment Share on other sites More sharing options...
sjsald Posted May 28, 2020 Author Share Posted May 28, 2020 3 hours ago, Pedro1 said: Thunderbird Models make a vinyl masking set that helped me a lot (http://thunderbirdmodels.com/en/172-masks/48-tbm-011-thunderbird-models-172-ford-5-at-trimotor-masks.html). For the engines I used the ones from an Italeri Ju 52, with collector rings from solder wire. Please note that Airfix moulded the prop blades with the pitch reversed, so that needs to be corrected 🙂. Peter Thank you! Link to comment Share on other sites More sharing options...
Space Ranger Posted June 4, 2020 Share Posted June 4, 2020 (edited) Any detail kit for Airfix’s Ford Tri-motor should include new wing leading edges (or complete new wings). The corrogations should fully wrap around instead of leaving the leading edges smooth. Edited June 4, 2020 by Space Ranger 1 Link to comment Share on other sites More sharing options...
Orso Posted June 4, 2020 Share Posted June 4, 2020 39 minutes ago, Space Ranger said: Any detail kit for Airfix’s Ford Tri-motor should include new wing leading edges (or complete new wings). The corrogations should fully wrap around instead of leaving the leading edges smooth. I wish I had known this when I converted mine into the single engine 8-AT 1 1 Link to comment Share on other sites More sharing options...
