The resin printer is fantastic for adding details! Redid the rear light clusters & mud guards, adding reflectors, blackouts, fastex clips, bolts, & power outlet.
Used the excuse of see how the non-skid would turn out to do a paint test using the SMS camouflage colours.
Got a little >< carried away.
Detail close up.
On 2/22/2021 at 4:13 AM, vytautas said:
I am really enjoying following your thread. It’s just hard to believe it’s all done from scratch. Beautiful work 👍
Thanks @vytautas - CAD makes this more a “design & print your own model”. Certainly a lot of work, and you can’t blame a manufacturer for bad design!
Interior painting has commenced, once again using SMS paints & custom decals for the seat cushions. Not a lot will be seen, so there’s not much more to do before it’s completed.
Seat backs will be aligned & glued prior to sealing up the hull.
Need to repaint the interior of the air sentry hatches as they’re also insulated.
Should be able to finish the interior by the end of the weekend.
On 2/25/2021 at 9:13 AM, ERK said:
Excellent work  - really top notch  workmanship.
Erk.
 Thanks, Erk. I appreciate the kind words. This’ll definitely be a three footer!
The arrival of SMS paint’s CARC sand allowed another series of quick wins on the “how will it look” phase.
So, the DUKE ECM antennas & mounts, plus the EOS R-400 remote (protected) weapon station & screen (on the dash) got an initial coat.
Then it was the turn of the satcom x-wing antenna & the base & bracket for the blue force tracker (or MT2011, as it’s known formally).
Sealed the upper & lower hull. Blocked out the RHS camouflage. Starting to look more like a Bushmaster :)
Painted up the LHS and took some pics against a higher-contrast background.
RHS v.2.
Now with rat (if you’re Iraqi) or roo (if you’re not).
Installed & painted the suspension. I had printed new, one-piece versions on the resin printer, but wasn’t happy trusting the interface between the hull and the transmission to CA
Front:
Rear:
Overall profile views with the wheels dry fitted, showing how little of the suspension is visible!
On 3/5/2021 at 1:46 PM, Vaastav said:
Lovely work mate, looks great
Thanks, Vaastav. It’s been a journey.
On 3/5/2021 at 6:40 PM, vytautas said:
That is outstanding! Nice work, looks great! A joy to watch.
Vytautas
Appreciated, Vytautas.
Lots of time spent bringing it all together. As always, the last bits before mat coating seem to take the longest.
Finished the weekend with a quick test fit of the truck in the display cabinet.
Will be a tight fit, height-wise, but will squeeze in.
  • GMK changed the title to 1/16 Bushmaster PMV - paint applied
1 hour ago, Romeo Alpha Yankee said:
Looks good in there Greg, so what is next? Something by Rheinmetall?
Thanks Ray.
Probably finish the M1 & my M113. Considering an AS1. On the fence about Boxer, tbh
Cleaning up the odds & sods to flesh out the details.
T handles/latches.
Handles & latches on the bonnet.
Hinges & vents for the roof.
Exhaust pipe.
Matted the underside.
And touched up the new parts.
Thanks for stopping by.
