Julien Posted May 11, 2020 Share Posted May 11, 2020 Heinkel He 111-H3 Romanian AF (48266) 1:48 ICM via Hannants The He.111 was originated in secrecy, disguised as a civilian transport in the mid-30s, but once Nazi Germany came out of the closet and disregarded the Versailles agreement, it immediately became clear that they were rearming in a major way. The early civilian and military variants had a more traditional stepped canopy, and there is a famous piece of film that is used and reused in documentaries showing a D or "Dora" variant dropping bombs during the Spanish Civil War as part of the Condor Legion, which was Hitler's proving ground for his new designs and Blitzkreig tactics. Various revisions followed until the P, which introduced the now-iconic stepless fully glazed cockpit, which improved both aerodynamics and the pilot's situational awareness. The P series saw limited action in WWII as it was replaced by the more competent H variant, substituting Junkers Jumo 211 engines, detuned to give it the throbbing beat that was to be heard over Britain almost until the end of the war. The H-3 had an improved version of the engine and increased numbers of machine guns for self-defence. As is often the case with wartime development, the end of the Battle of Britain saw the introduction of the H-4 with better engines and external bomb racks. The H series continued until the H-23, although there were also a number of side-projects such as the Z, Zwilling with two airframes joined by a central aerofoil and sporting five engines, designed to tow the Me.321 Gigant glider. The Kit We have only had one choice if we wanted a 1:48 He.111, although it has been in various boxes over the years. It's not a bad kit, but this is a 100% new tooling by ICM, who have raised their game substantially over the recent years. The kit arrives in their lidded top-opened with a glossy card lid and painting to top it off, with seven sprues in medium, grey styrene, one in crystal clear styrene, an instruction booklet in line-drawn colour, and a long decal sheet that can be found ensconced within the booklet. On opening the bags, it is very apparent that this is a modern tooling, with lots of lovely details, crisp moulding, and some very clever engineering on display. The cockpit and partial interior will require some thought for painting, but if you get the order right, you should minimise the swearing when you have to reload the airbrush for the Nth time. Construction starts with the two wing spar parts, which are separated by the gear bay roof assemblies and a walkway part. Additional detail is added to the bulkheads along with the fuselage walkways and a smaller bulkhead toward the tail, with the lower portion of the mid-upper "turret" ring attached to the floor. The cockpit floor is then assembled with rudder pedals, instrument panels, seat and control linkages, slotting into the front spar once finished. An additional chair and the overhead instrument panel are installed later in the build. As a prelude to closing up the fuselage, the tail wheel is fitted together, which has the wheel moulded-in, and consists of three parts. Preparation of the fuselage halves involves adding the inserts into the wing roots and making good the join; inserting the paired side windows; adding ammo can racks; radio panel; the pilot's control column, and more glazing in the ventral gondola. The spar/cockpit assembly is then fitted to the starboard fuselage half and the port side is added along with some glue. The rudder is separate and fits to the fin with actuators, then the missing fuselage panels between the spars are added, which of course will need painting and fettling in if you're bothered about the "endoscope brigade". The mid-upper insert is designed to cater for different "turret" installations, and has a lovely serrated ring moulded-in, with controls and bracing strut added before it is installed into the fuselage opening, closing off much of the rear fuselage. You can pose the bomb bay open or closed by selecting one of the two panels, one of which has opening for the bomb bay, where the bombs are suspended tail-first in a framework that is peppered with lightening holes so that the included bombs are visible within. The bombs themselves are built up from two halves that have two fins moulded-in, and a single part that fits on the tail forming the other two fins in a cruciform layout. To these are added stiffening brackets, with four bombs in total to make. With the bomb bay finished, it is inserted into the fuselage from below, filling yet another gap in the skin. Even if you are leaving the bays closed, the bomb bay can be seen from the side windows, so it's best to build that assembly and install it anyway to prevent that section from being see-through from the sides. At this point the wings are begun, with the lower sides added to the fuselage/spar assembly first. The ailerons are separate, and are built up before the uppers are added, as are the elevators, and the two engines, which are provided in their entirety, along with much of the ancillary equipment and engine mounts. The completed Jumo 211s are fitted to the front of the spars and depending on whether you want to display them or not, and then enclosed by cowling panels, radiators and the intake/outlet ramps. The bottom cowlings can be split to reveal the engine detail, which is a good way of showing off the detail without ruining the lines of the aircraft. The upper wings and ailerons are fitted, the remaining cowling panels with the exhausts are added, with the latter having a decent indent at the tip to simulate being hollow, and finally the nose glazing, which has a machinegun and the aforementioned overhead instrument panel, which is moulded in clear styrene and is provided with a decal for the instruments. The nose "cone" is a separate clear part, and it too is fitted with a machine gun with a choice of single or twin drum mags and dump bag for the spent brass. Another two MGs are fitted to the front and rear glazing on the gondola, and the mid-upper gun is added to the turret ring, along with the protective clear shroud at the front. The main wheels are each built up from two halves, and placed between the twin legs that have the main retraction jacks moulded in, and secured with a number of cross-braces between the two legs. An additional ram is fitted within the bay, attached to the rear cross-brace. The gear bay doors fit to the bay sides with large tabs, as do the bomb bay doors if you are using them, and these last parts have the correctly separated four "petals" that are seen on the real thing, rather than a single panel. The props are made up from a single part with two part spinner and back plate, which fit onto the engine's output shaft through the vented front of the cowlings. Markings There are two decal options included in the box as suggested by the tite for the Romanian Air Force. both in the Green/Brown/Grey camo scheme, . From the box you can build one of the following: He.111H-3, 5th Bomber Group, Romanian Air Force, Bessarabia, Summer 1941 He.111H-3, 5th Bomber Group, Romanian Air Force, Russia, Late 1942 Decals are printed by ICM, with good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas with a few exceptions around some of the fuselage codes. These can easily be cut off before they are applied however, so it's not an issue. The triple white bars on decal option 2 can be seen in some photos (Google image search "he 111 1a+da"), and those on the starboard wing appear to have a substantial amount of overspray around the trailing rectangle, which could be fun to replicate yourself. Conclusion The He.111 is a truly iconic shape, and we're long overdue a new tooling of the type in this scale. ICM have done a great job of it by the looks of things. Very highly recommended. Available in the UK from importers H G Hannants Ltd. Review sample courtesy of 2 1 Link to comment Share on other sites More sharing options...
Shark444 Posted May 20, 2020 Share Posted May 20, 2020 Looks to be miles better than the old Monogram kit! Link to comment Share on other sites More sharing options...
Julien Posted May 20, 2020 Author Share Posted May 20, 2020 16 hours ago, Shark444 said: Looks to be miles better than the old Monogram kit! It is. Link to comment Share on other sites More sharing options...
