Hoops Posted May 12, 2020 Share Posted May 12, 2020 On 5/8/2020 at 4:27 AM, Old Viper Tester said: 83-1144. I don't think the two-seater in the background is '752 - there's no FLIR ball atop the nose, but I haven't found a record of a USAF B/D participating in the CAS Eval. Sven I think that the two-seater in the the rear of this photo is actually 752. A couple of data points: All of the Air Force painted Euro 1 aircraft had the "Ejection Seat" text painted in white on the warning triangle, the warning triangles on 752 were black only. 752 had the sensors stuck to the inside of the canopies (helmet trackers?) not present on normal F-16s. Perhaps the FLIR was removed temporarily? Cheers, Hoops 4 Link to comment Share on other sites More sharing options...
Hoops Posted May 12, 2020 Share Posted May 12, 2020 10 hours ago, Hoops said: I think that the two-seater in the the rear of this photo is actually 752. A couple of data points: All of the Air Force painted Euro 1 aircraft had the "Ejection Seat" text painted in white on the warning triangle, the warning triangles on 752 were black only. 752 had the sensors stuck to the inside of the canopies (helmet trackers?) not present on normal F-16s. Perhaps the FLIR was removed temporarily? Cheers, Hoops Just realized another point, the two seater in the background does not have the in flight refueling light on the vertical tail. Being based on a FSD airframe 752 did not either. Cheers, Hoops 3 Link to comment Share on other sites More sharing options...
Richard E Posted May 12, 2020 Share Posted May 12, 2020 (edited) On 5/7/2020 at 8:27 PM, Old Viper Tester said: On 5/7/2020 at 8:27 PM, Old Viper Tester said: 11 hours ago, Hoops said: I think that the two-seater in the the rear of this photo is actually 752. A couple of data points: All of the Air Force painted Euro 1 aircraft had the "Ejection Seat" text painted in white on the warning triangle, the warning triangles on 752 were black only. 752 had the sensors stuck to the inside of the canopies (helmet trackers?) not present on normal F-16s. Perhaps the FLIR was removed temporarily? Cheers, Hoops @Hoops may be right. I've found a couple of pictures of 75-0752 on display at the Frontiers of Flight Museum in Dallas and the camouflage demarcation lines and stencil locations look very similar, whilst appreciating that '752 is now a museum exhibit the FLIR is also missing Edited May 12, 2020 by Richard E 2 Link to comment Share on other sites More sharing options...
