WV908
Canberra Red Dean trials
Hi all,
  Does anyone know how the Red Dean missiles and pylons / carriers were fitted to the Canberra trials aircraft?
I'm specifically looking for info on WD935, the nose of which survives locally to me at Doncaster
  WV908
I have the Freightdog set for the P.12 which bases the missile installation on the proposal documentation with the missiles on the wingtips. Whether that means they could't find anything else I don't know.
The Crowood book on the Canberra says:-
The Canberra was selected as the missile's launch platform and the seventh production B.2, WD935, was delivered to Vickers' test section on the airfield at Wisley, three or four miles from the works at Weybridge, on 8 August 1951. The company also had production facilities at Hurn and WD935 went there for the necessary engineering. As a missile was to be carried under each wing, local strengthening of the mainplanes was included in the schedule of work on the aircraft. The conversion was completed in October 1953 and a first flight, with an aerodynamic test missile, was made in january 1954. Wisley airfield was on a plateau and on 21 September 1955 WD935 suffered brake failure while rolling after touchdown and finished up in a field far too close for comfort to the main Portsmouth road. Its use on the Red Dean programme was rather curtailed after the accident; another B.2, WD942, which was in Australia at the time, and had been delivered to Wisley on 28 September 1951 to undertake specific tasks, took over the damaged Canberra's part of the programme.
@canberra kid will know more if anyone does.
Thanks @rossm
This is the problem - any documentation that is around lists the theoretical P.12 attachment point as the wingtips, mounted on strengthened PR.9 style wings. It sounds like this strengthening was to be built in during production and as WD935's strengthening was retrofitted one would imagine it was external, which begs the question of if the trial pylons / missiles were mounted further inboard.
I'd also quite like to know how she was painted.
Thanks,
  WV908
EDIT: The Canberra Tribute site lists the pylons as 'underwing carriers' which was much of the basis of my query.
Edited by WV908
It does say "As a missile was to be carried under each wing", so I imagine WD 935 was proving the feasibility of launching the missile from a Canberra, not the exact final design - unless that had moved on or the statement is not quite accurate.
There are two photos in Dan Sharp's Secret Jets of Cold War Britain of WD956 with under wing pylons for Red Dean trials including one of the missile firing. There is an illustration from the P.12 brochure which shows Blue Jays on underwing stations, wingtip tanks and the ventral gun pack
Edited by LostCosmonauts
Seems like the normal Canberra wing pylon location? Interesting lumps under the wingtips and is that a radar in the nose or a standard glazed bomber nose?
There’s a sharper pic and some description of the trials at
https://books.google.co.uk/books?id=Hoc7AwAAQBAJ&pg=PT130&lpg=PT130&dq=canberra+wd956&source=bl&ots=4ISTUhOUVG&sig=ACfU3U1qgQsHPIDzLuCeeJC2OT6L3fuZzQ&hl=en&sa=X&ved=2ahUKEwjkqfTZkp_pAhUOTRUIHac6DL4Q6AEwAnoECAMQAQ#v=onepage&q=canberra wd956&f=false
Describes them as sideways and forward looking camera pods and if you scroll back a page there is a neat diagram of the fittings
fixing typo
On 5/3/2020 at 10:35 PM, WV908 said:
Hi all,
  WV908
Sorry I'm a bit late to the party, is this the sort of thing?
John
John
What can I say chaps but Thankyou. What you've both provided is absolutely perfect and I have no reason to believe that WD935 would have been fitted out or painted any different. The chequer markings will be interesting to do, but I look forward to scratching the parts for my Canberra build.
  WV908
Edited by WV908
  WV908
I do have a photo of WD935 with the Red Dean test vehicle and the pylon is the same as on WD956 but the weapon is silver not black, the underside of the wing is black so I assume she is in standard Medium Sea Grey and Black scheme.
John
John
Thanks John,
  With the missile being silver I would assume the markings on it are black, or did it looks like the extant example at Cosford?
  WV908
Edited by WV908
