Julien 8,529 Posted May 3, 2020 Share Posted May 3, 2020 Wehmacht 3t Trucks (DS3507) 1:35 ICM via Hannants Ltd. While tanks and fighting vehicles maybe the more glamours side of vehicles used by armies it is often forgotten that the humble truck is the back bone of logistics; without which no army in the world can unction. This set from ICM brings together three of their 3t German truck models under one box lid. Typ L3000S German Truck (35420) Standardising from 1940 on the Mercedes Benz design in order to simplify spares and maintenance, the L3000S was one of many variants of the truck to see service. Powered by a 4 cylinder 4.85 litre diesel engine with four-wheel drive and able to carry up to 3 tonnes of cargo, it was a workhorse that saw service in almost every theatre of WWII where there was a German presence with almost 30,000 made. Consisting of three large sprues, a clear sprue, three pairs of rubberised tyres, decal sheet and instructions, this is a full engine kit with detailed chassis, multi-part engine assembly, cab and truck bed. Construction begins with the chassis and engine, suspension and exhaust, then moves to the front fenders, driveshafts attaching the rear axle in place, and steering arms at the front, both attaching to the leaf suspension. The wheels have two-part hubs that the rubbery tyres slip over, with two at the front and two pairs on different style hubs on the rear axle. The crew cab is made up with floor, instrument panel with decals, bench-style seat, then the various external panels that box in the crew. There is a small window to the rear, and the main windscreen aperture is moulded into the roof and firewall cowling, while the doors are separate mouldings that can be posed open or closed with separate winders and handles, plus clear panels all round the cab. Before the engine bay is boxed in the cab is joined with the chassis, then the front bumper/fender is glued to the end of the chassis rails and the three-part cowling with separate radiator is dropped between the front wings to complete the chassis. If you were minded, you could score the top panel of the cowling to display the engine, and if the thickness of the part bothered you, you could cut a new one from brass using the original as a template and rolling the edges. The smaller parts such as lights, number plate holders and windscreen wipers are fitted after the cargo bed has been made up. The cargo bed is built on the floor, with upstands latching into their hinge-points and the addition of front fixed panel and the rear door giving it some rigidity. Five cross-braces are added underneath and are joined together by two additional longitudinal rails where they join with the chassis. A spare wheel, stowage boxes and spare fuel cans in cages are then fitted to the underside with the rear mudguards suspended from boxed in sections. The bed fits onto the chassis by a quartet of pegs that locate in corresponding slots in the chassis rail, then the aforementioned lights, pioneer tools and windscreen wipers are glued in place around the model. Markings There are four options on the decal sheet, only two of which are theatre specific to this boxing and painted grey. Not everyone will stick to the theme though, which is fair enough as it's your model. From the box you can build one of the following: WH-272 104 Ukraine, Summer 1941 WL-34548 Russia, Summer 1942 WH-858 842 North Africa, Summer 1942 WH-76836 Italy, Summer 1944 KHD S3000 German Truck (35451) From 1940 onward the German army, by standardizing and simplifying the numerous types of trucks, tried to improve the procurement of spare parts and facilitate repairs. The result was the standard 3 ton truck, which all German manufacturers now used as a basis for construction. This was also the basis on which the motor manufacturer Klöckner Humboldt Deutz AG, (KHD) of Cologne produced the A3000. Various bodies and sets of equipment were available, including a half track, “maultier”. A typical recognition feature was the oval radiator grille and one-piece windscreen. In total about 5960 examples were built between 1940 and 1944. The 4 wheel drive A3000 came to be used on all fronts in the Second World War and was indispensable for supplying the troops with goods of all kinds. The build starts with the nicely detailed engine with the block and gearbox halves glued together followed by the addition of the rocker covers, starter motor, alternator, front engine mounts, cooling fan, air filter, and other sundry items. The instructions then move on to the complicated transfer box, with its input and output shafts and cross member frame that fits onto the chassis rails with the addition of four other cross members and rear chassis end piece, to which the towing eye, cover and pin are added, along with the front mudguards and engine are attached. The front and rear leaf springs are pre moulded to the chassis rails, the front and rear axles and transfer box are then fitted. Turning the rails over the engine can now be fitted plus the exhaust system, which comprises of four parts, and looks particularly fragile so it may be an idea to build in situ rather than as a separate assembly the instructions call for. The two driveshafts are then be added, as are the radiator/front chassis end piece. The steering rack assembly is built up using the four parts provided and, if the modeller chooses can be built up so that the front wheels are pose able, although this may make it rather fragile, particularly the rear tie rod. After fitting the various brackets and supports as well as the front bumper, it’s onto the wheels, these come as single piece tyres plus inner and outer hubs. There are seven provided, singles for the front, doubles for the rear and a spare which fits on the chassis behind the cab and under the bed, along with the four piece fuel tank. The building of the cab begins with filing off the ejection pins marks on the underside of the floor, before fitting the pedals, steering column, steering wheel and handbrake handle. The seat support and cushion is fitted to the floor, whilst the windscreen, instrument panel, (with decal instruments), are fitted to the roof/front part of the cab. Onto the rear panel of the cab the seat back and rear screen are attached. The next assembly for the cab is the bonnet, which is made up of left and right hand parts, bonnet and radiator grille. The completed bonnet cannot easily be made to be posed either open, which is a shame. To finish off the foot plates are attached along with the doors, which are made of the external panels, door cards, clear parts, and door handles. Last details are the wing mirrors, lights, wipers; grab handles, spade, triangular roof marker, jerry can and its support bracket. The last assembly is the truck bed, with the bed itself being fitted with the side, rear, and front plank sections. On the underside, four lateral strengthening beams, plus the two wheel arches are fitted with their attachment struts. The kit comes complete with four tilt rails that attach to the outsides of the truck bed sides. To complete the build the windscreen wipers, wing mirrors, grab handles, headlamps, and width markers are glued into their respective positions. Markings There are two markings on the sheet; A. KHD S3000 Ukraine 1942 in overall Grey B. KHD S3000 France Summer 1944 in Yellow/Green camo. V S3000 (1941 Production) German Army Truck (35411) From 1940 onwards the German army, by standardizing and simplifying the numerous types of trucks, tried to improve the procurement of spare parts and facilitate repairs. The result was the standard 3 ton truck, which all German manufacturer snow used as a basis for construction. This was also the basis on which the motor manufacturer in Cologne produced the "V3000S" from 1941 onwards. Various bodies and sets of equipment were available. A typical recognition feature was the oval radiator grille and one-piece windscreen. In total about 25,000 examples were built. The "V 3000 S" came to be used on all fronts in the Second World War and was indispensable for supplying the troops with goods of all kinds. The build starts with the nicely detailed engine with the block and gearbox halves glued together followed by the addition of the rocker covers, starter motor, alternator, front engine mounts, cooling fan, air filter, cooling pipes, gear stick and other sundry items. The instructions then move on to the chassis rails with the addition of five cross members and rear chassis end piece, to which the towing eye, cover and pin are added. To the top of the main rails the two sub rails are added. These are then further secured to the main rails by six ties and clamps. The front and rear leaf springs are fitted along with the rear axle and transfer box. Turning the rails over the engine can now be fitted plus the exhaust system, which comprises of seven parts, and looks particularly fragile so it may be an idea to build in situ rather than as a separate assembly the instructions call for. The two driveshafts can then be added, as can the radiator/front chassis end piece. The steering rack assembly is built up using the four parts provided and, if the modeller chooses can be built up so that the front wheels are posable, although this may make it rather fragile, particularly the rear tie rod. After fitting the various brackets and supports as well as the front bumper and tow hooks, it’s onto the wheels, these come as single piece tyres and outer wheels. There are seven provided, singles for the front, doubles for the rear and a spare which fits on the chassis behind the cab and under the bed. The inner wheels are glued whilst an middle part is not, to enable the wheels to turn when fitted to the axles which most modellers probably wouldn’t be bothered with. The building of the cab begins with filing off the ejection pins marks on the underside of the floor, before fitting the pedals, steering column, steering wheel and handbrake handle. The seat support and cushion is fitted to the floor, whilst the windscreen, instrument panel, with decal instruments, are fitted to the roof/front part of the cab. Onto the rear panel of the cab the seat back and rear screen are attached. The next assembly for the cab is the bonnet, which is made up of left and right hand parts, bonnet and bonnet ornament strake. The completed bonnet can then be posed either opened or closed. The final part of the cab is the engine bay which is built up of the left and right hand sides, radiator grille, and rear bulkhead. These five sub assemblies are then fitted together to make the full front assembly, which is then fitted to the chassis. To finish off the front, the mud guards/foot plates are attached along with the doors, which are made of the external panels, door cards, clear parts, and door handles. Last details are the wing mirrors, lights, wipers; grab handles, spade, triangular roof marker, jerry can and its support bracket. The last assembly is the truck bed. This is built up with the bed itself, five strengthening beams on the underside along with two storage containers and rear number plate. There are four supports for each of the rear mudguards and the mudguards themselves to be fitted before flipping the assembly over and attaching the front sides and rear panels. On the front panel, two brackets are attached, into which the hoops for a canvas cover, which is not supplied. The whole assembly is then attached to the chassis, completing the build. Markings There are four markings options on the small sheet;; A. V3000S Russia Summer 1942 (Overall Grey) B. V3000S Russia Winter 1942 (Overall white) C. V3000S Italy 1943 (Overall Grey) D. V3000S Sicily June 1943 (Two tone grey camo) Conclusion This is a great combination set that offers a lot in the box that would keep you busy for quite a long time, and for the price of one large tank model (i.e. almost half its individual RRP). Two vehicles and eight figures plus weapons in total, and lots of lovely detail that just begs to be made into a diorama. Very highly recommended. Review sample courtesy of Link to post Share on other sites
Threadbear 508 Posted May 24, 2020 Share Posted May 24, 2020 Got this 3 set of trucks and are great. However the box art depicts the Deutz truck as a 4X4 where as the kit is a 4X2, otherwise, brilliant. Link to post Share on other sites
