Vulcanicity Posted May 1, 2020 Share Posted May 1, 2020 That's a beautiful Harrier, I am also very much a fan of the weathered wing leading edges down to primer - a really cool effect 1 Link to comment Share on other sites More sharing options...
_alfisti_ Posted May 1, 2020 Author Share Posted May 1, 2020 7 hours ago, Selwyn said: Nice build of a GR3 Harrier, Just one incredibly small accuracy criticism, something I see on a lot of Harrier GR3 builds. (also on GR1/T2/T4 Builds!) The aircraft in the Falklands had guns fitted in the gunpods. Your gunpods depict the pods without guns fitted, as they have the cone shaped wooden barrel blanks fitted to the front of the pods. these should be cut off and "30mm barrel" size holes should be visible. It was usual to fly blanked gunpods on field exercises in Germany, but in general guns in pods were normally fitted to all squadron aircraft, so the wooden cone shaped blanks were seldom seen in practice. Simple 1st generation Harrier gunpod rule; Gunpod with cone shaped wooden barrel blank = empty pod no gun fitted. Gunpod with open barrel apature= 30mm ADEN gun fitted. Selwyn Thank you for the hint. I only cut of the tip of the kit pods and added a neddle for the barrels, but after looking closer to some reference pics now i see what you mean. There is no barrel visible in the original, so on my next Harrier i will only open the holes and don´t add barrels. Link to comment Share on other sites More sharing options...
Selwyn Posted May 1, 2020 Share Posted May 1, 2020 (edited) 8 minutes ago, _alfisti_ said: Thank you for the hint. I only cut of the tip of the kit pods and added a neddle for the barrels, but after looking closer to some reference pics now i see what you mean. There is no barrel visible in the original, so on my next Harrier i will only open the holes and don´t add barrels. In real life there was a cylindrical blast suppressor that covered the gun barrel inside the front fairing (it was a metallic coppery red colour) it wasn't really visible even in 1.1 scale unless you really got close and peered down the barrel hole. The actual gun barrel was about 7-8 cm back from the hole in the front of the gun pod. Selwyn Edited May 1, 2020 by Selwyn 1 Link to comment Share on other sites More sharing options...
Johnson Posted May 24 Share Posted May 24 Great build, wonderful finish and weathering. Researching for my GR3 as part of the Falklands War 40th Anniversary GB. If mine is half as good I'll be happy! Link to comment Share on other sites More sharing options...
_alfisti_ Posted May 24 Author Share Posted May 24 Thanks a lot for your kind words. I´m sure you will also do a great job on yours. Link to comment Share on other sites More sharing options...
Ad-4N Posted May 24 Share Posted May 24 What paint did you use for the yellow green primer chipping? Link to comment Share on other sites More sharing options...
_alfisti_ Posted May 25 Author Share Posted May 25 16 hours ago, Ad-4N said: What paint did you use for the yellow green primer chipping? Hi. Tamiya xf-4 was used for the chipping. Link to comment Share on other sites More sharing options...
F-32 Posted May 25 Share Posted May 25 Very smart looking GR.3, love the weathering Link to comment Share on other sites More sharing options...
Ad-4N Posted May 25 Share Posted May 25 1 hour ago, _alfisti_ said: Hi. Tamiya xf-4 was used for the chipping. Thanks. I was thinking it might be XF-4. It looks fantastic. Well done. Did you apply it with a sponge? Link to comment Share on other sites More sharing options...
_alfisti_ Posted May 25 Author Share Posted May 25 Thanks a lot. ...yes, I used a piece of a sponge. Link to comment Share on other sites More sharing options...
