GordonM Posted April 28, 2020 Share Posted April 28, 2020 Hopefully a simple and quick question! I’ve got the Airfix ‘Mighty Hunter’ in the stash and lockdown is making me look at getting on with it.. My question is during the time 51 Squadron were based at RAF Wyton can someone clarify a timeline for the following: IFR probes and colour schemes. Namely did the white / light grey scheme pre date IFR probes being fitted? By the time 51 Squadron moved to Waddington from Wyton were the aircraft in the two tone grey scheme, or did that happen after the move? Thanks in advance Link to comment Share on other sites More sharing options...
Richard E Posted April 28, 2020 Share Posted April 28, 2020 Have you seen Mark's @canberraman photographs of the Nimrod R Mk.1s from RAF Wyton Link to comment Share on other sites More sharing options...
Rickoshea52 Posted April 28, 2020 Share Posted April 28, 2020 As far as I know the white and grey scheme was as delivered from new so pre-dates the fitting of the IFR which was introduced around the time of the Falklands Conflict for the MR fleet deployed for that campaign, they were also in the hemp over light grey paint with large dark blue/red roundels. By the time 51 relocated to Warrington they were most definitely in hemp over light grey with large subdued pink/light blue roundels which were later replaced with a smaller roundel at Major in the mid to late nineties. Be aware that 51 lost XW666 during a flight test which resulted in XV249, a stored MR2, being converted to R1 as a replacement. Nimrods began being repainted in grey around the time I left the RAF in 2005. Link to comment Share on other sites More sharing options...
71chally Posted April 28, 2020 Share Posted April 28, 2020 The refuelling probes were fitted in spring 1982 (Falklands driven) just after the Nimrod fleet had gone into the hemp scheme.. R.1s moved from Wyton to Waddo in 1995, which I think pre-dated the grey scheme. Link to comment Share on other sites More sharing options...
GordonM Posted April 28, 2020 Author Share Posted April 28, 2020 Ok, so I’m going to need a couple of buckets of hemp.... cheers chaps. Link to comment Share on other sites More sharing options...
Jabba Posted April 28, 2020 Share Posted April 28, 2020 The only aircraft to be fitted with the in flight refueling probe in 1982 was XW664 and it was in the Hemp/Lt Grey scheme. The other 2 aircraft had not had the Probe fitted by the time I left 51 Sqn in 1987. The last aircraft to be painted in the Hemp scheme was XW665, which was still in the old scheme when I arrived at the end of 1981 and was painted whilst during early 1982. Initially XW664 was fitted with hook aerials on the tailplanes, but as the aircraft used to have a corkscrewing affect at the back end making some of the flying formation eating team (aircrew) to feel sick, a solution was found, and that was the bigger finlets. These were also fitted to XW665 and XW666 even though they did not have the probe. Link to comment Share on other sites More sharing options...
GordonM Posted April 28, 2020 Author Share Posted April 28, 2020 1 hour ago, Richard E said: Have you seen Mark's @canberraman photographs of the Nimrod R Mk.1s from RAF Wyton I’ll be bookmarking those photos! I went to Huntingdon Technical College, so my education was interrupted by Canberras! 1 Link to comment Share on other sites More sharing options...
Hook Posted April 29, 2020 Share Posted April 29, 2020 On 4/28/2020 at 8:23 PM, GordonM said: Ok, so I’m going to need a couple of buckets of hemp.... Let's hope your local narcotics squad isn't reading along. I have the Airfix in the stash as well, bug I would have to get an aftermarket decal sheet first. Cheers, Andre Link to comment Share on other sites More sharing options...
torqueofthedevil Posted May 4, 2020 Share Posted May 4, 2020 On 4/28/2020 at 5:29 PM, GordonM said: Hopefully a simple and quick question! I’ve got the Airfix ‘Mighty Hunter’ in the stash and lockdown is making me look at getting on with it.. My question is during the time 51 Squadron were based at RAF Wyton can someone clarify a timeline for the following: IFR probes and colour schemes. Namely did the white / light grey scheme pre date IFR probes being fitted? By the time 51 Squadron moved to Waddington from Wyton were the aircraft in the two tone grey scheme, or did that happen after the move? Thanks in advance A small point: IFR is Instrument Flight Rules! Refuelling equipment is usually referred to as AAR Link to comment Share on other sites More sharing options...
71chally Posted May 4, 2020 Share Posted May 4, 2020 In flight refuelling was commonly referred to as IFR, and is still known as that by some. Link to comment Share on other sites More sharing options...
klubman01 Posted May 5, 2020 Share Posted May 5, 2020 To be strictly accurate, it is now called AR (Air Refuelling) Link to comment Share on other sites More sharing options...
