Martian Posted May 6, 2020 Share Posted May 6, 2020 Loads better! Martian 👽 1 Link to comment Share on other sites More sharing options...
perdu Posted May 6, 2020 Share Posted May 6, 2020 Proper job now Ced Likey, me likey 1 Link to comment Share on other sites More sharing options...
Brandy Posted May 6, 2020 Share Posted May 6, 2020 Much betterer! Is the lawn finished yet? Ian 2 Link to comment Share on other sites More sharing options...
Max Headroom Posted May 6, 2020 Share Posted May 6, 2020 3 hours ago, Martian said: Loads better! Martian 👽 Aye, the guns don’t jam as frequently. Is that the door over there.....? Trevor 6 Link to comment Share on other sites More sharing options...
Martian Posted May 6, 2020 Share Posted May 6, 2020 7 minutes ago, Max Headroom said: Aye, the guns don’t jam as frequently. Not surprising seeing as how they are not gummed up with Vogon snot. Martian 👽 1 4 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted May 6, 2020 Share Posted May 6, 2020 Anti histamine bullets. 4 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted May 6, 2020 Share Posted May 6, 2020 It's the Vicks. Vickers. Close enough. 2 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted May 6, 2020 Share Posted May 6, 2020 That’s the way to do it. Brilliant work. 🤩 1 Link to comment Share on other sites More sharing options...
Wince Posted May 6, 2020 Share Posted May 6, 2020 Great work on this. I struggled with this back in 1997 as a 14 year old and regret trashing it. 1 Link to comment Share on other sites More sharing options...
CedB Posted May 7, 2020 Author Share Posted May 7, 2020 Thanks Giorgio, Simon, Martian, Bill, Ian, Trevor, Pete and Wince Lawn is mown! I thought I ought to try and finish one before continuing with the rest. You can tell by the mess on the bench that I'm having to use lots of tools and stuff: Untitled by Ced Bufton, on Flickr I got the broaches out to open up the grip and trigger holes but I find them useless, twisted or moved up and down. Have I got a duff batch? No cutting / filing surface that I can see? Anyway, I've finished one: 0.8mm Albion tube, 0.8mm Plastruct body, ART band between the tubes. OK to carry on Sir? I need to put some detail on the body - sharpie / fine felt tip? 14 Link to comment Share on other sites More sharing options...
Heather Kay Posted May 7, 2020 Share Posted May 7, 2020 I think the problem with broaches is they’re meant to do one job - make a hole bigger in diameter. The edges are the bits that do the cutting by rotating the broach. They're not really meant to widen slots, though they can do it with care and in soft material like plastics. To use a broach, drill a hole in the usual manner, then insert an appropriately sized broach in the hole and twist it while gently pushing it into the hole. It will make the hole bigger in diameter. It’s ideal for making a hole just a bit bigger than the bit itself manages. I use broaches to ease out drilled holes in brass so it’s easier to fit hard drawn wire rod into the 'oles. Wire rod is frequently slightly larger than the diameter quoted on the packet. 6 4 Link to comment Share on other sites More sharing options...
perdu Posted May 7, 2020 Share Posted May 7, 2020 I use needle files to broach out holes that need easing Not really important info acos Ced already has broaches, just saying A good description of how they work, easy for the non-engineering mind to follow Heather Nice one In toolmaking for fasteners we often used hexagonal broaches to pull though a round hole with inreasing sized hexagonal teeth This gave holes the right shape and size for nuts and bolt heads Drill the tool steel, pop into the broaching tool and broach, then harden the new tool for making bolt heads to size Lovely engineering Broaches should be able to make many different hole shapes Triffic! 3 2 Link to comment Share on other sites More sharing options...
The Spadgent Posted May 7, 2020 Share Posted May 7, 2020 Crackin’ shooter Ced. 👍 1 Link to comment Share on other sites More sharing options...
CedB Posted May 8, 2020 Author Share Posted May 8, 2020 Thanks Heather and Bill The old grey matter is stirring and I think you've both explained that to me before - sorry! Broaches for enlarging diameter, got it, thanks. Thanks Johnny I went ahead and marked up some detail with a fine felt tip: The new one is at the bottom - I hope you can tell… I just need to make the other five from these bits: … then I can get on with… what was I doing… oh, gun mounts so I can complete the internals and close up. I went blood doning yesterday so I'm feeling a bit washed out this morning and very thirsty. Unusual. Maybe I'm getting too old for this regular blood draining… 13 Link to comment Share on other sites More sharing options...
keefr22 Posted May 8, 2020 Share Posted May 8, 2020 3 hours ago, CedB said: Maybe I'm getting too old for this regular blood draining… " A pint? That's very nearly an armful".... Nice 'ickle guns Ced! Keith 1 5 Link to comment Share on other sites More sharing options...
Martian Posted May 8, 2020 Share Posted May 8, 2020 1 hour ago, keefr22 said: " A pint? That's very nearly an armful".... Then drink a couple of arm's worth of beer. That should more than restore the situation. Helpful of Mars 👽 7 Link to comment Share on other sites More sharing options...
perdu Posted May 8, 2020 Share Posted May 8, 2020 Very helpful... 2 1 Link to comment Share on other sites More sharing options...
CedB Posted May 8, 2020 Author Share Posted May 8, 2020 5 hours ago, keefr22 said: " A pint? That's very nearly an armful".... Nice 'ickle guns Ced! Keith Thanks Keith - classic I've found a video on YouTube. Bit weird as it's an example of digital cleaning so has 'two screens' but still worth a watch if you're not too worried about the pre-PC content! Here's the relevant bit: You do get badges now - someone's listening perhaps 3 hours ago, Martian said: Then drink a couple of arm's worth of beer. That should more than restore the situation. Helpful of Mars 👽 3 hours ago, perdu said: Very helpful... Thanks Martian and Bill Not allowed alcohol, apparently… might be worth an experiment though? I've done a couple of bits. Depth charges glued: Flash thingies stuck on with GG thin: Hopefully more tomorrow. 11 Link to comment Share on other sites More sharing options...
Martian Posted May 8, 2020 Share Posted May 8, 2020 1 hour ago, CedB said: Thanks Martian and Bill Not allowed alcohol, apparently… might be worth an experiment though? There are many who have spoken well of it. Martian 👽 1 Link to comment Share on other sites More sharing options...
Selwyn Posted May 8, 2020 Share Posted May 8, 2020 Have you thought about looking for some of these? https://www.hpmhobbies.com/high-planes-vickers-k-gun-x-2-accessories-1-72/ Selwyn 1 Link to comment Share on other sites More sharing options...
Martian Posted May 8, 2020 Share Posted May 8, 2020 8 hours ago, perdu said: Very helpful... I thought so. Martian 👽 3 Link to comment Share on other sites More sharing options...
hendie Posted May 8, 2020 Share Posted May 8, 2020 nice flashers Ced 1 Link to comment Share on other sites More sharing options...
CedB Posted May 9, 2020 Author Share Posted May 9, 2020 14 hours ago, Martian said: There are many who have spoken well of it. Martian 👽 Quite right I hear - there was wine last night and I feel much better this morning 11 hours ago, Selwyn said: Have you thought about looking for some of these? https://www.hpmhobbies.com/high-planes-vickers-k-gun-x-2-accessories-1-72/ Selwyn Thanks Selwyn - looks like a new product (there's no image yet) but might be useful for future readers. It did lead me to a great site on the Vickers GO though. 8 hours ago, hendie said: nice flashers Ced Thanks Hendie More fiddly guns this morning. I drilled two holes in each end for the grip and one for the trigger then used the SM61 fine to create the straight back and the pointed blade to round the front and clear the flash: Untitled by Ced Bufton, on Flickr This time I drilled two holes for wire to support the tube and stuck the wire in with CA. I found it easier to put a drop in the holes and poke the wire in: Yes, that red stuff is blood, as if I haven't given enough this week. The drill broke through the plastic into my thumb. It may be just a smear to you but it's life and death to some poor wretch (see Hancock video at 13:42) Tubes on with GG thin: Not as wide a gap between the tubes as I would like but Albion don't do 'the right size'. I'll let that dry, stick some ART on and paint them up with AK paste later. 9 Link to comment Share on other sites More sharing options...
CedB Posted May 9, 2020 Author Share Posted May 9, 2020 While I'm waiting for the guns to dry I thought I'd look at the floats. Oh dear: Lots of ejector marks and the ones on the supports are in the middle of some panel detail. Great. Looking for some references I found a great picture from the Catalina Preservation Society here (scroll down and click to enlarge if you want to). That shows (and explains) the folding mechanism but also shows the internal panels - that'll cover up some of the ejector marks. The kit floats had the locating slots covered in flash: …but they cut out well enough: I think that blob on the back is supposed to be the mooring rope ring? Nasty. Assembled, the folding frame doesn't look too bad: …but the hinge is too big and there's a missing rod - the one that pulls the frame into the wing. Sounds like I've committed to 'floats down' eh? I think so, and it should be 'fun' 13 Link to comment Share on other sites More sharing options...
CedB Posted May 9, 2020 Author Share Posted May 9, 2020 Five guns painted: Depth charges: One of the tail rings was shorter than the others and didn't fit. Rats. Scratch tube: Not perfect but good enough for the ceiling: Back to the floats. What do we think of the struts? I think they look about the right thickness, but obviously the hinges aren't on the real thing so they'll have to go. Oooh look, that part has a 'S' on it. So do these: As long as I keep flipping the wings over to check the port/starboard we should be OK. 5 5 Link to comment Share on other sites More sharing options...
