Tamiya Extra Thin Cement aternatives
So I ran out of this and the LHS are all closed but not the hardware stores.  I began searching for the ingredients and found the MSDS. So sharing here for record and in case others want to know.
Tamiya extra thin cement main ingredients are 50% Butyl Acetate and 50% Acetone.
http://www.hobby2you.eu/catalog/sikkerhedsblade/543459.pdf
Tamiya extra thin cement quick setting ingredients are 40% Ethyl Acetate, 40% Acetone and 20% Butanone
https://cdn.simba-dickie-group.de/downloads/300087182/300087182_MSDS_TAMIYA_Extra_Thin_Cement_Quick-Setting_02-2018.pdf
Ehyl Acetate evaporates faster than the Butyl version and is a hotter solvent on plastic.
Butanone as we know is the main ingredient in most polystyrene cement.
On another forum I read that using MEK works as well as the extra thin cement and is hotter.
I found out the hardware store here sells MEK (but in 3.5 litre tin) so I am going to get it, mix with the Acetone I have lying around the house.
I guess if it works, I will have a lifetime supply of ultra thin glue, ha ha.
I've used MEK before with excellent results - that's just MEK with no Acetone admixture. It's pretty volatile so good ventilation is a must. In the past, when I was young and daft, I've even used it to attach canopies with no problems
HTH
SD
Methylene chloride is the one I use I get it in a litre bottle off eBay. Cost me about £7 ($10) delivered I pour it into an old Tamiya paint jar to use.
  • 5 months later...
Having exhausted trying to glue with Mr.Hobby Mr.Cement S (as for my it's not glue, it's 💩, but this very good cleaner for panel line when you scribing panel line!💡
 and Mr. Hobby  Mr.Cement something with the help, I took this advice ...in results, now I have 1 liter  "Tamiya Extra Thin Cement" my own manufacturing!😉😁😎
As no strange, but the most difficult thing here is to buy acetone, good industrial quality .... with butyl acetate, it was more of a problem to find a convenient suitable glass container with a capacity of one liter, because where I bought butyl acetate, they sell it from one liter.
 The total cost of all components (0,5 liter acetone and
1 liter butyl acetate)
cost me about $ 5,5.
And yes, it works like Tamiya extra thin cement!
I will have to try to make more according "Tamiya extra thin cement quick"
to this recipe:
B.w. anybody know ingredients and  MSDS ordynary "Tamiya Cement"? Non bottle ordynary "Tamiya Cement" written: "Component  Element: 12% Synthetic Resin 88% Styrene Organic Solvent" but of course the chemical composition of these components is not indicated.
B.R.
Serge
I don't recall when I read the tip (may have been here on BM) but Tamiya Airbrush Cleaner is almost the exact same formula as Tamiya Extra Thin.  I gave it a try and Airbrush Cleaner glues styrene just fine.  The only difference I can see is that Airbrush Cleaner has a slight yellowish tint and the Extra Thin is clear.  Here, across the pond, Extra Thin is about $6 USD for 40ml and Airbrush Cleaner about $8 for 250 ml.  That's 3¢ vs. 15¢ per ml and I'm not sure having a bottle cap with a brush is worth 12¢ extra per ml.  Besides, I have two dedicated brushes I use for applying liquid glue.
Lou in California.
Yes it was.  It was on a Russian forum, and probably somewhere here on BM. Maybe was video on YouTube....
 The difference is only in the proportion of components for the glue 50% to 50% for the cleaner 49% to 51% (as far as I can remember, but I may be wrong - the memory can malfunction), as for me 1% is not a very big difference.
But the problem is that my local hobby-shop does not have a cleaner either, but the factory and the household market have chemical components for making this glue myself.
B.w. the irritating odor in Tamiya glue creates acetone, because butyl acetate smells like pear, and has the colloquial name "pear essence".
B.R.
Serge
Found:
http://www.hobby2you.eu/catalog/sikkerhedsblade/543450.pdf
Ordinary  Tamiya Cement have next Component  Element:
Butyl Acetate
123-86-4
40.0% Acetone
67-64-1
40.0% Cyclohexane
110-82-7
7.0%
3-Methoxy-3-Methylbutyl Acetate103429-90-9
2.0% Polystyrene Resin
9003-53-6
11.0%
.....the bottle label says more simplistically.
B.R.
Serge
All these people mixing different chemicals together with no knowledge of what might happen worries me immensely. I don't have a chemistry background, so wouldn't attempt such a thing. I'll stick to buying the proper stuff. Call me a worrywort but I'd rather know what I'm using and that it's safe..
