Hello fellow modelers, let me introduce you myself. My name is Thanos, I am a mechanics student from Athens, Greece. One of my passions are airplanes. I spend the most of my day in home, due to the corona virus outbreak. So, I started scrolling in YouTube and I found lots of aircraft modeling videos. I didn’t waste any time and I bought my first kits, (2 Eduard Spitfires (1/72) and a Kinetic F 16 Block 52+ HAF (1/48), which are actually my favorite aircrafts), paints and an H&S Ultra 2 in 1 airbrush. I had almost no experience in scale modeling (only a Revell A320 and a Revell Leopard 2A6, almost 5 years ago), but I have a lot of experience in general manufacturing, as I used to spend the most of my day in my university’s laboratories, prior to virus outbreak.
I made this thread in order to share some photos of the Kinetic’s F 16 and also to ask about advices from people who have built this kit. For the Spitfires I will make another thread.
I am using reference photos from a book called "Vipers under the skin".  The most colours I am using are AK's 3rd gen acrylics, I am also using some TAMIYA acrylics and Humbrol Enamels.
I started this thread a little bit late, but I have a lot work to do in my project.
I started with the cockpit, which have nice details but I found that some swithes are wrong. I ve used AK's 3rd gen acrylics for as base colors (Intense black as priming and then I sprayed 80% sky gray + 20% england grey as base color). For the details I also used some AKs 3rd gen, some TAMIYA acrylics and Humbrol Enamels.
I used 0.2mm Nozzle, cause my H&S Ultra came with 0.2mm aircap as an 0.4mm aircap (a known issue to them for the lattest batches, but I have received the replacement part). For detailing I used DaVinci NOVA 10/0 and Winsor and Newton 111 3/0 synthetic brushes.
Then the inlet followed, I made some fitting testing und I painted it inside. I used white with very little sky gray, also I used Mr.Surfacer 1200 in order to fill some gaps.
After the Inlet I started paintig the exhaust. As you can see in the pictures I tried to fill some flaws caused by the mould. At first I painted with AK's 3rd gen Intense White mixed with only a little of Sky Grey. Then I sprayed some smoke lines (following my referense pictures and my experience with the engine) with Intense Black, in the end I further weathered it with a mix (using again the refernce pictures) of Winsor & Newton Wintor Ivory Black and Abteilung Dark Rust oil paints (I used a No 8 Synthetic Flat Brush). I didn't thin the mix prior to the application (as this oils have relatively low viscosity), but I only used AK's odorless enamel thinner to remove the excess paint. I used the same processes for the afterburner chamber and the exhaust nozzle connector but I tried to make a heavier weathering, using two tones of the weathering mix (a blacker and a browner one).
49803303341_01d6be965b_m.jpg49803302956_3e521442c9_m.jpg49802750963_b034e18344_m.jpg49802749523_8d41440690_m.jpg
For the inside part of the exhaust nozzle I used a mix of White and Medium Grey mix, trying to replicate the ceramic material. And I weathered it using different tones of the weathering mixture. The most difficult part was the exterior painting. As a base I painted it black and then with natural steel metalic color. I made a mix using black and medium grey to paint the smoke and then I tried to shade every fin using the previous weathering mix (Ivory Black and Dark rust).
For the wheel bay I used AK's Intense white and Intense Black for pre shading, AK Panelliner for grey camo and Winsor & Newton Wintor Ivory Black oil paint for weathering.
DSC_0451.JPG.18e28cab679bd08f4104769b36a1b6a7.JPG813008487_DSC_0469(1).jpg.bed30c74d7f1065552807248e75e4c6d.jpg
The dry fittings continue.....
1.jpg.acb43162253c0c91e4aec7a061910733.j
But today I really made big progress, I finished weathering on wheel bays and finally I glued the inlet and the main wheel bay with the fuselage. I made some dry fitting, so I managed to have a good result. The inlet was a little bit tricky and needed a lot of sanding and putty, but in the end the result was satisfying. Tomorrow I am planning to glue the three fuselage parts. I have also finished the assembly of the weapons and the drop off tanks. I use as a reference picture of a F 16D Block52+, so I am planning to use 2 370 gallon tanks, 2 Iris Ts, 2 120 AMRAAMs and 2 AGM 88 HARMs, allong with the CFTs and LANTIRN targeting and naviagation pods.
58556501_DSC_0472(1).jpg.b90f0058c4151312084133766_DSC_0474(1).jpg.a0de3ddd6430c
I know that it looks overweathered, but I think that the result is very close with the reference pictures. HAF's F 16 are really weathered, due to their use.
Today I finally assemblied the three fuselaga parts. There weren't many fitting issues, but before the final assembly, I made lots of dry fittings. The biggest issue I had was with the gun cover, which had a slightly smaller curvature, after extensive use of putty and sanding, I think that I manage to fix it.
150719627_DSC_0484(1).jpg.ff5a176f404678
As for the nose section I hadn't too much problems, but I haven't glued the nose and the side panels yet. The CFTs dry fitting was also really good, I didn't open holes and I positioned them using their silhouette.
1371193381_DSC_0479(1).jpg.ba55d9c4ce4051103063964_DSC_0481(1).jpg.8eb1569f93196
2031934211_DSC_0482(1).jpg.46d23d73658541.jpg.104ab078228825c5cdf90f3874d7cb72.j
As you can see in the pictures I glued the CFTs and assembled the vertical stabilizer. The CFTs' fitting was really good, especially on the left one. While building the vertical stabilizer the following question came into my mind: should I paint the vertical stabilizer and the fuselage separately and then glue them or glue them and paint them together?
DSC_0487.jpg.fd4c8a76d82c162df1cc99fd608DSC_0493.jpg.bddff330f8ade3cd9352d4af3feDSC_0494.jpg.c4015ff561b5289e5c5cebaff67
Edited by iceman98
Hi everyone, hope you are safe and have a nice month!!!
These days I filled some gaps with putty and sanded them (I fixed some large gaps on the CFTS and the parts mentioned in the previous post), but still there is a lot word to do, especially in the nose section. Also I tried the fitment of almost every part of the fuselage and repaired some problems caused by the molds.
1448585076_DSC_0499(1).jpg.1726e9042eea11279026879_DSC_0498(1).jpg.826e80f31b74c
For the side nose parts I used some blu tack in order to adjust them, I haven't glued them since I am not sure if I must fix the nose first. (just to be sure I will add some bolts as counter-weight).
818761226_DSC_0501(1).jpg.2a350ac0196c4f453803251_DSC_0500(1).jpg.c90f5f3f1b6c0a
Last week I assembled the nose section.
I used blu tack to position the side parts. With the addition of blu tack I prevented the sinking of the parts.
Then I placed the parts and I prepared them for putty application using masking tape. I tried to have a smooth transition on the sides and I left a large gap on the bottom.
I used an old blade on my hobby knife to apply the putty. In order to properly fill the gaps I applied putty 4 times.
Then I started sanding them, I used grit 600, 1500, 3000 wet sandpapers soaked with AK Odourless Thinner (I believe that you can use also white spirit or turpentine), thinner helped me to achieve a smooth result really fast.
Finally I reopened the filled holes and rescribed the panel lines
