AdrianMF Posted May 15, 2020 Author Share Posted May 15, 2020 Thanks Gents! Today’s crazy notion involved getting the cowling sides a bit rounder. So i put them inside a spare plumbing fitting (inside dia 15mm) and dunked it in boiling water for 5 minutes. I remembered to drink from the other mug with the tea in it! So now I can cut a piece to fit around my “polo mint” with a butt join and glue it on. Because the curve is there and the joint won’t be stressed I can use Contacta not CA. The polo needs to be inset 1.5mm from the back edge so it overlaps the nacelle properly. When that’s dries a bit I can pop the engine fronts in and add some more loops of card ready to sand down a rounded front lip. 9 Link to comment Share on other sites More sharing options...
Hewy Posted May 15, 2020 Share Posted May 15, 2020 Very clever adrian ,some great modelling ideas put in practice 1 1 Link to comment Share on other sites More sharing options...
modelling minion Posted May 15, 2020 Share Posted May 15, 2020 As Glynn says, some excellent proper modelling going on here. And well done remembering to drink from the right cup! 2 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 15, 2020 Author Share Posted May 15, 2020 Had to get my last group call of the week done and then I could do this: That can dry overnight and then I can add the engines and the inner circles for the front lip. 10 Link to comment Share on other sites More sharing options...
Hewy Posted May 15, 2020 Share Posted May 15, 2020 Looks a great fit 1 Link to comment Share on other sites More sharing options...
John Posted May 15, 2020 Share Posted May 15, 2020 Lovely work, and probably still easier than building the MPM kit 😁 John 1 3 Link to comment Share on other sites More sharing options...
CedB Posted May 16, 2020 Share Posted May 16, 2020 Now I can see what you were up to! Great technique Adrian 1 Link to comment Share on other sites More sharing options...
modelling minion Posted May 16, 2020 Share Posted May 16, 2020 Very nice work Adrian. 1 Link to comment Share on other sites More sharing options...
stevej60 Posted May 16, 2020 Share Posted May 16, 2020 Some great engineering here Adrian. 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 16, 2020 Author Share Posted May 16, 2020 5 hours ago, CedB said: Now I can see what you were up to! Sorry it didn’t turn into a Flamingo Christmas tree decoration Ced! Blue Peter was so much better than this... So the first internal wraps have been added. They go up against the engine baseplate and will be sanded back to the level of the outer cowling, which is marked with black Sharpie to tell me when I get there: This layer gets painted black on the inside because I won’t be able to reach it when the front rings are on. Then two narrow wraps were added to bring the cowling in at the front. I’ve doused it all with some Tamiya green cap and when it’s dry I can sand in the curved front. 7 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 16, 2020 Author Share Posted May 16, 2020 One down: 15 Link to comment Share on other sites More sharing options...
CedB Posted May 16, 2020 Share Posted May 16, 2020 Very nice Adrian and a great technique for getting round cowlings - I like it! 1 Link to comment Share on other sites More sharing options...
modelling minion Posted May 16, 2020 Share Posted May 16, 2020 Yet more excellent work Adrian and resulting in a very nice looking cowling. 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted May 16, 2020 Share Posted May 16, 2020 Most impressive scratch-building sir ! 1 Link to comment Share on other sites More sharing options...
Dansk Posted May 17, 2020 Share Posted May 17, 2020 Some awesome work Adrian, this is gonna turn out great 1 Link to comment Share on other sites More sharing options...
PeterB Posted May 17, 2020 Share Posted May 17, 2020 Hi Adrian, Marked improvement on the original "fat " cowlings. Pete 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 25, 2020 Author Share Posted May 25, 2020 I’m back to the Hudson today: The undercarriage and has been changed considerably to make it retract. Whilst I really appreciated this as a boy, I’ve since changed my mind and I’m changing it to look more accurate. In doing so I have (re)learned that pre-CAD kit parts aren’t necessarily the same size on both sides... 11 Link to comment Share on other sites More sharing options...
Hewy Posted May 25, 2020 Share Posted May 25, 2020 Very interesting that the parts aren't identical each side, are you sure your not digging a deep hole,there are a lot of styrene crumbs there 1 Link to comment Share on other sites More sharing options...
modelling minion Posted May 25, 2020 Share Posted May 25, 2020 Good to see your Hudson getting some attention again Adrian, some interesting work going on here. 1 Link to comment Share on other sites More sharing options...
stevehnz Posted May 25, 2020 Share Posted May 25, 2020 I've been neglecting my homework on this one, I do like your ideas for the nacelles Adrian, something for me to try & remember come the day I dig out my one with it's Kiwi markings. Steve. 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 25, 2020 Author Share Posted May 25, 2020 1 hour ago, Hewy said: are you sure your not digging a deep hole Hmm. I’m getting there, just not sure whether it’s to a new set of wheels or the bottom of a hole! the working wheels are hinged high up in the wing because it’s easier to mould the hinge up there. That means the legs are long and they go too far back when retracted. So you have to shorten the wheel well: You can see how much shorter the legs are in reality: I think I’ve finished messing around now: The legs fit snugly into holes I’ve drilled in chunks of 1.5mm card stuck into the nacelles. I need to putty up the back of the nacelle, sand it down and add some proper struttery to the legs. I could go on with the wheel well detailing but I have a Hudson to build... 10 Link to comment Share on other sites More sharing options...
mick b Posted May 25, 2020 Share Posted May 25, 2020 On 5/16/2020 at 1:58 PM, AdrianMF said: One down: Excellent work Adrian but these may have saved you some time? https://www.djparkins.com/product.php?productid=18028&cat=286&page=1 Mike 1 1 Link to comment Share on other sites More sharing options...
CedB Posted May 25, 2020 Share Posted May 25, 2020 Nice work Adrian - it's almost like you've created a 'build your own wheel bay kit'… have you thought about an AM company? 1 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 25, 2020 Author Share Posted May 25, 2020 37 minutes ago, mick b said: these may have saved you some time? Nah, cheating. 37 minutes ago, CedB said: build your own wheel bay kit Good online walkthrough photo sets are a mixed blessing... 1 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted May 26, 2020 Author Share Posted May 26, 2020 I’ve assembled the nacelles and filled the unwanted holes: The nacelles need a sand and a tidy, then they can get stuck to the wings. While I was holding a ball of Milliput in my hands I did a whole lot of other filling that needed to get done. 8 Link to comment Share on other sites More sharing options...
