I completed this huge model a few months ago - it's the stunning HK Models 1/32nd Lancaster combined with Iconic Air's Dambuster Conversion. The conversion set provides the modified bomb bay set up, the bomb itself, as well as a decal sheet for the 617 Squadron aircraft. I have chosen Maltby's aircraft, coded AJ-J.
Paints were from Hannants' Xtracolour range of enamels.
Regards,
Rob
  • Like 34
On 4/13/2020 at 1:28 PM, SAT69 said:
Absolutely gorgeous! What is the kit like to build?
Thank you. I found the tolerances very tight and you need to get everything lined up perfectly before joining the fuselage otherwise you'll hear a very unpleasant crunching sound... The engine cowlings again took a lot of careful alignment and are a tight fit to the wing. The transparencies are exceptional and some of the clearest I've seen. The last problem is the sheer size of it and it's a big model to wrestle with!
On 4/13/2020 at 8:35 PM, woody37 said:
Is this the one you had at Telford next to Toms Halifax? They looked fantastic together. Cracking beast :)
Yes indeed it was - and thank you!
On 4/13/2020 at 8:46 PM, bentwaters81tfw said:
Good to see that again Rob.
When are you doing that 1/24 Mk IX Spit?
The Spit remains on the to-do pile, Frank. I need to summon up the courage to tackle all that resin.
Regards to all,
Rob
On 4/13/2020 at 3:53 PM, exdraken said:
Nice!
Looking at it on my phone, it coukd be any size though... any reference?
Span must be enormous!
It's about 3 and a half feet wingspan.
So about a good meter in conventional units :devil:
Not as much as expected!
