Johnny Checketts' D-Day Mk V
Well before the arrival of Airfix's new 1/72 Mk Vc, I'm gonna try and sneak this one in; an Eduard Mk IX with the nose from an extra Mk V fuselage from a Sword Seafire kit (and spare oil cooler from an Airfix Mk I/II/V kit).
Just some minor surgery required (hopefully).
  • Like 12
4 hours ago, stevehnz said:
 a genuine Kiwi ace thrown in
Johnny Checketts must have been quite a guy, an ace decorated by the RAF, the USAAF and the Polish Air Force. It's the Polish connection that first made me aware of him, he was the leader of 142 Wing during D-Day and 303 Sqn was part of that Wing.
So I'm including this as part of my ongoing 303 Sqn collection.
I've got some decals for Checketts' Vc from the Sword kit built as RF-Q in the pic above.
  • Like 11
Well, I'm afraid I'll have to wait for the new Airfix kit to build this one - the Sword nose does not fit the Eduard fuselage and this has been binned.
It started out promising.
But aligning the Sword cowls (approximately 2 billion times) resulted in the requirement for a much wider undercowl than the Sword one. So I cut in half to allow for a centerline shim.
About the hundredth time it all came apart in my hand trying to place a shim I gave up and tossed it, once to the floor and once into the trash can.
  • Sad 8
Hey Cookie, couldn't you glue in a strip on the inside of the nose and fill the rest of the gap with putty?
Please factor in that I've never done Spitfire customizing... or even built a Spitfire 🙂 .... So this may be the silliest remark ever.
Thanks everybody, live and learn!
That would be a viable plan too, the nose was just too fragile with 5 butt joins all having to hold at once, but the biggest problem would have been if it had gone together, no spinner would have been big enough to fit the new nose. The shapes are just too different, the Sword nose needs to be wider at the back to fit the Eduard fuselage and then would need to taper to the same size at the spinner backplate, which would require some sort of professional sculpting.
The Airfix Mk 22 nose was a little narrow for the Eduard fuselage, but fit just fine with some spacers:
IMG_4394_zpsfzpq0fjt.jpg&key=5248073de08
I thought adding a Sword Mk V nose would be much simpler than that, but guess not!
  • 1 year later...
Sorry Cookie
Just a couple of quick questions about this aircraft,  were you able to ascertain if the C wing cannon bulges were wide or the later narrow versions please?  I am assuming it was clipped wing.
I ask because I am looking to do the same aircraft in 1/48.
And will you now be doing this one now with the Airfix 1/72 kit; it is a nice model to build.
Hi @Olmec Head, I saw one pic of this aircraft and it had the narrow cannon bulges and I'm pretty sure it had clipped wings.
I have purchased the 1/72 Airfix kit for just this purpose, and made sure to grab a couple of spares box narrow cannon bulges from an AZ Mk IX.
It will have been built with the wide bulges, but the panels could have been replaced.
I've just received Wojtek Matusiak's Polish Wings Spitfire Mk.V volume 2, and was looking for just this point - and the elevators.  The only examples I could find with the thin bulges were an MAxxxx and an MHxxx.  As late as a JGxxx still hade the wide ones.  However the MAxxx still had the old elevators - couldn't tell with the later one.  The only example in the book clearly with the later elevators was a rebuild Rxxxx!  (The book obviously has the full serials, but it is downstairs and we've closed up for the night.)
Thanks Graham, I didn't think about the elevators, I presume these would be the extended horn version, I didn't even consider about that.
I would also guess that the cannon bulges would be narrow as well, which is good as I have the C Wing conversion set for the Airfix 1/48 Vb with the narrow bulges!
I am looking to do the Airfix and Special Hobby 1/48 Spitfire Vc  as a tandem build.  But with the need to chop about both kits, it is receding into maybe next month.
I just built the Airfix new 1/72 Spitfire Vc as a SAAF aircraft for the Africa GB, its a nice kit without any gotchas.  Interestingly, the nose width is less than the Airfix 1/72 Spitfire 1a which suggests that the 1970s Airfix Spitfire 1a was accurate.
  • 4 weeks later...
Hi @Olmec Head and @Graham Boak, I just found this review of the 1/48 Hasegawa Vc and there is a photo of the actual aircraft near the bottom of this link:
https://modelingmadness.com/review/allies/gb/spits/presspit5.htm
I've seen a photo of it with the D-Day stripes in Red Kite's 303 Sqn series, but no longer have access to it. I definitely recall it having the narrow cannon bulges in that pic - but still that opinion is based on my quite possibly faulty memory of a photo.
I'm pretty sure the Sword instructions in the following link are correct:
https://www.super-hobby.com/products/Supermarine-Spitfire-Mk.Vc-3113197.html#gallery_start
