Terry1954 Posted May 18, 2020 Share Posted May 18, 2020 Stunning work Beefy. I have one of those gyro cutters. It took me a while to get the hang of it, but when I do it correctly, its great. Terry 1 Link to comment Share on other sites More sharing options...
Dads203 Posted May 18, 2020 Share Posted May 18, 2020 Just catching up Beefy, it’s now looking fantastic with some paint on fella, really nice indeed. 1 Link to comment Share on other sites More sharing options...
franco1964 Posted May 18, 2020 Share Posted May 18, 2020 Thanks for your explanations beefy, your railing work is near the perfection! Good job! 1 Link to comment Share on other sites More sharing options...
beefy66 Posted May 26, 2020 Author Share Posted May 26, 2020 Well it has been a bit of a slow week on this build to hot to be inside for a few but some small progress made I have scratch built one of the missing bridge lockers looks sort of nearly there added a few more ladders and bascket things I think these might have been for the side netting storage Stay Safe beefy 12 Link to comment Share on other sites More sharing options...
JohnWS Posted May 26, 2020 Share Posted May 26, 2020 Luv the detail, beefy. John 1 Link to comment Share on other sites More sharing options...
robgizlu Posted May 26, 2020 Share Posted May 26, 2020 11 minutes ago, JohnWS said: Luv the detail, beefy. John Me too - and I continue to applaud that Oil Canning!!! Rob 1 Link to comment Share on other sites More sharing options...
franco1964 Posted May 26, 2020 Share Posted May 26, 2020 Nice work beefy! The hull work, for me, is a real plus! Go, go, go Beefy. 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted May 26, 2020 Share Posted May 26, 2020 Looking really good Beefy. I love that twin open (I assume 40mm) mount, and as Rob says, that Oil Canning really does look superb. Terry 2 Link to comment Share on other sites More sharing options...
longshanks Posted May 26, 2020 Share Posted May 26, 2020 Great detail I love that canning, superb Kev 2 Link to comment Share on other sites More sharing options...
beefy66 Posted May 27, 2020 Author Share Posted May 27, 2020 Gent's thanks for all the kind words with more work done on some of the deck fittings aiming director and what I think is the grenade launcher ? and the ships motor launches. Filled the deck holes with some scrap PE to make it look like a plate at the bottom of the ladders will paint and scratch it to make it look worn. Then had a nightmare with one of the ladders while folding the step plates it just fell apart my clumsy hands Will have to rebuild it and hope it looks OK Also looking at the life rafts they have a PE insert but not sure as weather to use not sure if the fit parts just look ok or with the PE what do you lot think ? PE dry fitted to the left ones and top one just primed. Stay Safe beefy 13 Link to comment Share on other sites More sharing options...
JohnWS Posted May 27, 2020 Share Posted May 27, 2020 The molded base on those rafts doesn't look too bad, while surprising the PE looks a little bulkier in the photo. For me, it would come down to whether I'd want bigger openings between the slats, or not. Both look pretty good, so IMHO going with either the kit rafts or the PE would be okay. John 3 Link to comment Share on other sites More sharing options...
Gisbod Posted May 27, 2020 Share Posted May 27, 2020 Good stuff Beefy, I was doubtful about the oil canning effect, but I have to say it looks good! Keep it up, Guy 1 Link to comment Share on other sites More sharing options...
Dancona Posted May 27, 2020 Share Posted May 27, 2020 I can only agree with all of the other comments, you have nailed that "oil canning" lovely job ! 2 Link to comment Share on other sites More sharing options...
robgizlu Posted May 27, 2020 Share Posted May 27, 2020 6 hours ago, beefy66 said: Gent's thanks for all the kind words with more work done on some of the deck fittings aiming director and what I think is the grenade launcher ? and the ships motor launches. Filled the deck holes with some scrap PE to make it look like a plate at the bottom of the ladders will paint and scratch it to make it look worn. Then had a nightmare with one of the ladders while folding the step plates it just fell apart my clumsy hands Also looking at the life rafts they have a PE insert but not sure as weather to use not sure if the fit parts just look ok or with the PE what do you lot think ? PE dry fitted to the left ones and top one just primed. Stay Safe beefy I think the etch looks a bit clunky in comparison. The originals look really neat Rob 3 Link to comment Share on other sites More sharing options...
Chewbacca Posted May 27, 2020 Share Posted May 27, 2020 I think for the PE to work well, you'd need to cut away the plastic underneath. But that's a one way trip for something that isn't guaranteed to be better. Personally I'd stick with the plastic. 2 Link to comment Share on other sites More sharing options...
Gisbod Posted May 27, 2020 Share Posted May 27, 2020 Agreed, I do think you have to pick and choose the PE, I find kit parts are often a better choice.. Guy 1 Link to comment Share on other sites More sharing options...
beefy66 Posted May 28, 2020 Author Share Posted May 28, 2020 Well after a bit more research ( Yes i do look for things myself sometimes) I found this photo on the link @JohnWS showing the planking to be quite wide and on another photo it shows other stuff stored inside so will add some bits a bob,s and use the PE. And on a small update a few more bits added deck crane for the torpedo loading beefed up with some scrap PE fret the joints where horrible and some rails fitted to bridge area. Very curvy this bit for top of bridge. and starting on the upper deck Stay Safe beefy 10 Link to comment Share on other sites More sharing options...
robgizlu Posted May 28, 2020 Share Posted May 28, 2020 Dear Beefy Please can you do all my railings for me? Many Thanks Rob Matthews 7 Link to comment Share on other sites More sharing options...
beefy66 Posted May 28, 2020 Author Share Posted May 28, 2020 1 minute ago, robgizlu said: Please can you do all my railings for me? Hi Rob This kit makes it look easy because you have a small lip at the edge of all the decks so when fitting I can just do small sections and work my way around while gluing into place bit of a cheat really Stay Safe beefy 3 Link to comment Share on other sites More sharing options...
Terry1954 Posted May 28, 2020 Share Posted May 28, 2020 As Rob suggests, those etch railings look superb. I've never done etch railings on a warship, largely as I haven't built (or at least completed) one since they have been readily available! I will have to do it one day soon, but slightly dreading the prospect! Terry 1 Link to comment Share on other sites More sharing options...
beefy66 Posted May 28, 2020 Author Share Posted May 28, 2020 3 minutes ago, Terry1954 said: As Rob suggests, those etch railings look superb. I've never done etch railings on a warship, largely as I haven't built (or at least completed) one since they have been readily available! I will have to do it one day soon, but slightly dreading the prospect! Terry Thanks Gent's you are to kind but I do appreciate the kind words and help Terry the railings really are not that difficult with a bit of patience and a good optivisor and I have plenty of time on my hands for now so quite enjoying this build just sorting something out for the base to get that ready for construction Stay Safe beefy 2 1 Link to comment Share on other sites More sharing options...
longshanks Posted May 28, 2020 Share Posted May 28, 2020 Got to love a man who can do PE railings with ease and modesty Stay safe Kev 1 5 Link to comment Share on other sites More sharing options...
Terry1954 Posted May 28, 2020 Share Posted May 28, 2020 8 hours ago, beefy66 said: I love the detail in that picture Beefy, a real help for modellers of these stalwart destroyers. I was intruiged to notice the "kill" markings on the outside of the bridge deck sidewalls. A bit of a tally for this ship I'd say. Terry 3 Link to comment Share on other sites More sharing options...
Chewbacca Posted May 28, 2020 Share Posted May 28, 2020 8 hours ago, beefy66 said: I know earlier I said go with the plastic for the inside of the floats but seeing the float the bottom of this image I'm no longer convinced. The straps are much wider than I would expect in a British float so I think the PE would work (with the same caveat that I put in above that you'd need to cut away the plastic) 3 Link to comment Share on other sites More sharing options...
Bugle07 Posted May 28, 2020 Share Posted May 28, 2020 Top notch pe work there Beefy, great job! Geoff 1 Link to comment Share on other sites More sharing options...
