phantom61 928 Posted April 9, 2020 Share Posted April 9, 2020 Hello Mates... I'm looking for photos or draw for the flight deck of HMS Endurance ... I'm finishing this Lynx Has3 ICE and I'd like to make a portion of the flight deck grazie Silvano 5 Link to post Share on other sites
bootneck 4,272 Posted April 9, 2020 Share Posted April 9, 2020 Hello Silvano, it is good that you have posted a photo of the second HMS Endurance, otherwise you probably would have had photos and responses of the first 'Falklands era' vessel. Mike 1 Link to post Share on other sites
Chewbacca 2,492 Posted April 10, 2020 Share Posted April 10, 2020 (edited) Hi Silvano, May I ask what more detail do you need? That photograph is pretty clear and coupled with the one next to it in your Flickr photostream you've got a very good plan view. Fortunately ENDURANCE's hull sides are pretty much straight at the flight deck (though they do taper in slight aft of the bum line (the aft of the two thwartships lines) so based on the fact that we know the beam at its maximum point is 17.9m, you can work out that the fwd end of the flight deck would be 373mm in 1/48 or 559mm in 1/32. Taking your second Flickr image, you can then work out that the flight deck length (hanger door to the aft most point astern of the deck code) is 558mm (1/48) or 837mm (1/32). The bum line is 354mm/531mm aft of the hanger door and the breadth of the flight deck at its aft end (just before it turns inward) is 362mm/543mm). Flight deck markings are, IIRC, 4 inches wide. The diameter of the circle can be easily worked out from your model. In perfect conditions the nosewheel is positioned on the point where the centreline touches the circle, the deck lock will be in the centre hole of the harpoon grid and the main wheels will be on the circle. If you blow up the photo above you can see the pattern of ringbolts used for the tie down lashings That should give you enough basic info to draw up some suitable plans from that. I did a similar exercise last weekend drawing up a set of flight deck plans for a 1/48 Wasp which will sit on HECLA's flight deck. All I used was PowerPoint (better drawing programs are available!) and it took about 2 hours start to finish As an aside, may I ask where did you get the ground crew figures? Also I hope you don't mind me commenting that I couldn't help but notice you have put the tail skid on your model. This is a very common mistake that many RN Lynx modellers make because I think all of the kit instructions include it for all variants. The RN only used the tail skid for the first couple of years of the Lynx service - it was certainly gone by the early 1980s, well before either ENDURANCE converted to Lynx I was offered the chance to be the Flight Commander in the second ENDURANCE in about 1995; all of my friends who'd been on that flight said it was a great opportunity with some of the best flying that anyone could offer but I used to hate wearing an immersion suit to go flying so couldn't think of anything worse! Hope that helps. Edited April 10, 2020 by Chewbacca typo 2 1 Link to post Share on other sites
phantom61 928 Posted April 10, 2020 Author Share Posted April 10, 2020 (edited) 14 hours ago, Chewbacca said: Hi Silvano, May I ask what more detail do you need? That photograph is pretty clear and coupled with the one next to it in your Flickr photostream you've got a very good plan view. Fortunately ENDURANCE's hull sides are pretty much straight at the flight deck (though they do taper in slight aft of the bum line (the aft of the two thwartships lines) so based on the fact that we know the beam at its maximum point is 17.9m, you can work out that the fwd end of the flight deck would be 373mm in 1/48 or 559mm in 1/32. Taking your second Flickr image, you can then work out that the flight deck length (hanger door to the aft most point astern of the deck code) is 558mm (1/48) or 837mm (1/32). The bum line is 354mm/531mm aft of the hanger door and the breadth of the flight deck at its aft end (just before it turns inward) is 362mm/543mm). Flight deck markings are, IIRC, 4 inches wide. The diameter of the circle can be easily worked out from your model. In perfect conditions the nosewheel is positioned on the point where the centreline touches the circle, the deck lock will be in the centre hole of the harpoon grid and the main wheels will be on the circle. If you blow up the photo above you can see the pattern of ringbolts used for the tie down lashings That should give you enough basic info to draw up some suitable plans from that. I did a similar exercise last weekend drawing up a set of flight deck plans for a 1/48 Wasp which will sit on HECLA's flight deck. All I used was PowerPoint (better drawing programs are available!) and it took about 2 hours start to finish As an aside, may I ask where did you get the ground crew figures? Also I hope you don't mind me commenting that I couldn't help but notice you have put the tail skid on your model. This is a very common mistake that many RN Lynx modellers make because I think all of the kit instructions include it for all variants. The RN only used the tail skid for the first couple of years of the Lynx service - it was certainly gone by the early 1980s, well before either ENDURANCE converted to Lynx I was offered the chance to be the Flight Commander in the second ENDURANCE in about 1995; all of my friends who'd been on that flight said it was a great opportunity with some of the best flying that anyone could offer but I used to hate wearing an immersion suit to go flying so couldn't think of anything worse! Hope that helps. Ciao Chewbacca, thanks... thanks you so much for your valuable information... the ground crew figures they were produced by "the Aviation Workhop", now i think it's called, Air-Graphic models... I proceed to remove the tail skid a friend of mine prints me in 3D the HLG "Heligrid" can you confirm that it was about 2800mm or 110,28 inc diameter? I turn the measures into 1/72 I understand you ... I dive and I never think I can fly a helicopter grazie tanto Chewbacca... posted new pic progres... Ciao Silvano Edited April 10, 2020 by phantom61 Link to post Share on other sites
phantom61 928 Posted April 10, 2020 Author Share Posted April 10, 2020 @Chewbacca... I forgot ... tha Westland Lynx, is the 1/72 scale Hobby Boss model ciao Silvano Link to post Share on other sites
Chewbacca 2,492 Posted April 11, 2020 Share Posted April 11, 2020 Very impressive work for 1/72. According to the official Westland history (David Gibbings, "A Quiet Country Town: A Celebration of 100 Years of Westland at Yeovil", 2015) , the grid is 2.5m diameter. However, I was rummaging through my archives last night and found some some extracts of the Lynx aircrew manual which show the aircraft official dimensions. A quick look at those coupled with that data from Gibbings would suggest that I may have made some errors with the calculations I did yesterday and that the figures are a little on the high side. I won't be able to go over them again today but should be able to do so tomorrow. Very best regards 1 Link to post Share on other sites
phantom61 928 Posted April 11, 2020 Author Share Posted April 11, 2020 (edited) Ciao Chewbacca... Thank you very much for your help ... I eliminated the tail skid for the HLG I tried to look in the manufacturers' manuals ... something I found ... with a friend with the 3D printer, we did a test using the Diam.2,750m ... this is the result ... the all flight deck is excessive, so I will find a way to make the portion of the stern Do you like It ??? ciao e grazie Silvano Happy Easter Edited April 11, 2020 by phantom61 1 Link to post Share on other sites
Chewbacca 2,492 Posted April 12, 2020 Share Posted April 12, 2020 Hi Silvano, The 3D grid looks nice and you've done a good job of building the flight deck structure but the markings look wrong. Fundamentally, when the Lynx is on deck and the deck lock is engaged in the centre hole, the nose wheel should be on the point where the centreline touches the "bum-line" and the outer circle. The main-wheels, which for flying operations are canted out I think 35 deg (but I cannot be certain about the actual angle) should then also touch that circle. So, taking the marked up drawing from the aircrew manual, the wheels should follow a circle of radius 2.4 m. So taking that, and the known beam at the forward end of the flight deck as 17.9 m, I think that offers the following: Which suggest to me that your draft markings on the flight deck above are too far forward. Furthermore, the two circles are too large. If you look at your first photo in your first post, you'll see that the outer circle is roughly 1/3 of the width of the flight deck and the back end of it is broadly in line with the aft corners of the flight deck. Another measurement you can use to double check this is that a Lynx fuselage (from the tip of its radome to the centre of the tail rotor) is 11.92 m (166 mm in 1/72). The aircrew manual shows that the distance from deck lock to the centre of the tail rotor is 7.09 m (98.5mm in 1/72) and the drawing shows that the centre of the grid to the aft end of the flight deck is 65 mm. Thus you should have 98.5 - 65 = 33.5 mm of tail cone/pylon overhanging the flight deck with the Lynx in position on the grid. That's about in line with the second line of riverts forward from the tail pylon hinge. Hope that helps 1 Link to post Share on other sites
phantom61 928 Posted April 12, 2020 Author Share Posted April 12, 2020 outstanding Chewbacca... you have been very helpful I make the base with a Forex panel and when I have the 2mm plasticard I start the real construction ... I added the decals I had and some small jobs ... grazie Silvano Link to post Share on other sites
phantom61 928 Posted April 12, 2020 Author Share Posted April 12, 2020 the photo... sorry.... last but not least... the pitot... ciao Silvano Link to post Share on other sites
phantom61 928 Posted April 20, 2020 Author Share Posted April 20, 2020 Hi Mates... with the information of @Chewbacca and other photos found on the web... I started the construction a portion of the aft part of Flight Deck HMS Endurance 2005-2008 ... I hope you like them ciao Silvano 5 Link to post Share on other sites
Chewbacca 2,492 Posted April 20, 2020 Share Posted April 20, 2020 Hi Silvano, Glad to be of help. I still think the grid looks a bit too far forward in the cut plastic version comparing the rear of that to where the deck turns in, but I think it will look fine once it's all done. My Pilot when I was a Flight Commander rarely hit the grid first time anyway! Link to post Share on other sites
Geoff_B 502 Posted April 20, 2020 Share Posted April 20, 2020 Royal Navy/RN Helicopter Deck securing points 1/72 Etch Would this be any use ? Link to post Share on other sites
phantom61 928 Posted April 21, 2020 Author Share Posted April 21, 2020 23 hours ago, Geoff_B said: Royal Navy/RN Helicopter Deck securing points 1/72 Etch Would this be any use ? would have been helpful... thank you very much @Geoff_B obviously 3D printing has depth ... but in this scale, you can see little ... ciao Silvano Link to post Share on other sites
phantom61 928 Posted April 22, 2020 Author Share Posted April 22, 2020 hi... little progres on flight deck... would you know where to find photos or illustrations of the Fligt deck lower Tks... ciao Silvano 2 Link to post Share on other sites
phantom61 928 Posted April 27, 2020 Author Share Posted April 27, 2020 Hi mates... I continue in detail of the area under the flight deck ... the spars can be seen from the photos found, on what I did not know ... I put a little imagination ... hope you like it... ciao... Silvano 3 Link to post Share on other sites
Chewbacca 2,492 Posted April 28, 2020 Share Posted April 28, 2020 Hi Silvano, if you're going to that much detail under the deck where it can't be seen, one thing that will definitely be there is a drain from the deck lock grid. I think was in the middle but it's a long while since I was last standing on a flight deck! 1 Link to post Share on other sites
phantom61 928 Posted April 30, 2020 Author Share Posted April 30, 2020 Hi Mates... after a web search, I found these photos of the tie-downs used on the Royal Navy Flight decks ... tha modellers are a strange breed ... they always try to help each other ... help your friend with the 3d printer let's see what I can do... ciao Silvano Link to post Share on other sites
phantom61 928 Posted May 17, 2020 Author Share Posted May 17, 2020 Hi mates... new progress... here are the pictures... tie-down positioned... I also engraved the freight elevator these photos from a beautiful movie helped me I colored the part below flight deck with some "fantasy" decals ... but relevant... now the candeliers for the safety net ciao Silvano 4 Link to post Share on other sites
phantom61 928 Posted June 4, 2020 Author Share Posted June 4, 2020 Hi mates, we are in the final stages I sprayed a light gray on the tie-downs and then masked them ... followed by a dense acrylic color, then textured with a sponge ... 2 days of drying, then masks for the white circles ... little is missing ... do you have ideas for how to make safetynet ??? I tried with cotton and mosquito nets ... but it doesn't satisfy me ... ciao Silvano 1 Link to post Share on other sites
phantom61 928 Posted June 4, 2020 Author Share Posted June 4, 2020 I forgot ... I finished the Lynx Has-3 ICE Hobby Boss 1/72 ciao Silvano 5 Link to post Share on other sites
Richard E 1,519 Posted June 4, 2020 Share Posted June 4, 2020 39 minutes ago, phantom61 said: do you have ideas for how to make safetynet ??? I tried with cotton and mosquito nets ... but it doesn't satisfy me ... Excellent work so far Silvano. Could you use a stainless steel mesh like this to make the safety net ? Off topic - another view of your avatar ? 2020-05-14-009 (S) by richard.everett3, on Flickr 1 Link to post Share on other sites
phantom61 928 Posted July 29, 2020 Author Share Posted July 29, 2020 thank you @Chewbacca you reminded me that I have not posted photos of the "almost" finished display... I have to wait for the safety nets, because the solutions so far tried ... have not satisfied me Ciao Silvano 4 Link to post Share on other sites
