Bjorn Posted April 8, 2020 Share Posted April 8, 2020 I plan to build my favourite Flogger, the MiG-23BN in 1/48, using the Cold War studio nose correction set. I have a Trumpeter MiG-23MF in my stash and wonder if I could use that one instead of buying an expensive and mis-shaped Trumpeter BN? Are there any other external differences apart from the nose (and cockpit) and the rear bomb racks? And if so, did Trumpy care about them in their BN? 1 Link to comment Share on other sites More sharing options...
Jure Miljevic Posted April 8, 2020 Share Posted April 8, 2020 Hello Bjorn Engine nozzles differ substantially. Here is the one on MiG-23 MF (actually on MLD, but the nozzle looks the same as on MF) found here on Prime Portal: Here is a photo of MiG-23 BN nozzle, found on Aircraft Walkaround Center here: I was not aware of other differences, but while browsing for suitable engine nozzle photos I came across this page on ARC forum. Apparently, replacement of MF's nose wheel with a larger one and modifications of nose undercarriage doors are also necessary. I vaguely remember that AM MiG-23 nozzles had been available, although I do not know for which sub-type or in which scale. Cheers Jure 2 Link to comment Share on other sites More sharing options...
exdraken Posted April 10, 2020 Share Posted April 10, 2020 (edited) As stated above, big difference in nozzles. The BN / -27 has featherless / no petals outer nozzles. :Resin nozzles are awailable from Aires and Eduard for many -23 version, some open or closed includung the BN, or -27 An example: https://www.scalemates.com/de/kits/aires-4748-mig-23bn-late-exhaust-nozzle-opened--1156638 Edited April 10, 2020 by exdraken 1 Link to comment Share on other sites More sharing options...
Floggerman Posted April 12, 2020 Share Posted April 12, 2020 The front wheels are bigger (that's why the doors have a bulge, size is 570 x 140). The rudder had no dampers (the BN is closer to the M than to MF (for Trumpy all the same...)). The Delta-antenna on the right fixed wing. The fixed front part of the fin could have the shape of M or MF, check references. 2 Link to comment Share on other sites More sharing options...
Bjorn Posted April 13, 2020 Author Share Posted April 13, 2020 (edited) Thank you all! After all, it seems as if it is possible to convert the MF, since you have to buy lots of aftermarket parts anyway to correct all Trumpy's BN errors... Edited April 13, 2020 by Bjorn Link to comment Share on other sites More sharing options...
peterburns Posted April 13, 2020 Share Posted April 13, 2020 The intake splitter plate is also different as I recall Link to comment Share on other sites More sharing options...
Floggerman Posted April 14, 2020 Share Posted April 14, 2020 (edited) 15 hours ago, peterburns said: The intake splitter plate is also different as I recall No, it's not What you mean is the MiG-27. Edited April 14, 2020 by Floggerman Link to comment Share on other sites More sharing options...
