Sea Vixen - recce pod.
Dear Britmodeller,
I am new here, so let me say "Hello" for all of you.
I am a fan of the reconnaissance aviation and I would like to know some details about recce equipment of De Havilland Sea Vixen. I have plan to built one this model.
Best regards,
Stulee
The Vixen carried a pod on theS/B centre hard point, it carried two Vintern F95 cameras one forward facing & one 45o downward to port side, so it could see under the aircraft & long range on opposite wing. If you send me your e mail I have pictures regards Len
Hi that sounds very interesting any chance of a pic?
22 hours ago, Stulee said:
Dear Britmodeller,
Best regards,
Stulee
John
  • Thanks 2
I was going to say that I've seen it in the manual, but I have no way if uploading the pages, well done John!
I have seen it said that it is a modified Hunter drop tank (smaller type), don't know how right that is but the proportions seem similar enough for modelling purposes.
Thanks all of you guys! Hawker Hunter drop tank sounds good, but my first choice was Supermarine Scimitar :) .
Stulee
Larry the components drawing is from the FAW.2 IPC, the pod drawing is from the FAW.1 AP so I would assume both types could use the pod.
John
Good old F95's - wonder where they were first used ? Went on to Phantom, then Jaguar.....
As John says, both the FAW.1 & 2 used the same pod.
Probably the most well known example of a photo from the pod is the one of an 899 Sqn Sea Vixen FAW.1 refuelling an F-105D which was taken by a second Sea Vixen with the pod.
There's also a dramatic high altitude shot of the Isle of White and south coast taken from the same kit.
I would need to double check, but I think first RAF use of the Vinten F95 was in the early/mid 1950s with the Meteor FR.9 and PR.10.
It did serve for a long time, into the 1990s and went through various Mk numbers, at least to Mk6.
Standard fit on Harrier GR1/3, Sea Harrier FRS1/FA2 and T2/4/8.
Also in another recce pod carried by the 1st generation Harriers.
BFN
