G-IRTY Silver Spitfire - Quattro Stagioni - La Primavera - ***Finished***
Stagione
From Wikipedia
Quote
Stagione (Italian for "season") is an organizational system for presenting opera, often used by large houses. Typically each production is cast separately and has a brief but intensive run of performances. By contrast, companies that use a repertory system maintain a permanent company and rotate productions over many months or even years. Historically the stagione system has been preferred in Britain, the United States, and most large international operahouses.
Seems like a fitting way to describe the process I'll be following for my builds for my chosen subject.
G-IRTY, the Silver Spitfire, began life on the Castle Bromwich production line in late 1943 as the first of the block of 44 aircraft under contract B981687/39 as MJ271, LFIXc, with a RR built Merlin 66.
For this spring incarnation, I'll start off with a relatively simple Airfix Mk.IXc kit.
y4mMAAnnAYfhJxbTmz8Px65U6byiVrjOElIwnDn0
I have some aftermarket bits that might come into play later on, however I suspect that that won't be in this build.
  • Like 10
Finally found the time to do some actual plastic cutting & applying paint today.
anyways:
There is only one known picture of MJ271 during WWII and that is this:
y4mXE3Y3Y5gi3eHhAVmRc6soA23qMUCoX-sEXFgL
Judging from the lack of codes, the clean look and the pilot wearing not a normal flight helmet but a cap, this might very well be the delivery flight either from the factory, or with the MU before designation to 132 Sqn (which was to be the first user of this aircraft).
So just the sky band & spinner, and what seem to be light-coloured patches over gunports & camera.
Also, no yellow wing L/Es yet.
Oh, right, plastic.
This being the rather simpler airfix kit, there's not much to prepare.
Interior green in the appropriate places.
y4mUR4CYhovx9R0x39H1AidGHTeYXXPKfB0RCP3p
Also what goes for a cockpit has been assembled and splashed with some colour.
y4mRx4NfZ3DxyAydyNA-Yf0whFpX1L9XKOXMGgGa
The clear drop is a bit of CA glue to form a headrest - and of course closer inspection of the in-flight picture doesn't show one.
That'll go then.
As there is a pilot figure included, I'll go for an in-flight look as well.
Probably mount this with a stand with a magnetic option, so I'll have to add a metal strip or nut that doesn't interfere with the fit.
Pilot has had some surgery to prevent 'im sitting too high (shaved a couple of pounds off his derriere - faster than a diet).
More drastically, I've made a real head-turner by taking a saw to his noggin :P
Before:
y4mbvgHyqX4pHXtFuxZ1MmZdmX2Ir2vzeJtLSO_1
After:
y4maLCByPAV-deQ4cHZihDIMHimvPptt-uyNES0d
Not glued in place yet, so the headrest mod is reversible.
More tomorrow.
Lovely day out in the sunshine, today.
Small snag:
A short shot on the gunsight.
In a rather prescient manner, our intrepid pilot (having survived major surgery) is perfectly poised to deliver a wallop to that errant device.
Replacement bit of transparent blister packaging will sort that out later.
y4m2MmMJYkvKn116szkfghny51ikf6OQYY0BkRGT
As this one is going to be in flight, I've slow-glued a piece of mounting bracket to the bottom wing.
I'll fudge a stand with a magnetic head somehow.
Edited by alt-92
anyways:
Nice that you had this picture included..
I have some more information about it as this was a sort of acceptance fligh before delivery to the Netherlands .
Th pilot is Dutch and his name is Frits Vijzelaar..
The whole story about G-IRTY and it Dutch connection is written by Coert Munk in the ( the Dutch Dakota association) DDA classic airlines magazine “Logboek”
cheers, Jan
Quote
Scrap packaging plastic as replacement gunsight.
y4mV1LJ46gHEg1gF9AdHzy-dFBV64o2TCqMP0g2f
And all buttoned up - good, clean wing joins without problems,  just a light scrape on the trailing edge.
Ready for primer and paint on the radiator housing, masked canopy.
y4mtQy3mu1VYZUvh8c_GBL-Fe5ELQS1SyaggxVbO
Progress (in small steps).
MSG on the undersides but I nearly forgot to add some spare PE in the radiators:
y4mS0Gn7JpxewxrxT3w6lXMESJvDDCmqP3cxMKZY
Kludged together stand with magnet, painted dark metallic.
Works pretty well:
y4mmv2iFLEnisVORBwbWuvPL6lC2RAppPr08Th83
Sky S on the rear fuse for the band:
y4mq_eEktc0DhHZFNXPmvddKL068FyDVVUF0y4HK
Cutting masking tape to 18" in scale.
y4mHwJS4GOrWuqDU-qO-4Gfot2KjNQUfWzU0T147
And in between some fettling on rear torque links on the AZ early Mk.IX I've been working on.
y4mg7z9IizTNegc5o9geQ48zglsPSqvW0bikjSFz
Somehow I managed to follow the instructions & placement holes which use the forward links, these should be backwards.
That one is nearly ready for markings.
y4mN_iSLPoRow5l64Q-LAM65R9psgvkCsZFDl5Vg
Edited by alt-92
  • 4 weeks later...
Masking the MSG (Tamiya XF 83).  Vallejo 71.273 on top - I prefer this to the XF-82 I think.
I'm going to 'cheat' here for the XF 82 dark green and use a masking set.
y4mkCQjZoqdxjMHLkWHmHaoKHU55GaJKkUlCp_NX
y4ml0acV8MXy3cyIm2ans4X0rQbOsqfxq3YxMKk5
Bump
Paintwork. Small corrections needed, masks and instructions don't quite match photographic evidence of the pattern on the starboard side beneath the cockpit.
y4mfI32XW2Pw5RhkonFumpi6e8Rb8gdvvNNUx1Z2
It's starting to look like a Spitfire :)
Ready for gloss coat as prep for the minimal decals - just the insignia & serial number.
Sky band unmasked, and no touchups needed there.
y4m4KouYzgoqB47F91o0ZllnKRjbzlw5BfWiL2Jj
  • 3 weeks later...
Rummaging in the spares box I did find some suitable roundels, and stenciling as well.
So the most visible ones are going on.
y4m5SW20ERDM7WIi2ZpZWMdF7-VHGmShbUGAWWne
y4mnSVYKKQZ6lATQbtRwhToKpz-qijdrYccxRzbs
1 hour ago, It's a disease said:
Any idea what that is sticking out of the wingtip?
Not sure, do you mean in the second picture?
It is lined up with the spray booth lid, maybe a trompe l' oeil?
8 minutes ago, It's a disease said:
Stbd upper.....
odd thing sticking out near the wingtip.
I think what you're seeing is an optical illusion: it's the aileron hinge line.
  • alt-92 changed the title to G-IRTY Silver Spitfire - Quattro Stagioni - La Primavera - ***Finished***
