Japan Ground Self Defense Force Type 16 Tamiya 1/35
Next build while in lockdown. Wanted something I could build up and leave complete for painting later. Thought of trying some modern armour so went for this one. Plan is to do it in "urban digital" squares (3x grey) for something different, inaccurate and to test my masking (going to print my own masks too).
Probably start the build at the weekend and take it slow (dont think I will do much more than OOTB)
49742429091_b03a97ec3e_b.jpg2020-04-06_02-34-36 by Robert Worth, on Flickr
11 minutes ago, Bullbasket said:
As I know more about neurosurgery that I do about JGSDF vehicles, is this a Whatif cammo scheme or did they actually paint it in this?
John.
Aye up John.
Will be a Whif i imagine. I know the Chinese like digi-cam though.
Regards,
Steve
44 minutes ago, fatfingers said:
Aye up John.
Regards,
Steve
Yep fully WHIF. Was tempted to go even further and put it as a Rebel Alliance vehicle from Star Wars but that may be a galaxy far away from my skill at masking.
Also no real evidence of kit stowage or mods so will leave that part
an example of digital mask. Plan to print on masking sheet (think I have stuff coming you can print on). Some of it isn't "jagged" enough. Each square unit  is (in this example) 5mm - may reduce that or perhaps do a combination of 3mm and 6mm to allow more variation. I did see a nice hexagon pattern today (more like "normal" camouflage but the edges are as well sides of a hexagon rather than being wavy ) so who knows, may try that instead.
49745404186_0763d1bbfe_c.jpgDigitalCam-Grid by Robert Worth, on Flickr
hmm printing on the vinyl not 100% successful - patience is needed to let the ink dry. run a 2nd attempt so will let it dry overnight (and definitetly the 3mm squares win)
So the build started. Some simple bits and some clear. The lights are coloured in with sharpie then backed with silver foil - personally I think its not a bad rendition. Glued and held together with tape to let it all go off
49760623658_7e05cc0195_b.jpgIMG_20200411_170027 by Robert Worth, on Flickr
49761153311_9b64bcb80b_b.jpgIMG_20200411_170036 by Robert Worth, on Flickr
49760623568_23c065f75e_b.jpgIMG_20200411_170049 by Robert Worth, on Flickr
6 minutes ago, phildagreek said:
Looks good, I’m not sure I could deal with those masks though, they sent my eyes a bit funny just sat here looking at them.
Good luck!
only need probably 1/4 of them. Have splatted paint on my test kit (1/72 goose) so will do a couple of tests - may end up tri-tone green if the 3 i have in stock work well (if not will go with tri-tone grey)
Good luck!
Phil, have used some of my masks (printed on to masking vinyl) on my test kit - using tri-tine green. They go on ok (3mm is a tad small but will stick with it, could do a mix of 3mm and 5mm perhaps). second green is painted so will mask and paint the 3rd tomorrow to see if it works.
Have to love Tamiya kits. Go together really well. This one has moveable steering but parts not overly fiddly... really enjoying it
49765869337_09ac4aa980_b.jpgIMG_20200412_171307 by Robert Worth, on Flickr
49765009848_392a6bdf47_b.jpgIMG_20200412_171257 by Robert Worth, on Flickr
49765009788_cf9a988936_b.jpgIMG_20200412_171318 by Robert Worth, on Flickr
and fimally my proof of concept for digital camouflage worked (could;ve done with a better contrast of greens but thats not the scheme I am going for). Mask goes on really well, just takes time to cut out!!! The 1/35 scale will give more scope for variation in pattern as well - and yes it will be tri-tone grey (not sure which grey paints yet but I like AK interactive as pre-thinned and Vallejo model air so will look at those).
49765541726_bd5a0e13b0_b.jpgIMG_20200412_175829 by Robert Worth, on Flickr
16 minutes ago, Hamden said:
Camo looks good Rob but very time consuming though!
Looking forward to seeing it on your Type 19
      Stay safe           Roger
time is something I have plenty of at the moment (well apart from work). But yes - probably 30 min masking for a 1/72 Goose (wingspan @ 15-20cm). I think it will make the Type 16 look different and will push me at a time when I dont have full access to all my modelling stuff, taking my time is part of the plan
more work. Suspension/drive train & wheels all done (rubber wheels which are ok but at least the hubs are removable to aid painting). On to the turret which, to me, is a really nice shape and calling out to be "digitised"
49770044462_7d17ab80e7_b.jpgIMG_20200413_154009 by Robert Worth, on Flickr
49769718146_328cd58043_b.jpgIMG_20200413_155552 by Robert Worth, on Flickr
49770044452_36b565fd60_b.jpgIMG_20200413_170638 by Robert Worth, on Flickr
49769183108_189af125b2_b.jpgIMG_20200413_163953 by Robert Worth, on Flickr
49770045127_50e5ba6bc3_b.jpgIMG_20200413_163956 by Robert Worth, on Flickr
Decision on paint - AK Interactive going with
Sky Grey (light)
English Grey (medium)
Ash Grey (dark, just off black I think)
with the lower hull/running gear/wheel hubs the English Grey (or perhaps vary depending on the wheel)
oohhh tempted to go 4-tone with light stone from the AK Interactive Caunter set . Not to add colour but to provide a light contrast... will see when all paints arrive
Turret progressing (including drilling ~80 holes in the muzzle (not perfect but will get cleaned up a touch))
49774404061_0ce4774a57_b.jpgIMG_20200414_202003 by Robert Worth, on Flickr
49773874483_6fe19e0583_b.jpgIMG_20200414_202036 by Robert Worth, on Flickr
49773874393_3c65ca661e_b.jpgIMG_20200414_202026 by Robert Worth, on Flickr
