1/350 HMS Kent County Class Cruiser 1941
Never one to look a gift horse in the mouth i expect ill be needing some of that rob if nobody else is in the queue (gladly reimburse you for it of course ) regards colin
Rob
HMAS Sydney forecastle will need some etch if any going (after Cedwards of course). Name yr price! Royal Mail to Australia may be quicker than Latvia to UK...
9 hours ago, Pak75 said:
Rob
Hi Colin and Pak75 - Aplogies as I probably didn't word the phrase well.  What I was meaning to say was that anyone considering buying the Anti-skid from North Star should be aware that it is sufficient only for covering the Foc'sle area and would not be enough for any further such as the 4" gun areas.
I regret that I'll be hanging onto mine for the spares locker.  Whilst it is definitely a finer etch (in detail) IMO you'd be much better off seeking the sheet from Fretcetera https://www.scalelinkfretcetera.co.uk/product/sl32f31/ both in terms of amount and delivery time
Sorry if I inadvertedly misled !
Rob
No worries rob i will order some (im getting kinda worried about the pile of photo etch thats building up for this build lol  )but going off your build totally worth the effort
Hello again!!
First off - good and knowledgable people....can anyone tell me what these 2 obects are?  The first sits on the deck ventilators - the second on the superstructure deck...
DSCF9501_LI
DSCF9500_LI
Super-fast deliveery From White Ensign Models once again - much needed oars and ladders etc - essential - thanks WEM :clap:
DSCF9510
And some general progress shots..
DSCF9502
And thanks to whoever explained that -  The trick to bending etch is to press into an India rubber with whatever curved implement you are using - I am eternally grateful!
DSCF9503
DSCF9504
DSCF9505
DSCF9506
DSCF9507
DSCF9508
The turrets primed showed significnat spaces between the top etch and the pastic - a real drwback so it's back to the (invaluable) Mr Hibby Liquid putty.
DSCF9509
Likewise where I'd filled locating holes for rafts sat proud so back to re-sanding key areas
DSCF9512
Learning from Kent - 3mm masking tape  :yes:
DSCF9514
And since the red antifouling will be hidden within the base - I thought I'd experiment with the hairspray technique having read in one of the other BM sections (?avation and apologies to whoever did thsi first - I omitted to write down name and location) that it was possible with enamel Colourcoats paints!
The VERY happy answer is - IT IS.  Using just 2 layers of "Worn effects" (other brands are available), 20 mins after application of the red, I scrubbed with a bristled brush or used an acupuncture needle to "scratch" the top layer of paint.  The trick is to get water to the starch layer that will then lift (hopefully) giving a pleasing and natural chipped effect.
DSCF9515
DSCF9516
DSCF9517
I'll try the same on the hull sides with a base layer of 507C then worn effects then 507A over showing some chippig at water line and bow.
DSCF9518
Thanks for looking
Stay Safe Y'all
Rob
  • Like 25
Rob,
Could you post pics of the instruction steps regarding those two parts?
A bit of perspective might help ID them.
I'm thinking (tentatively) some sort of hoist arm and maybe damage control timber beams?
Tom
Like the weathering effects and it seems such a shame to have to paint all over that bling nice and neat work  👍
Stay Safe
beefy
Now looking at your bottom on a 'puter screen :hypnotised:
Totally awesome effect with the hairspray technique, going to look a real treat on the sides. Go for it
Stay safe
Kev
I'm quite surprised that the hairspray technique works with Colourcoats enamels Rob, as I always thought the idea was to wet the top surface which re-activated the underlying hairspray chemical allowing the paint to "flake" a bit. I'd assumed it was something to do with Acrylics themselves. Had no idea it would work with enamels too. You learn something every day!
I would be interested in @Jamie @ Sovereign Hobbies view.
Great looking hull effects.
Terry
Terry
Hi Terry,
I wrote a thread on exactly this a while ago using a Corsair as a test model. It works fine. It also works on lacquer paints.
Ithink this is one of these examples of a subject whereby someone presumed something, voiced it without ever troubling himself to test it first, and it got repeated and repeated until it became "common knowledge".
I certainly "knew" it wouldn't work until I realised I'd never once seen someone prove it so I got out the paint mule and gave it a go.
On 8/22/2020 at 5:19 PM, Modelholic said:
Rob,
Tom
Thanks Tom - here are the pics
Scan0002
part E35 might be shoring timbers as you suggest :hmmm:
Scan0001
and E6 ??
23 hours ago, RGL said:
So, whilst in the process of buying up stuff for my Kent, I order up the metaled deck (which got here really quickly from the UK) then I find that Joy yard wooden deck for the Kent has a PE focsle!  https://www.hobbyeasy.com/en/data/5cfzg2nkcv9rp5mrtwzf.html
I'm not surprised - kudos to them for their enterprise - wonder if they've been following the Blog ;)
21 hours ago, Jamie @ Sovereign Hobbies said:
Hi Terry,
Jamie - apologies for forgetting it was you and the Corsair.  Totally agree with you and Thanks!!!
Rob
FWIW I'm thinking (E6) a spreader for the funnel stays or similar. It's too short to be a derrick arm!
 and (E35) a pontoon to secure alongside the ship to aid in painting?
Just guesses I'm afraid.
Tom
Rob for part e6 how far to the cranes Jib arms go down could be a simplified rest for them when not in use and secured :hmmm:my thoughts.
beefy
beefy
My guess, as well.
John
The first looks like it could be spreaders/lead inlet for wireless aerials, there would be a lead from each end to the mid point of an aerial wire strung between the two masts (dipole aerial)
The second looks like it could be a raft/pontoon for painting the hull etc.
Thanks for the input Fellas.
Another intensive episode of masking gets us to this...
DSCF9520-1
DSCF9522-1
DSCF9523-1
still some left to do on the port Bridge superstructure - getting the angles right and the camo lines to align wasn't easy.
So - it's time to return to Kent that has sat on the sidelines, with work now on Berwick having brought it up to a similar stage.
I used a neutral Grey washon the deck as a trial with dark wash was a bit OTT.  It's subtle.
DSCF9524-1
It certainly adds depth to the moulded deck that I think is rather good.  Berwick is due a Wood veneer deck
So the remainder of today (after having watched 2 games of rugby...On a Tuesday!!!!!  Strange times) was spent applying wash to the deck and then a start on weathering to the anti-fouling and hull with oils.  I was a bit looser with Berwick's anti-fouling during painting and it's more effective.
DSCF9525-1
DSCF9526-1
DSCF9529-1 DSCF9528-1
DSCF9530
Thanks for looking
Rob
  • Like 12
These are going to look stunning together with the paint schemes and weathering 👍
Stay Safe
beefy
