Hi all
With this model I think I am going close a 12-month period in which I am going to finish 6. Something that I have never done.
Although I have some models in process, I did not feel like continuing with them, so I looked at the Bandai boxes related to STAR WARS that I have in hiding and decided on this kit.
What can I say about him that hasn't already been said? Gorgeous detail, gorgeous and finely detailed pieces and a perfect fit. A candy.
The construction is already quite advanced and I decided to start this post because I think I will not stop its assembly.
Of its assembly I can say that it has been a suffering due to the fact that the arrangement of the different pieces has been chaotic in sprues. If you had to build a leg you had to take a piece from sprue C1, another from sprue C2, another from sprue A and two other pieces from sprue B (it is an example, it has not literally been like this). Something that has been very heavy.
Well, the cockpit. I have painted it entirely using Vallejo MC paints.
Andrés S.
Hi everyone.
Edited by Andrés S.
I start with the painting process.
The base color indicated in the instructions is 45% white, 45 % neutral gray, 5% black and a little blue. But with this mixture you would get a too dark gray for my taste. Finally, I made it with 30% neutral gray, 70% white and a little blue.
I've done some dirt / shading with Gunze's H-333 and applied oil from the Vallejo range of effects.
Andrés S.
Sí, son unos kits magníficos tanto en la calidad de reproducción de detalles como en el ajuste entre las piezas. Son realmente muy recomendables.
Bueno, espero hacerles justicia a la calidad de estos kits con mi pintura.
Me alegro de que te guste.
Saludos.
Yes, they are magnificent kits both in the quality of reproduction of details and in the fit between the pieces. They are really highly recommended.
Well, I hope to do justice to the quality of these kits with my paint.
I'm glad you like it.
Greetings.
I continue with the paint applying Vallejo filters to simulate accumulated dirt and applying some chips.
Andrés S.
The painting phase has come to an end with highlighting the details with oil and varnishing everything with Vallejo satin.
Now I have the base problem. That I do not have and I will have to order from an online store and I do not remember if I keep or throw away the grass and other items to represent a terrain.
When I decide what to do with the base I will put it in ready for inspection.
Andrés S.
Edited by Andrés S.
  • Like 12
Thanks !!!
I think I will be able to get the necessary material for the land in online stores but it will take several days to arrive.
Cheers.
Andrés S.
  • 4 weeks later...
Hi.
Today the grass that I have had to order online has arrived. Doing the hobby like this is a .... If I hadn't been in this situation, I could have gone the next day to my usual store and got what I needed, but it can't be: not for now.
I would like to add some fallen tree branch and pigments to the feet. Regarding the base, I think I will have to make some arrangement with the frame of a photo frame.
And a general final photo to see how it looks.
Regards.
Andrés S.
  • Like 12
4 hours ago, The Chief Smeg said:
That grass looks superb; what is it please?
Thank you.
It is electrostatic grass of 2 and 4 mm in length of 3 different shades. Must be used with an electrostatic lawn applicator. The commercialized applicators are very expensive (from €50 to €100) but I made one following the steps of a YouTube video and it all cost me €6. I leave you the link in case you are interested in making the bases of your models.
He is from a Spanish modeler and speaks logically in Castilian but has subtitles and also just by seeing the images the process is well understood.
Regards.
Andrés S.
Penultimate step before being able to fit it into finished models: applying pigments to the feet.
I have used the references of Vallejo Siena Claro, Sombra Natural and Sombra Calcinada.
I have heard around that if the pigments have their fixing liquid but I have done it by putting them on the feet and distributing them with a brush dipped in water. To fix them, once the water has evaporated, I have sprayed matt varnish on them. I don't know if it will be the correct method but I have done so.
Andrés S.
On 4/29/2020 at 11:55 AM, Andrés S. said:I leave you the link in case you are interested in making the bases of your models.
Andrés, that is fantastic, thank you very much; as you say it is a very easy tutorial to follow and such a simple idea!
I hope you can make yours as easily as it turned out for me. You will see how it really works perfectly.
Andrés S.
What do you recommend for gluing the grass in place?
The first layer of grass should be glued with white glue, diluted approximately 20%, applied with a flat brush.
Once the glue is dry, it is recommended to use this glue but spray it for the next layers of grass. There are several brands of railway modeling that market it. It is recommended to use grass of a short length (2 mm) first to help the following layers, which should be somewhat longer (4 or 6 mm), to maintain vertically.
On YouTube there are several tutorial videos on how to use it. Most are to represent meadows in railway dioramas, but they are applicable to our needs.
  • 2 months later...
  • 3 weeks later...
Beautiful detailing, I especially like the dirt accumulated at the back of the cockpit floor - really brings it to life. But, having looked at the finished model (and the one I have still in its box), how much of the interior can actually be seen once it's closed up?
