Ima Penin Diaz
1/24 GEMINI under the Rogallo wing
The Gemini spacecraft is one of my favourite vehicles and I had a partially prebuilt one that I bought off of eBay and will rebuild it.
The hull taped together ... notice the decals ... well, they'll all get removed later!
Note the damage to the lower bit which resulted from disassembling the parts.
This version of the Gemini was to return for a landing on Terra Firma, not water, so landing gear has to be built.
On the left is the 1/48 Revell kit wherein the landing gear doors were part of the kit. I used this smaller version to create the pattern for the doors and cut them out.
Using Dymo tape to make the guide ...
... and the result.
With the interior bulkhead dry fit ... I need to determine the depth I can build of the bay.
Building the interior walls of the landing gear bays ...
... and done.
The eBay model didn't have the RCS portion so I used a piece of PVC plumbing pipe to make a new one ...
And filed a bevel onto the edge to fit the kit's hull pieces.
Drilled holes for the Thrusters and filled them with Aluminum tubing.
... and added styrene strips to recreate the shingles ...
That'll do for now ...
IPD
Excellent idea - I'm looking forward to following this build.
     Ive seen the real deal in books and articles before. Ive read it was a good idea but in practice was kind of a disaster. I think I remember something about the parachute. It was to be aerofoil in shape, to help the capsule glide back to earth ? Makes you wonder if thats where the idea of para-gliding came from ? Seeing as Im a fan of Gemini capsules I'm going to follow this build.
Dennis
You are correct ... and here's what inspired this build of mine.
It's an image from National Geographic magazine circa 1964 ...
The Landing Gear need to built from scratch, so-o-o ... a little styrene, a couple Aluminum tubes, a spring from a pen ...
... the Main Gear ...
... the Nose Gear ... I used the 1/48 kit's nose gear for a little reference
... and done.
... the Main Gear ... this dry fit indicated that the Gear were gonna be too long, so I shortened 'em ...
... the adjusted one on top. The other one will get shortened too.
The new RCS section, into which the Nose Gear will get fitted.
I made an inside surface to hold all the greeblies ...
Starting to look like something ...
Till next posting ...
IPD
Loving watching this project develop. Always thought that the Rogallo wing was a good recovery concept just needed refinement. Its nice to see they are using a similar method for recovery of the SpaceX fairings , but under automatic guidance.
Nice to see you all here ... and thanks for the comments!
I had just 2 reference pix for the landing gear ... this is the Nose ...
... and the Main Landing Gear.
Assembling the hull, I used scrap styrene shims to fill some gaps at the heat shield and other seams ...
A channel needed to be built for the lines for the Rogallo wing ... first on the RCS section ...
... and the crew cabin.
At the heat shield, a groove was cut in for the lines for the Rogallo wing.
To repair a missing chunk in the heat shield, Milliput was stuck in, and sanded down ...
I wanted to install a skid plate onto the front of the Nose Gear.
... and done.
On the top of the Nose Gear is a spool which plays out line when the Wing is deployed. This is the rudimentary pattern ...
A variety of iterations and the final one to the right, made from sheet Aluminium. The spool itself is styrene tubing.
And installed.
Starting to detail the crew cabin ...
... and with hatches and RCS section dry fit.
A dry fit of the MLG and NLG ... I held the model upside down and took the picture ...
This is coming together rather nicely.
IPD
After a coat of primer I replaced some of the washers that were sanded off previously ...
Some of my sketches to try to figure how best to display this model ...
Using 1/2" tubing, starting to build the Rogallo wing.
With a sheet of thicker paper I started to develop the patterns ...
The scale of the 2 subassemblies looks about right.
A possible display idea ...
To support the stand, I placed a tube of Brass into the styrene tube ... a length of clothes hanger will be the main support of the completed model.
Using a sheet of 0.010" styrene the wing is getting assembled ...
In an attempt to show some billowing of the 'chute material, I'll try using Grocery bag plastic attached with Rubber Cement.
The pencil lines will be my guide for applying stripes of Rubber Cement ...
Clamping the sheet styrene to the tubing. You can also see the stripes of Rubber Cement
This'll do for now ... till next posting.
IPD
I sprayed on a coat of Model Master Steel
... and then a coat of Light Grey ... I wanna try to get the effect of having re-entered the earth's atmosphere ...
The hatches didn't sit correctly, so I added a few styrene supports ...
That's better
The decals ... they needed a lot of setting solution and a little coercion to settle into the corrugations ...
They settled very nicely
I'll also try to replicate the wear on the heat shield ...
Getting there ...
... looks good enough!
To get that worn, burnt look, I sanded down through the layers of paint ... this is just about what I was looking for.
Some paint on the Nose ...
Installing the spool ...
I added a couple of guides / anchors to the spool because there will be some tension on it ...
Main Gear installed ...
And with the Nose Gear installed ...
And even though it will be suspended, it was nice to see it self supporting ...
I had to do a little surgery and add a couple of rods to support the Wing lines ...
And then make sure it would support the weight ...
That's a lot of images, let's see if it posts ...
IPD
