alt-92 3,258 Posted March 24, 2020 Share Posted March 24, 2020 This is a kit I've had on my to-do list for a relatively short time, but needs must, opportunity rises etc. etc... Did not expect to join the GB at the beginning, however, being confined to home there's no time like now. So, without further ado, I present you: The Swedish* Heavy Metal Display - Solo build. The kit is delivered in a sturdy, compact, but tall two-part packaging: Clicking around the site, I've also taken the liberty of adding some Aftermarket bits. Consisting of some LED lights: 4 1 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 First steps: The obligatory sprue shots. After carefully slicing the tape and opening the first box, we can see the custom wrapped and boxed clear parts. Along with the content of box 2 in black metal: plenty of soft wrapping materials at hand, I must say they did not skimp on the packaging. Moving along, we also find the deconstruction Manuel. 2 1 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 ....which upon opening, instructs us in no uncertain terms to begin with the assembly of the landing gear. Oh well...nothing for it. Gear struts assembled, and I must admit: no putty or sanding needed. In fact, things are going so well, I've proceeded with the assembly of the main fuselage spars as well. This is going to be quite a big stonker once it's finished! 1 3 Link to post Share on other sites
stevej60 37,296 Posted March 24, 2020 Share Posted March 24, 2020 Great start,should be a big beast when finished,are you going for a splinter finish? 2 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 Preferably not - this will be a clean build, right out of the box so to speak - apart for the landing lights that is. Work intervened. WfH is great, but less if you're part of the guys making it possible you actually CAN work from home. 1 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 Right. Panic averted! Which means, we can finish the build just in time for dinner. Just before the call to arms, I managed to get the roof on. By this time, it seemed a good idea to move the build to the location where it's going to end up - so here we go, first side & back windows added. The windows are quite a tight fit, and together with the severe danger of warping it really needs proper attention to adjust the stance. Fortunately, the gear struts are not too long, and have the built-in option of playing with the oleos extended or not to fix abovementioned issue. The roof top is bluetacked in place, because we still need to fit & adjust.... The doors. Greebly bits added: And a bit out of focus but recognizable, the bay door pivots. 1 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 Doors fitted, and adjustments made: As obviously the interior of the fuselage will be extremely visible, proper care is taken to add the illumination. Now, I believe these are the correct tools, right? Feedback appreciated 1 2 Link to post Share on other sites
Pete in Lincs 14,610 Posted March 24, 2020 Share Posted March 24, 2020 Black interior rather than green? Must be a post war model. 2 1 Link to post Share on other sites
Col. 11,454 Posted March 24, 2020 Share Posted March 24, 2020 Brilliant Now I want to add one of these to the stash, or is that for the stash myself. 1 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 ¿porque no les dos? Anyways, where were we? Oh right. Illumination. The aftermarket LED lighting is one of those multipurpose thingies, you can also use them in wardrobe closets & such and therefore each has a pretty looooooong lead attached. Needed to do something about that, so this is the front view: Now normally, these thin white wires would dangle behind the rear windows - not optimal, so some scratchbuilding took place. Found a spare wire/lead guide strip in the stash/spares cabinet, so that was suitably cut to size. A near perfect fit, of course the close-up shows all the horrible bits but 1:1 it's barely noticable, I swear, really! 1 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 (edited) Nearly there, we're on the home stretch now! Time to install the innards, all the interior bulkheads are now fitted. One thing I've noticed is that this kit manufacturer is pretty good when it comes to spares, so there's a good chance I'll be adding some greeblies to hold an extra shelf. Don't know if they also sell these on a separate sprue, if not there's a place that does vacform custom work nearby. A light coating of Windex & polish later, and it's boarding time for the passengers. Excellent view of the internals with these canopy parts. Would recommend, 10.10. And that, my dear friends, concludes this build of the new 1:1 scale Milsbo Display cab Solo* build from that big Swedish store. Hope you like it! *Disclaimer: please pay attention to what the Deconstruction Manuel states: for safety, you should do this with two persons. Not possible in my case, YMMV, at your own risk, yada yada, consult a lawyer, etc. Edited March 24, 2020 by alt-92 5 1 Link to post Share on other sites
Col. 11,454 Posted March 24, 2020 Share Posted March 24, 2020 Quick work and a lovely overall finish. The internals look good too 1 Link to post Share on other sites
alt-92 3,258 Posted March 24, 2020 Author Share Posted March 24, 2020 Thanks I know the whole flatpack bit from the rules was mostly made in jest, however I decided to grab the bull by the horns and run with it. Not kidding about the warping bit though, these panels are really tight and I've heard plenty stories of breakage. Link to post Share on other sites
trickyrich 16,428 Posted March 24, 2020 Share Posted March 24, 2020 I love it!!!! I've been wondering when we'd see a proper Ikea build......though it's not really one as you finished it and probably had no bits left over! And you also fitted the bill but then filling it with some nice looking models. I do like the case, though I'd probably need a dozen or so of these....plus do they come in bigger sizes?? A couple of mine would easily take up the entire shelf and more! Great to see something like this in the build. a bit of fun and enjoyment for everyone, well done! 1 Link to post Share on other sites
flarpen 502 Posted March 25, 2020 Share Posted March 25, 2020 Well, that is a nice clean build. However, I did miss what kit it is. 1 Link to post Share on other sites
alt-92 3,258 Posted March 25, 2020 Author Share Posted March 25, 2020 (edited) 14 hours ago, trickyrich said: I love it!!!! Thanks Felt good doing it, some lighthearted building in these times. Quote I've been wondering when we'd see a proper Ikea build......though it's not really one as you finished it and probably had no bits left over! Hmm.. Let's see, The only bits left are the obligatory wallmount brackets Ikea must provide to keep the damages claims at bay. So two screws & metal brackets in the spare parts bin. Quote And you also fitted the bill but then filling it with some nice looking models. I do like the case, though I'd probably need a dozen or so of these....plus do they come in bigger sizes?? It's big enough at 1.75 meters high & 65cm wide. I did check before, so I picked this one because it'll fit the 1:48 collection inside. 4 hours ago, flarpen said: Well, that is a nice clean build. However, I did miss what kit it is. Milsbo Black, also available in white. Edited March 25, 2020 by alt-92 links added 1 1 Link to post Share on other sites
desert falcon 782 Posted March 26, 2020 Share Posted March 26, 2020 Nice cabinet and a very nice collection as well 1 Link to post Share on other sites
