1/72 Hasegawa F-4E Phantom in flight, RAAF 1 squadron
Hi all.
This one has been sitting on the shelf for a while, so with other bits and pieces drying for other kits, I got back into painting it. It's the 1/72 Hasegawa F-4EJ Phantom with Hawkeye decals to be dressed as a 1 squadron jet. This one one will be on a stick, hence the gear up.
The tan had been applied quite some time ago so on Saturday night I pencilled in the camo scheme using a Faber Castell water colour pencil and then applied the light green. Sunday was the darker green’s turn.
The paint has been applied freehand and this is the second model I’ve tried it on. I’m really happy with the result considering it’s a 72nd scale model. I used a Harder and Steenbeck with a 0.15mm needle and about 12-15 psi on the pressure gauge; enough to get a fine line but not so low to cause the paint to spatter.
The colours used were Gunze H420 RLM80 Olive Green, Gunze H303 FS34102 Green and Gunze 310 FS30219 Brown. The underside is Gunze 338 Grey.
The metal panels around the exhaust are done in Alclad, specifically Stainless Steel dusted with dark aluminium and then a very thin mix of translucent blue on some of the panels. All of it was then sealed in with Mr Color Clear.
The decals are from Hawkeye which look good but are printed on a single piece of carrier film. The roundels also have the white backing decals which I’m not a fan of. I had a rat through the decal spares and found a sheet of Australian roundels from the Peter Russel era of Aussie Decals. I tested a roundel on the upper wing and although it took a while to de-stick from the carrier paper it reacted very well to Microsol. You can see the result in the picture of it. The glue residue is visible in the pic but it will be wiped away.
I’ve since painted the red fuselage warning band for the compressor blades.
I enjoy the painting stage the most and this one has been a lot of fun. I think I’ll need to investigate the three tone Vietnam era camo subjects a bit further.
Weathering soon!!!
Mick
Edited by Mick Drover
Title correction
  • Like 17
16 hours ago, Col. said:
Tidy paintwork :goodjob:  The white decals on a white backing sheet look like a fun game of hide and seek :blink2:
Thanks Col. I ditched the roundels from the Hawkeye sheet. What you seen in the pics are the Aussie Decals version. You can place either a rat or a red dot in the middle depending on the era. They respond well to Microsol too.
13 hours ago, Retired Bob said:
Some good freehand airbrushing there, going to look really nice when finished. :like:
Thanks Bob. Decals have been started.
14 hours ago, Booty003 said:
Lovely fine edge on the airbrushing, going to look very smart.
Thanks Booty. I'm quite happy with the result so far.
