robstopper 26 Posted March 18, 2020 Share Posted March 18, 2020 I'm building the new Tamiya MkI 1/48 Spitfire at the mo. I've ordered an Eduard canopy mask, rather than try to hand-cut the box-issue Tamiya one. I've used masks before, but with this one i was wondering if its better to mask and paint the canopy first, then fit to the model at the last minute, or if it's better to fit them to the model first, mask it up, then paint all in one go before removing the mask as the last step? TIA. Link to post Share on other sites
robstopper 26 Posted March 18, 2020 Author Share Posted March 18, 2020 Sorry, posted in cold war by mistake. Mods feel free to move please Link to post Share on other sites
FinnAndersen 477 Posted March 18, 2020 Share Posted March 18, 2020 If your model has the canopy closed, then I would attach canopy before masking. If cockpit is open, mask first and then attach. Link to post Share on other sites
Chuck1945 284 Posted March 18, 2020 Share Posted March 18, 2020 FWIW, I’ve been using Eduard masks for the last couple of years and normally, if the kit canopy is used, mask and paint the canopy on the aircraft. If the canopy is to be removed for whatever reason, I’ll just attach it with white glue for the painting step so it can easily be popped off later - example the pilot’s section of an Eduard Bf 110 canopy that will be open when finished Link to post Share on other sites
robstopper 26 Posted March 18, 2020 Author Share Posted March 18, 2020 Canopy will be closed, so fit then mask seems to be the general consensus. Cheers for the advice. Link to post Share on other sites
Seawinder 604 Posted March 18, 2020 Share Posted March 18, 2020 1 hour ago, robstopper said: Canopy will be closed, so fit then mask seems to be the general consensus. Cheers for the advice. I would opt for putting on the masks before the parts are installed because it's less cumbersome to do the small placement adjustments without having to heft around the entire model. Otherwise, I can't see any difference in the result either way. Link to post Share on other sites
alt-92 3,260 Posted March 18, 2020 Share Posted March 18, 2020 I would think it's more useful to take into account the effect you want to accomplish - i.e. a clean, gradual transfer from windshield/canopy to fuselage. 1 Link to post Share on other sites
AltcarBoB 791 Posted March 18, 2020 Share Posted March 18, 2020 (edited) I have done 2 models recently using pre cut masks. A 1/72 Fokker DXXI with the canopy fitted and last week a 1/72 Fairly Fulmar before fitting the canopy. Doing the Fokker was an utter ball ache and I cracked the left hand undercarriage wheel fairing. The Fulmar was a 30 minute job easy to flip the canopy round, get your finger tips inside to press the mask down and no risk breaking off delicate parts. I know which way I will be doing it in future fit masking, glue on canopy and then get the hairy sticks or airbrush out Edited March 18, 2020 by AltcarBoB Speeling Link to post Share on other sites
Nocoolname 1,369 Posted March 18, 2020 Share Posted March 18, 2020 Ohh. Is this like one of those... 'milk first then tea, tea first then milk' queries? Link to post Share on other sites
robstopper 26 Posted March 18, 2020 Author Share Posted March 18, 2020 #confused.com Link to post Share on other sites
Smithy 1,238 Posted March 18, 2020 Share Posted March 18, 2020 (edited) I always mask before attaching the canopy regardless of whether open or closed. I use Parafilm so have to cut to make the mask and trust me it is far, far, far easier to do this on a separate canopy stuck to the working surface with a little Blutack because you have to move the piece around to cut it. With premade masks I still do this, much easier control working on the canopy by itself. Edited March 18, 2020 by Smithy Link to post Share on other sites
72modeler 6,323 Posted March 18, 2020 Share Posted March 18, 2020 As @Smithy has stated, I also mask my canopies and paint them before attaching to a model. I also pour some plaster of Paris, or better yet, dental stone into the bottom of the inverted canopy to fill it. (I get a small tub free from my dentist/dental lab, and it will provide enough material for many canopies in 1/72.)This will protect the canopy from flexing and getting stress cracks from the repeated handling and finger pressure. A blob of the same on the bottom gives you a handle if you need it. Masking and painting a canopy already attached increases the possibility of cracking any filler or paint already applied to the model, or knocking something else loose. Those transparencies that have a significant portion designed to to painted to match the surrounding area would be exceptions. Mike Link to post Share on other sites
robstopper 26 Posted March 19, 2020 Author Share Posted March 19, 2020 As its on a spifire, theres not a lot of protruberances to worry about, the undercart on this tamiya kit is an all-in-one single piece (genius idea that, i always struggle to get the legs aligned and secured properly!), so the risk of damage when masking and painting with the canopy insitu is a lot less than on a biplane for example. But, I think i'll probably mask then fit, but will see how i feel when i get to that stage. Link to post Share on other sites
alt-92 3,260 Posted March 19, 2020 Share Posted March 19, 2020 mask > fit > spray/brush Link to post Share on other sites
FinnAndersen 477 Posted March 19, 2020 Share Posted March 19, 2020 2 hours ago, robstopper said: As its on a spifire, theres not a lot of protruberances to worry about, the undercart on this tamiya kit is an all-in-one single piece (genius idea that, i always struggle to get the legs aligned and secured properly!), so the risk of damage when masking and painting with the canopy insitu is a lot less than on a biplane for example. But, I think i'll probably mask then fit, but will see how i feel when i get to that stage. I never fit the undercart until painting is completed, including the final clear coat. That entails having the undercart doors painted and coated on the runners and only removed when I install the undercart, antenna and pitot. That strategy leaves me with a relatively clean model that can be filled, sanded, primed, painted, masked and painted repeatedly. Of course the first thing to mask and paint is the canopy as this has to have interior color visible through the glass. That said, to avoid paint seeping under the canopy mask, I apply a coat of gloss clear as the first coat on the canopy, before the interior color. HTH Finn Link to post Share on other sites
Seawinder 604 Posted March 19, 2020 Share Posted March 19, 2020 20 hours ago, 72modeler said: As @Smithy has stated, I also mask my canopies and paint them before attaching to a model. I also pour some plaster of Paris, or better yet, dental stone into the bottom of the inverted canopy to fill it. (I get a small tub free from my dentist/dental lab, and it will provide enough material for many canopies in 1/72.)This will protect the canopy from flexing and getting stress cracks from the repeated handling and finger pressure. A blob of the same on the bottom gives you a handle if you need it. Masking and painting a canopy already attached increases the possibility of cracking any filler or paint already applied to the model, or knocking something else loose. Those transparencies that have a significant portion designed to to painted to match the surrounding area would be exceptions. Mike My strategy for Spitfires is to mask the windscreen, attach it to the fuselage, apply further masks to keep paint from getting inside the windscreen and/or the cockpit, then apply interior color to the windscreen followed by external camouflage. I do the same thing with the small clear piece at the rear of the cockpit. I mask and paint the sliding canopy separately before attaching it to the model. Link to post Share on other sites
Stressy 129 Posted April 5, 2020 Share Posted April 5, 2020 Do any of you have trouble with acrylic paints not adhering to the canopy plastic very well with a tendency to peel, particularly when you remove masking? Link to post Share on other sites
