F-14D Upgrade Sets (for AMK) 1:48
1:48 Eduard Brassin
After much delay the AMK F-14D was released (reviewed here), and here we have some rather nice detail and upgrade sets to go with it from Eduard, who have a long history of first rate resin and Photo-Etch (PE) sets for those hungry for more detail in their models.  As usual with Eduard's Photo-Etch (PE), small resin and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between.  The larger set arrives in the new shallow Brassin cardboard box, with the resin parts safely cocooned in bags, and the instructions folded around acting as padding.
F-14D Seats (648535)
The Tomcat is a two-seater, and both SJU17A NACES seats (AKA Martin-Baker Mk.14) are supplied in the set with additional resin parts for the canopy breakers; seat cushion; umbilical, and a full set of pre-printed PE seatbelts, pull-handle and leg restraints.  The instructions include painting guide with Gunze Mr Color call-outs, and after main painting the stencil decals are applied for the ultimate in realism.  The seats are identical, so applying the seatbelts in a slightly different pattern will assist with realism, giving the impression that the crew have just departed for the mess.
F-14D Wheels (648530)
Kit wheels are generally in two halves, which means you have the resultant joins to deal with, possible mould-slip issues on single part wheels, and sometimes less than stellar detail due to the moulding limitations of styrene injection technology, especially in the tread department.  That's where replacement resin wheels come in, with their lack of seamline and superior detail making a compelling argument.  They are also usually available at a reasonable price, and can be an easy introduction to aftermarket and resin handling, as they are usually a drop-in replacement.  In this Brassin set you have two highly details main wheels with separate brake detail and a duo of smaller nose wheels to cope with the harsh carrier landings.  You also get masks for the hubs/tyres to cut perfect demarcations.
Upgrade Set (491053)
Two frets are included, one nickel plated and pre-painted, the other in bare brass.  A complete set of new layered instrument panels, cockpit wall and side consoles are the primary parts on the painted set, with new rudder pedals and floor skins; boarding ladder; chaff & flare boxes; refuelling probe covers; slate end skins;  canopy internal structure and rear-view mirrors; fold-down foot pegs for the pilots; slime-lights on the nose and sides; additional vents with backing fans, plus a set of delicate, detailed afterburner rings to slip inside the two exhaust trunks also supplied.
Seatbelts STEEL (FE1054)
The new ultra-thin and bendy steel frets are becoming common in the Eduard line, and if you aren't going for the resin seats, you can get the PE from that set separately to improve the kit parts with pre-painted belts; anti-flail leg straps, and ejection actuation hoops
Tface Masks (EX673)
Supplied on two sheets of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape.  On the second sheet there is another set of canopy masks tailored to fit the interior of the glazing so that you can paint the interior and give your model that extra bit of realism.  It's especially useful on kits of this level of detail, as it will simplify painting enormously.
Review sample courtesy of
  • 3 months later...
Just a word of caution for the obsessed Tomcat fan, the Eduard F-14D wheels are not actually D wheels, they depict the main wheel hub of B/late A. So far I don't think they have actual D wheels. The detail is stunning though.
