Shorty84 Posted April 11, 2020 Share Posted April 11, 2020 2 hours ago, Rabbit Leader said: Isn’t it amazingly how we modellers look at various household items in different ways. That’s one novel way to make use of a Pepsi can! Yup, I use drinking cans regulary to scratchbuild parts I normally would buy photoetch for. The material is really nice to work with, you can cut, sand, drill, scribe and emboss it easily. Adrian, seems you are progressing nicely on your conversion. I'm eager to see how your approach on the nacelles turns out. Cheers Markus Link to comment Share on other sites More sharing options...
Adrian Hills Posted April 11, 2020 Author Share Posted April 11, 2020 Got the basic shape in Milliput for nacelles. With spinner in place it shows I will have to remove some meat to get profile correct. I might add that my method of construction follows the excllent method chosen in Luis Mira's build 🙂 6 Link to comment Share on other sites More sharing options...
CliffB Posted April 14, 2020 Share Posted April 14, 2020 On 4/10/2020 at 7:49 PM, Adrian Hills said: and then attended to the problem of the rear roof of the cockpit, not represented in this kit. On a previous build I used plasticard but this time it was just not working. Fortunately I found a solution !! Another great idea Adrian, but I might struggle with my FROG build...…. Cheers 2 Link to comment Share on other sites More sharing options...
vppelt68 Posted April 14, 2020 Share Posted April 14, 2020 you guys really model at the other end of the spectre than I do, out of the box. This is yet another incredible build! V-P Link to comment Share on other sites More sharing options...
Adrian Hills Posted April 20, 2020 Author Share Posted April 20, 2020 In the lovely sun a bit of al fresco modelling. Fortunately the light wind blew away the Milliput dust. I now have shapes about right (nothing is perfect with me). Next stage will be to add air intakes. 7 Link to comment Share on other sites More sharing options...
Adrian Hills Posted April 21, 2020 Author Share Posted April 21, 2020 Now refined lower section of nacelle, compared it in dimension and positioning with 1/72 nacelle and fitted air intakes (bits of straw). Since the photo below I have added a centre divide. Tomorrow will coat in Milliput. 5 Link to comment Share on other sites More sharing options...
Adrian Hills Posted April 22, 2020 Author Share Posted April 22, 2020 A morning of Milliputting. It was going off after the first one so had to get best shape possible. Hope to thin porky one down (nearest camera) - if possible ! 10 Link to comment Share on other sites More sharing options...
CliffB Posted April 22, 2020 Share Posted April 22, 2020 Where there's a will, there's a way. You're achieving incredible results Adrian. Cheers Link to comment Share on other sites More sharing options...
Adrian Hills Posted April 28, 2020 Author Share Posted April 28, 2020 Hammond (the rubber crocodile) says 'they'll do@ 5 Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 1, 2020 Author Share Posted May 1, 2020 Exhausts and ventral breather. I've made the sixteen other bits that go in front and behind exhausts, but as they are only one mm across will leave them for tomorrow ! 9 Link to comment Share on other sites More sharing options...
vppelt68 Posted May 1, 2020 Share Posted May 1, 2020 Amazing effort, well done! 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted May 1, 2020 Share Posted May 1, 2020 Those Vultures have really turned out lovely and look like they might even work better than the real examples! That's real craftsmanship, well done. Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
zebra Posted May 2, 2020 Share Posted May 2, 2020 Those Vultures are superb! 1 Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 6, 2020 Author Share Posted May 6, 2020 Assembled and waiting for last bits of Milliput to dry before gluing end plates on and hosing down. Would like to try Airfix enamel Dark Earth as getting bored with Gunze. 5 Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 7, 2020 Author Share Posted May 7, 2020 Got the garden hose out and sprayed some Humbrol Dark Earth. I predominantly use Gunze but think a change is good. I painted my last Manchester (my first vac conversion nearly thirty years ago) with my special Gunze F.A.W. Dark Earth. I used to add black, grey, RLM chocolate and occasionally blue to mute it a bit. I'll leave it to you to guess what FAW stands for. This paint is very matt and quite furry. What has worked well in the past is a good polish. It just takes the edge off the mattness and will be done when dark green and flat black applied. I used to use a scrap bit of silk. However, it disappeared years ago and my lover found me rooting around in her knicker draw - so will need another source for silk !! 6 3 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted May 7, 2020 Share Posted May 7, 2020 1 hour ago, Adrian Hills said: ... and my lover found me rooting around in her knicker draw - so will need another source for silk !! Sourcing another polishing cloth you say Adrian.. yeah right! The Lanc looks nice in DE, furry bits and all... Hehehehe 😆 Cheers.. Dave Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 11, 2020 Author Share Posted May 11, 2020 Hmmm, found out that Humbrol 30 was certainly NOT RAF Dark Green and nearest I had was their 163 in satin - hence it is a bit shiny. Will hose lot down with Humbrol Satincote or similar. Might help to overcome decal silvering problems. However, I like the Humbrol interpretation of the RAF colours Here is a comparison of Gunze Sangyo's offering 6 Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 20, 2020 Author Share Posted May 20, 2020 Finally got around to pull moulding the canopy. Interestingly I filled the 'sacrificial' canopy with Milliput about ten years ago as I always intended to make an Avro 684 (subject of another build stream) and didn't need it. I followed Cliff's advice and sharpened up the shape of the windscreen. Having pull moulded a canopy for a previous build, a conversion to a Lanc damaged in a Russian peat bog after attacking the Tirpitz, I decided to make this canopy a lower profile and the same height as the crappy injection job. I hope you agree it was worth the effort. Now I really must get these builds finished as the Blizbuild is this weekend and my Matchbox Walrus awaits ! 5 Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 21, 2020 Author Share Posted May 21, 2020 A bit of white glue and I'll fudge the gaps with masking tape. Covers all manner of sins. Besides I've already got my girlfriend's secret roll out to do seat belts for the 1/100 scale pilot ! I seem to have a spare 1/72 Lanc canopy which firstly shows the massive disparity in size between 1/96 and 1/72 (this can also be seen on CliffBs post on Canadian Lanc) - but will use the framing as a guide for my pull moulded effort. 6 Link to comment Share on other sites More sharing options...
Troy Smith Posted May 21, 2020 Share Posted May 21, 2020 1 hour ago, Adrian Hills said: A bit of white glue and I'll fudge the gaps with masking tape. By chance, as I had some for DIY jobs, I used Wudcare 5 minute fast grab PVA, it's really good quick drying waterproof PVA, good for jobs this, plus a wetted paint brush can be used to clean up and persuade glue into gaps. I can give a little tub to play with some time. Remember that Microscale Kristal Kleer is basically just PVA anyway. On 11/05/2020 at 17:23, Adrian Hills said: Might help to overcome decal silvering problems. Have you not tried the 'bed in kleer' trick yet? Looking good Cheers T Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 21, 2020 Author Share Posted May 21, 2020 Cheers Troy. Couldn't resist this photo as I'm really quite pleased with interaction of the profile of the engines with the spinners. Remember, this is the third spinner I re-profiled as well as persuading Milliput to curve down. Not perfect but good enough to put a smile on my face 7 Link to comment Share on other sites More sharing options...
CliffB Posted May 22, 2020 Share Posted May 22, 2020 This is all looking really good Adrian (and yes, your new canopy is a massive improvement of the kit part!). Cheers 1 Link to comment Share on other sites More sharing options...
Rabbit Leader Posted May 22, 2020 Share Posted May 22, 2020 On 22 May 2020 at 7:20 AM, Adrian Hills said: .. Not perfect but good enough to put a smile on my face Something that we all need to remember every now and then, although one must'nt sell oneselve short, for this is a great result so far Adrian. Cheers.. Dave 1 Link to comment Share on other sites More sharing options...
Adrian Hills Posted May 27, 2020 Author Share Posted May 27, 2020 A long haul but it is now DONE. Just to show you that I used masking tape for the canopy framing. Hammond wanted to get in on the action while I celebrated with a bottle of Harvey's finest seasonal ale Proper pictures to follow in gallery tomorrow. But for now here are a few Luis Mira's 1/144 build was such an inspiration 🙂 4 Link to comment Share on other sites More sharing options...
CliffB Posted May 28, 2020 Share Posted May 28, 2020 Congratulations Adrian, on crafting such a unique model Cheers 1 Link to comment Share on other sites More sharing options...
