Julien Posted March 13, 2020 Share Posted March 13, 2020 Model T 1911 Touring with American Motorists ICM 1:24 (24025) The Ford Model T car has gone down in history as the worlds first mass produced car. By 1927 in a little over 9 years 15 million cars were produced. In 1999 the Model T was crowned the most influential car of the 20th Century. The Model The model arrives in the usual sturdy box with a separate top sleeve with a nice artist’s representation of the vehicle on the front. Inside, within a large poly bag, are four sprues of grey plastic, a clear spure and 4 rubber tyres. There is also one sprue for the figures. The build starts with the nicely detailed engine with the block and gearbox halves glued together followed by the addition of the rocker covers, fan belt, dynamo, exhaust manifold, cooling fan, cooling pipes, and other sundry items. The radiator is attached to the front axle and just needs the radiator grille glued to it to complete the assembly. The radiator/axle is then glued to the front of the floor pan/chassis. The rear axle, drive shaft and differential are built up from only three parts and fitted to the underside of the chassis along with the two piece exhaust/silencer unit. The front and rear axle support frames are then added, as is the steering rack. The four wheels, rubber tyres are added to the spoke wheels and are glued to the axles, the construction moves to the body work. The rear engine wall (not a firewall as its not solid) is made up and added, the engine covers are then added. The rear coachwork body is then made up and added to the chassis. The driver floor pan is added along with the steering wheel and column. Drivers pedals are added. The seats are then made up and added, along with the windscreen and its supporting stays. If fitting the roof this is the next part to be added (note there is no option for the roof down). The rear part has its window added and then its fixed to the roof. The stays are then added and the roof can be fitted. The horn arrangement is made up and fitted . The last items to be made up are the head lights, lights and the motormeter for the radiator. Decals There are no decals included in this kit. Figures This is ICM set 24013 "American Motorist". One is a male driver and the second is a female passenger. Both are what would be considered well dressed for the period. In general the mould in crisp and clean with plenty of detail. . Like ICM's recent figures these are well sculpted and should build up well. Conclusion This is another great addition to the Model T series that ICM have been releasing. As with the other versions, it looks like it wont be a difficult kit to make, but will look great once painted. Recommended. Available in the UK from importers H G Hannants Ltd. Review sample courtesy of 3 Link to comment Share on other sites More sharing options...
fatfingers Posted March 14, 2020 Share Posted March 14, 2020 Thanks for the review. Not my usual bag but i could be tempted by this. Recently finished their Model T Fire Engine and it was a really nice kit. Regards, Steve Link to comment Share on other sites More sharing options...
