Marklo Posted November 16, 2021 Author Share Posted November 16, 2021 (edited) Thanks for moving the thread. I think I’m finally looking forward to finishing this one. First off a quick recap. The CIX is pretty much a two seater DIII with new swept wings in a sesquiplane configuration. Three were built, but the type was never put into full scale production. I’ll be finishing this as the second prototype which was converted for use as a transport plane for Manfred Von Richthofen, partly because of the historical interest and partly because the other two schemes are either boring ( first prototype) or way too complex ( third prototype) Next step, finish the interior and zip it up. Edited November 16, 2021 by Marklo 3 Link to comment Share on other sites More sharing options...
matti64 Posted November 17, 2021 Share Posted November 17, 2021 Its a good subject Mark. I have been tempted but have been put off by the fact that it has a highly curved top but a dead flat bottom of the fuselage and I couldnt think of a way for me to make that with any confidence. It looks like you are well on track with it though. 1 Link to comment Share on other sites More sharing options...
Marklo Posted November 17, 2021 Author Share Posted November 17, 2021 Dusted off the fuselage and attached the upper decking. The interior is far enough advanced that I can finish it with the fuselage zipped up. 5 Link to comment Share on other sites More sharing options...
Marklo Posted November 18, 2021 Author Share Posted November 18, 2021 Upper deck on. I’m sort of running a photo behind as I’ve also milliputed the sides. 3 Link to comment Share on other sites More sharing options...
jean Posted November 18, 2021 Share Posted November 18, 2021 This is so ridiculously impressive and so far out of my league/patience, that I can only look at your thread in awe. Congratulations for the work you have already done! JR 1 Link to comment Share on other sites More sharing options...
Marklo Posted November 18, 2021 Author Share Posted November 18, 2021 milliput on. 2 hours ago, jean said: This is so ridiculously impressive and so far out of my league/patience, that I can only look at your thread in awe. Thank you. But remember it’s not the level at which you model it’s wether you’re enjoying your hobby. There are many modellers on the forums that are way better than me, but it’s so nice to learn from their work. 7 Link to comment Share on other sites More sharing options...
Marklo Posted November 18, 2021 Author Share Posted November 18, 2021 (edited) On 11/17/2021 at 9:49 AM, matti64 said: Its a good subject Mark. I have been tempted but have been put off by the fact that it has a highly curved top but a dead flat bottom of the fuselage and I couldnt think of a way for me to make that with any confidence. It looks like you are well on track with it though. You’re welcome to my molds if you’d like. ( also assuming I can find them ) I managed to get a semi decent plunge mold out of them. They are in 1/48 which isn’t everyone’s ideal scale. Edited November 18, 2021 by Marklo 1 Link to comment Share on other sites More sharing options...
Marklo Posted November 26, 2021 Author Share Posted November 26, 2021 (edited) I find my soldering skills are very hit or miss, but today they worked a treat first time. So notwithstanding a little filling the that’s the interplane struts sorted. I’m hoping for a fairly easy assembly. And here’s the current state of the component parts, I’ve given everything a coat of primer as I had done in the cup from another job and never like to waste things. The fuselage is almost done and the wings need trimming, shaping and done scribing. Oh and I’m pretty sure there’s a rudder floating around somewhere. Once the two high wing build are done I’ll probably concentrate on the KUTA collection, oh and of course my four remaining 109s Edited November 26, 2021 by Marklo 6 Link to comment Share on other sites More sharing options...
pheonix Posted November 26, 2021 Share Posted November 26, 2021 A little filing of soldered joints is fairly normal in my experience. What matters is what they look like when cleaned up and are they secure - if yes to both then success! P 1 Link to comment Share on other sites More sharing options...
Marklo Posted November 26, 2021 Author Share Posted November 26, 2021 (edited) 1 hour ago, pheonix said: if yes to both then success! Most definitely, even I was surprised. But tbh it’s one of my few truisms that the more effort I put into my model engineering the more things go according to plan Edited November 26, 2021 by Marklo 1 Link to comment Share on other sites More sharing options...
Marklo Posted December 7, 2021 Author Share Posted December 7, 2021 The lower wings are drilled and pinned with brass rod, as is the tail. And I’ve drilled and dry fitted the interplane struts. The wings need a bit of trimming and shaping before I go gluing things. 3 Link to comment Share on other sites More sharing options...
Marklo Posted December 12, 2021 Author Share Posted December 12, 2021 (edited) The lower wings have been trimmed snd shaped and the fuselage is pretty much finished. The plans show a scalloped trailing edge on the wings al a Fokker but I’m not sure that’s correct, I need to take a closer look at the photos and check it. I’ve also cut the rudder off as I got the shape slightly wrong so I’ll have to go again for that. Some assembly next. Then the undercarriage and I can start the paint work proper. Edited December 12, 2021 by Marklo 6 Link to comment Share on other sites More sharing options...
Marklo Posted December 14, 2021 Author Share Posted December 14, 2021 (edited) wings assembled. It’s semi primed as I had a bit leftover from my other projects today. And the rudder horizontal tail surfaces and undercarriage. I’ll get some wheels and the tail skid on next. Then it’s final cleanup before painting. Edited December 14, 2021 by Marklo 5 Link to comment Share on other sites More sharing options...
Marklo Posted December 17, 2021 Author Share Posted December 17, 2021 wheels and tail skid on. Upper wing trimmed joined and dry fitted. Really starting to take shape. 8 Link to comment Share on other sites More sharing options...
Marklo Posted December 18, 2021 Author Share Posted December 18, 2021 Had some paint left in the cup after preshading the flagon and the tomcats so I couldn’t resist giving the CIX a coat of paint, even though it still needs a bit more filler and sanding very pleased with how it looks. 6 Link to comment Share on other sites More sharing options...
Marklo Posted December 23, 2021 Author Share Posted December 23, 2021 I’ve foiled the engine covers and attached the interplane struts. I’ve also pinned the elevator on with brass rod as I keep knocking it off. A little last minute cleanup, just about ready for paint. 4 Link to comment Share on other sites More sharing options...
Marklo Posted January 20, 2022 Author Share Posted January 20, 2022 Undersides painted. The fuselage will be red, but I’ll try to get a bit of a plywood look going underneath it. 6 Link to comment Share on other sites More sharing options...
Marklo Posted January 21, 2022 Author Share Posted January 21, 2022 (edited) Green on the upper surfaces. The area around the hump is still a bit rough so I’ve painted it green to give me a sanding guide. Edited January 22, 2022 by Marklo 5 Link to comment Share on other sites More sharing options...
Marklo Posted February 3, 2022 Author Share Posted February 3, 2022 Post shading on the green and some purple. Red next. 2 Link to comment Share on other sites More sharing options...
arfa1983 Posted February 4, 2022 Share Posted February 4, 2022 I still can't see any of your pics Marklo Link to comment Share on other sites More sharing options...
Marklo Posted February 4, 2022 Author Share Posted February 4, 2022 On my iPhone I can see the pics on android I can't see any hmmm, no idea how to fix it.... Link to comment Share on other sites More sharing options...
Marklo Posted February 5, 2022 Author Share Posted February 5, 2022 looking oddly Italian looking very red, it’s actually Tamiya flat red with a bit of white to tone it down. 3 Link to comment Share on other sites More sharing options...
Marklo Posted February 9, 2022 Author Share Posted February 9, 2022 wheels on. Just decals, the cabane struts, rigging, engine and prop left. 3 Link to comment Share on other sites More sharing options...
Marklo Posted February 26, 2022 Author Share Posted February 26, 2022 Some more decals on. Having had the decals from the spares box disintegrate these are home printed ones. Possibly a little oversized but I like them 3 Link to comment Share on other sites More sharing options...
Marklo Posted March 5, 2022 Author Share Posted March 5, 2022 Scribed the upper wings and added some more decals. 3 Link to comment Share on other sites More sharing options...
