For you delectation and entertainment (if you are old enough to remember the reference) here is one of two Airfix spitfire XIV that I have finished.
With a bit of effort the kit comes up nice.  With this kit I replaced
  • the 20mm barrels with some spare Edurard ones I had going unused.
  • The wheels with some resin 4-spoke jobs as these had better detail
  • Eduard seat belts
  • Freightdog decals from the "Brits Abroad" sheet.
  • Drilled out the openings for the two downward facing cameras that could be fitted.
Looking at the photos I see the long range tank is drooping a bit.  It was only held on with blue-tak 😉
Tim
  • Like 46
That's a fine looking Mk 14. It really looks smart in the SEAC scheme.
Nice work John
I have one of these on the go at the moment and with a bit of effort a nice end result can be had.
Thanks for sharing
James
Lovely result Tim. I also have one of these on the go at the moment but will probably go for the 'lazy lady v' option. Looks like you got a decent fit on the wing roots and fuel tank cover, I have found these need a bit of work (filler and a slim shim respectively) how did you get on? Either way it's a nice kit and I'll definitely do more in the future 😀 Cheers, Stu
The fuel tank cover took a bit of bending to get it to the right curvature to fit and the wing roots again took some fettling to fit.  Took a small amount of filler to blend in.
5 hours ago, Adam Poultney said:
Looks good, where can I see the other one you've done?
Sorry Adam, taken me longer to get the images up that expected.  Try here -
Tim
Looks good in the SEAC scheme.
I remember reading a biography of Ginger Lacey. He was CO of 17 Sqn in India, when bubble top Spits were delivered he said "Take them back & give me something that looks like a Spitfire!"
Pete
Very nice SEAC Spitfire, great job
