Sign in to follow this
Ima Penin Diaz
Astronaut on the Moon-Gene Cernan
I picked this up on eBay after having looked for it, for about a year.
Every model build of this kit bothered me. The kit itself is a poor rendering of the suited figure and I wondered if I could make it look ... a little better.
Plus, I don't do figures and this'll be my first one ...
It's a nice BIG figure ... and offers an opportunity to add some details ...
First thing was to cut out the face. I wanted more than just the face ... make it a little more 3D
Using Milliput, I added some more skull to his face.
The seams on this are awful ... but with some styrene scraps, the gaps were filled ...
The hose connections on the suit's torso weren't right, so I filed 'em off
After patching the seams, there are still small divots so I filled 'em with thick primer paint
The hands were cut off and rotated a few degrees and a little surgery was performed ...
The PLSS, Portable Life Support System, needs some attention as well ...
Made a couple of holes, and a few more will be too, for 'D' rings in the OPS
I was curious as to how the OPS was attached to the PLSS and decided to detach it and try to find reference for the brackets ... the tube on the side is a water container used by the Astronauts.
One can just make out the attaching brackets on the top ...
A few more holes were made to attach the hoses later on ...
Till next posting
IPD
Good stuff. That kit is notoriously unlike an actual Apollo EVA suit. It will be interesting to see how you accurize it.
I've tried vac-forming just once or twice before and wanna try it here to revise the LEVA helmet ...
 A couple of wooden bucks  ...
A side view of the kit's helmet ... I've added some styrene to the bottom and sides of the opening ...
A couple of successful attempts ... I'm gonna make a new visor too ...
On the right, I tried to vac-form a clear piece of plastic, but it didn't work ... it fogged over and I guess plastic can't be re-vacu-formed ...
The hemispherical visor piece has been cut out ...
... and the fit is not too bad at all ...
I found a blister pack that was the correct diameter and cut that out ... I'll see if I can't have a clear visor under the Gold coated one.
I also cut out the tabs that'll affix to the visors ...
The helmet sits a bit too upright so ...
... I separated it and gave it a bit of a tilt.
I also cut out a notch at the back end of the LEVA per photo reference.
Applying some first aid tape to give it some texture ...
And the top of the LEVA helmet done ...
So far, so good!
IPD
looking very good, a lot of work but I'm sure it'll be worth it
rgds
John(shortCummins)
It's not a lotta work, it's a lotta fun!  :thumbsup:\
I wanna take care of some smaller things ... the camera ...
The kit's camera is above and my version is just a stack of .040" styrene which'll get carved ...
... and almost done ...
... the RCU, Remote Control Unit on the chest, was built the same way ... this is the front ...
... and the back ...
... and the activation lever for the emergency oxygen ... this attaches to the side of the RCU ...
the cleats on the bottom of one boot ...
... carving the hose connectors on the front of the suit ...
A photo of Apollo 15's Jim Irwin and the attachment hardware for the PLSS harness ...
... and my attempt ...
The suit needs some beefing up in places ... Milliput was used ... I noticed that the shoulder on the left side was rather pointy, so I adjusted it ...
... sanded it down and rounded it over with Milliput
.... and a front view ...
The loops on the back of the boot were sanded off and replaced with loops made from Aluminium from a Lasagna pan ...
That'll do for now!
IPD
Love this kind of project,cracking modifications.
Many Thanx Gents!
The RCU and attaching hardware ...
... and with hardware attached ...
The pockets were made from thick Aluminium sheet from a frozen Lasagna pan ... the attaching straps behind the leg are strips of First Aid tape. The buckles are made from styrene scraps.
Parts for the check-list on the wrist ...
The OPS with flaps made from the thick Aluminum sheet ... back view ...
... front view ...
... the 'snaps' were made from straight pins that were snipped off ...
And with home made decals applied ... both the OPS and RCU.
... and with the completed Camera and check list
till next posting
IPD
That is looking fantastic, really like the effort going ino this, fitting the 2 visors sounds tricky to me.
I was always told that you couldn’t make a silk purse of a sows ear, but you’ve proved them wrong.
Great work. 😍
more excellent work going on here 👍
rgds
John(shortCummins)
Thanks Gents ... but let's wait and see how this "sow's ear" turns out ...  :popcorn: ... still lots could go wrong ...
I wanted to get a material that looked right on the PLSS. I tried household Aluminium foil, Tissue paper soaked in white glue ... and plastic grocery bag. This plastic creased very nicely and looked the part in scale ... so I wrapped the PLSS in it.
I also tried a variety of adhesives and found that Rubber Cement, from my old days as a Graphic Designer, adhered this plastic to the styrene, beautifully!
It was spray painted with Gloss White ...
... with Decals. The 'velcro' is just first aid tape ...
... assembled ...
... and with the sample bag harness ...
I wasn't sure if I wanted to attach a sample bag, but decided to try. I made a pattern and cut it out of household Aluminum foil ...
It's a little difficult to make out, but it looks the part ...
At the top, on the right side, the attaching hooks are visible ...
It's all starting to come together
IPD
The torso and the belt clasp ... made from styrene ...
I tried to make the 2 visors work, but couldn't get them to slide ... they are the same size and were just binding ... so I went with 1 visor and painted it ...
I painted the inside of this blister pack to maintain the glossy outside surface ...
... and it looks okay ... the LEVA helmet looks a little small, in proportion, but, I'll have to accept this.
I would have had to rebuild the entire kit piece ...
I made a base, at an angle, out of drywall pieces and plaster, but it wasn't steep enough, so I found a couple small sheets of styrofoam insulation and added it to the bottom to increase the angle of the base ... this will depict Astronaut Cernan on an EVA while walking up a steep slope.
With decals and hoses installed ...
... a scratch built hammer to include in his shin pocket ...
And almost done ...
I'd like to add some 'dirt' to the white suit, but so far, I'm happy with this ...
IPD
I have been building the courage to try my hand at a full clay sculpt of an Apollo astronaut, but maybe this is the way to go, whatever your build is certainly inspiring, great work.
MarhSH, clay modelling is a skillset unto itself, the type of clay, building an armature and just getting it to look correct, especially a human figure, is not easy to achieve. This may indeed be the better way. Start with a plastic kit and modify the heck out of it.
Here's a 360 view of this Captain Gene Cernan model ...
I may spray on some 'moondust' and dirty him up a bit ... but I'm liking how this turned out.
Many thanx for stopping by and offering your comments ... onto the next one!
IPD
I'm not usually a big "real space" fan, but that looks bloody amazing! Hats off to you, its a great seeing an old kit turned in to something so great, was a very interesting build to watch 👍
Gentlemen may I assume so? ) Thank you very much for your compliments!
These type of rebuilds satisfy me to a great extent!
And I'm glad you get some pleasure from viewing the WIPs too!
IPD
Impressive work! A great pleasure to read and follow this topic!
Cheers / André
